17x8 et20 will that fit?
Old Nov 5, 2010 | 09:21 PM
taeng's Avatar
I have a set of 17x8 et20 wheels that I plan on putting on. I currently have H&R's, but plan on going to s-techs if I put the rims on. Will this set up work? I could also have the rear disc machined down a few mm's to help if that's the worst case.
Old Nov 5, 2010 | 09:36 PM
mista0406's Avatar
those should work i have the murano rims i think there 18x9 on ksport coilovers
Old Nov 6, 2010 | 04:37 PM
taeng's Avatar
What are the offsets on the muranos though?
Old Nov 7, 2010 | 06:58 AM
Flava_24/7's Avatar
Boosted Panda
I think the offset will be way to low.
Old Nov 7, 2010 | 07:06 AM
z32drifter's Avatar
You're going to have some "poke" in the front with a 8 +20, the rear should be fine.
This is a 9 +34 (your 8 +20 will sitck out 1mm less)
Old Nov 7, 2010 | 07:10 AM
mista0406's Avatar
with no extra spacers mine are flush with the fenders in the front and the rear i needed 5mm spacers to make them flush... the offset is truly nothing hope this helps
Old Nov 7, 2010 | 07:22 AM
z32drifter's Avatar
looking back the shots above have 275mm tires, here are a few with different size tires. They rear is a 255/40, I can't recall the front it's either a 255/40 or 245/40.
Old Nov 7, 2010 | 07:34 AM
z32drifter's Avatar
the Murano wheels are 18x8 +35.
Old Nov 8, 2010 | 07:48 PM
taeng's Avatar
Z32drifter - what's suspension are you on? Do you have side shots?
Old Nov 9, 2010 | 04:53 PM
z32drifter's Avatar
My car is on S-techs and AGXs
This is what my car is on at the moment (different tires) 17x10s
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Pied
Sep 26, 2015 03:29 PM
