TX FS: Used Suspension Tech sway bars front & rear
Part #52115
Just a few superficial scrapes on the front one, otherwise they look nearly new. Only on for 3-4k miles. I'm including a big tub of Energy Suspension poly grease.
$175 shipped, $125 local pickup.
Thanks, Mike
Thanks, Mike
Its not too bad to install, if you have air tools and a big jack that makes it a lot easier, especially in the rear, front is faster and simpler. No reinforcement of links needed as far as I'm aware.
The metal plates in the photos have to get sandwiched on the rear suspension, between the radius rod bracket and the strut housing, so you can tell from that what there is to take apart.
MaxStock
Aug 14, 2015 10:03 PM
