A33 rear sway bar on A32?
Old Aug 21, 2015 | 05:03 PM
ef9's Avatar
ef9
Anyone installed/added a rear sway bar from a 5th gen into the 4th gen?
I have a 5th gen parts car and was wondering if it's worth it.
Old Aug 21, 2015 | 05:07 PM
RA030726's Avatar
I'm nutty for Nissans
If it's a Stillen or Progress RSB then it should swap right over.
Old Aug 21, 2015 | 10:59 PM
ef9's Avatar
ef9
I am looking at the 1996 I30 FSM and the 2000 Maxima FSM and both don't come with a factory rear sway bar.
The 2000 Maxima parts car that I have had a Stillen front tower strut brace and I remember seeing a rear sway bar when jacking up the rear to swap the wheels. I thought the rear sway bar was a factory one.
I hope it'll swap over to my 1996 I30 as you say.
Will the 2000 Stillen front strut brace fit my 1996?
Old Aug 22, 2015 | 06:23 AM
dwapenyi's Avatar
This is weird...the 2nd time this has come up, but yes, the 4th and 5th gen have an OEM RSB built into the beam.
The factory OEM rear sway bar is not easily visible. It's a big bar inside the multi-link beam. What you were looking at was probably the aftermarket progress or Stillen RSB.
Old Aug 22, 2015 | 06:30 AM
aackshun's Avatar
You mean that large bar that's attaching both struts is a sway bar
That's crazy! That's like the definition of a sway bar man, no way, you're insane!!!
Old Aug 22, 2015 | 09:29 PM
ef9's Avatar
ef9
I removed the Stillen rear sway bar and installed it on my 1996.
I also swapped the Stillen front strut brace too.
Old Aug 22, 2015 | 10:23 PM
Fakie J Farkerton's Avatar
Anyone installed/added a rear sway bar from a 5th gen into the 4th gen? I have a 5th gen parts car and was wondering if it's worth it.
http://m.summitracing.com/parts/aco-...ma?prefilter=1
^^fits 95-01 so safe to assume it will fit.
You should probably buy new hardware and bushings for it while you're there.
Old Aug 27, 2015 | 07:21 AM
dwapenyi's Avatar
The Stillen RSB makes a nice upgrade to the OEM suspension. If your car is on H&Rs or Eibachs or any other aftermarket, lowered suspension, however, being careful taking hard corners. You will more fully understand when we say "the car has a hot tail" or "snap oversteer."
lowpost99
Oct 26, 2025 06:53 PM
matts95max
Apr 23, 2025 10:44 AM
flu2000
Sep 8, 2015 02:23 PM
A32goldylocks
Sep 2, 2015 06:39 AM
