Changed Vacum hoses and then got a bad idle!!! Please Help!
Well I changed all the visible vacum lines and then fired her up and it idles rough and will sometimes bog down and the cut off!! on me
I did bump a few wires trying to install the new vacum lines but I dont think that would cause this!
BTW: The car had a smooth idle and would never die or cut of !!
I am so
ticked
Someone please help me figure this one out
I am so
ticked
Someone please help me figure this one out Thanks
Try cleaning the throttle body and iacv....Don,t use carb. cleaner...Only Throttle body cleaner..
http://www.motorvate.ca/mvp.php/518
You probably mixed up a couple of vaccum hoses. So now s/t is getting vaccum when it should't be, or vica versa. Check the EGR hose. At idle it should not have vaccum. If it does then you have to figure out which one it is mixed up with.
Originally Posted by seanneal
...Here are some diagrams so you can ...
Your problem is what u did =hoses... maybe now a IACV hose leak?
For small hoses, click: http://www.cardomain.com/ride/748507/3
I replaced all the hoses i could find but could have missed a few
I would like to get the vg engine vacum hose map if someone will please post it !
When I start the car it runs around 1000 rpms but if I rev it up the let the rpms drop they drop into the 600's Then when it strugles it goes to about 350-550 range then something must kick in and then the idle revs back up to 750-850.
What is kicking in to make the rpms jump?
When the car is running and I lean over and listen to the airbox side of the engine I can hear quite a loud air whistling noise (VACUM LEAK?) But I just changed the hoses and.......... most of them were cracked all over.
How could replacing old leaking hoses do harm to my engine ?
I dont think i could have mixed up the hoses because if memory serves me i took them off one by one!
Could my new vacum hoses be pulling a stronger vacum that now some other hose started to leak?
I really need to fix this thing because i need to drive this car!
Thanks Guys Keeep posting !!
The lines i replaced were only the small lines the 5 or 6 mm lines.
There were no lines that had clamps just simple push on vacum lines.
Does any body have the vg vacum line map
I read your page wiking and the page before and after but I still need some information! Thanks wiking
Thanks guys keep posting!!
Originally Posted by Maxima Man
... but I still need some information! ...
idle oscillation:
- IACV cleanup; detailed tHere
- TPS zero pos sw ok?; detailed tHere
- idle troubleshoot & some & all info; Favorite Links
map: each accessory is detailed separately plus semantics plus gallery pics
Check the Vacuum Hoses going to the Carbon Canister. The Loud whirring sound is probably one of those lines that came loose. It happened to me and took me quite awhile to find out what it was.
Hope this helps.
Hope this helps.
Is this canister under the batery in the vg engine bay?
I would like to see a vacum line map for the vg engine that way I can check all the vacum lines for leaks ! Please post the vg vacum diagram.............. Thanks so much
What is good to clean the trottle plate?
Will cleaning it strip the special oil film on the plate?
I was told it would be bad to lose this special film of oil!
Thanks so much ....Post please!
Go to wiking's home page for the vacuum hose diagrams..
Clean the throttle body and iacv with THROTTLE BODY CLEANER....Not carb. cleaner. There is no special oil film on the plate or anything else on the throttle body...Carburator cleaner is harsh on the aluminum....
Did you read this post and go the link???????
http://forums.maxima.org/showpost.ph...40&postcount=4
I read your links and posts guys lot of great info!
I was just trying to clear a few more things up
Thanks Guys !!!!!!!!!!!!!!!!!!
Is there any other vg vacum line diagrams I could get or someone has?
I want to check all my lines and make sure I replaced them all
Wikings are some what confusion lol !
!Wikings are some what confusion lol !
I read your links ...
- Yes, pics with txt from Maxima spaghetti & maximized confuzean FSM
- btw. FSM contains no maps, theyre for geologists. Thats why u cannot find em
Ok ... This weekend I am going to clean out the ivac and the egr valve and then check for any missed vacum lines and then fire it up and see if that fixes it !
I do read your posts man!
Believe me !!!
I like to learn .......
From you smart people before tearing into somthing ! LOL !
wiking=
Maxima man=
LOL Just Kidding....!
Believe me !!!I like to learn .......
wiking=
Maxima man=
.......LOL Just Kidding....!
Believe me !!!
I like to learn
f
Believe me !!!
I like to learn
fFrom you smart people before tearing into somthing !
10-4 I will do !
What do you recomend using to seal the ivac back up with ?
I don't have time to buy the proper gasket
Would some liquid gasket work or the like?
Thanks ........ Guys
Is there a easy way to clean the fuel injector connecter to be sure of a good contact?
Thanks guys !!
Thanks guys !!
Get a stiff bristle tooth brush and some electrical contact cleaner....and start brushing..
When I open open up the iacv is the ECU going to have to be reset or something like that?
The haynes said that the ECU would forget where the stepper motor was posistioned
Is this true ?
Or is it just if I had to disconnect it to replace the iacv with a new one
Thanks MyGreenMax !!!!!!!!!!!!
Is this true ?
Is this true ?
Is this true ?
.......Might want to ask wiking.....
...The haynes said that the ECU would forget ...
No IACV reset. Idle adj as manual suggests.
In a way ECU never 'forgets': it has -and never will- know about the stepper motor, but can it ? forget smtg which it has never known, dunno
'My' stepper motors have never had zero positions so far. (Floppy disks have one zero pos sw for home, but separate from stepper...) And max is no exception, its stepper is able to run into both valve ends. U can also do that if u care to read the IACV page, or the suggested manual...
ECU energizes stepper (runs IACV back &forth) to reach the rpm = sweet idle airflow = valve pos. YOU adjust that value into ECU with ECU potentiometer. ECU pulses stepper motor back &forth until that point is reached. This continous 'search operation' is the idle fluctuation felt always in maxima.
Thanks Wiking for the awsome info !
I will hack into it as soon as I can get my hands on a can of throttle body cleaner !
I have one (I promise) more question is the TPS extremly sensitive as to where it is located on the throttle body bolts? because I noticed that they have slop in them until you pick a spot and then tighten them down. ( I hope you get what I am saying )
Or is it not neccesary to remove at all?
Is it best to remove the part of the throttle body that houses the two butterfly plates
Or can you clean it just as well on the car ?
Thanks Guys props for Wiking!!!
...the awsome info !...
I'd say this forum is awesome, thks to ALL and everybody
TPS has zero pos sw, which has to open/close aroun 1000rpm. See page http://www.cardomain.com/ride/748507/6
Take TB out, in my case the last seal was misplaced causing input air choking... Removal does not add much more work there... Clamp /pinch first the TB heater hoses, then there will be no need to bleed the coolant.
When u have the plenum out, grind all extrusions left there.
lowpost99
Oct 26, 2025 06:53 PM
sdotcarter
Sep 2, 2015 09:53 PM
