Can I still use hub rings if I add spacers?
Old Apr 1, 2012 | 02:59 PM
wope's Avatar
Thinking of adding 5mm hubcentric spacers on my wheels, so that they sit more flush with my fenders. Will I have any issues using hub rings on my wheels if I add them?
Old Apr 1, 2012 | 08:40 PM
Maxima32's Avatar
Where are you getting the spacer from? Find out the center bore of your wheels and see if they have or can make them hub centric to the car and wheels. You may need to go 10mm to do it though.
Old Apr 10, 2012 | 10:18 AM
Prophecy99's Avatar
no you shouldn't, i have 5mm and use hub rings for my aftermarket wheels, and it still works on the original hubs. any larger of a spacer and they usually have a lip on them to replicate the hub they are covering up.
Old Apr 10, 2012 | 11:27 AM
You won't have any issues.
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Andy29
Sep 29, 2015 05:32 AM
Redfox
Sep 28, 2015 10:41 AM
Pied
Sep 26, 2015 03:29 PM
