Sub woofer line-level wiring and remote line
Old Apr 2, 2014 | 02:54 PM
JakeOfAllTrades's Avatar
Another member asked me about how I spliced into the Bose audio system in my 2009 maxima to hook up my aftermarket sub. Since I was taking the pictures anyway, I figured I'd share them with everyone.
Quick disclaimer: This is just the way I hooked my system up, I'm not responsible for anything that might happen to your car as a result of this post. These images are for reference only. If you don't feel comfortable with any of this, I'd suggest having it done by a professional.
I own a 2009 SV with nav and tech packages, wire colors may vary depending on year and packages.
I followed LVleo78's write up to install my system, so I won't go over all that stuff here again.
I installed a Sound Ordnance B-8P sub. It's an 8" sub in a bandpass box with a built in amp and line-level converter. I got it from Crutchfield for around $100.
For my particular car, here's the colors of the speaker hook ups:
Driver side rear deck speaker:
Pink = +
Blue = -
Passenger side rear deck speaker:
Brown = +
Red = -
Here's a picture of the location I made my splices:
To hook up the remote wire, I tapped into the remote wire for the bose amp. For me it was a green wire with silver stripes:
The green and silver wire was found in the harness that plugs into the passenger side of the bose amp (mounted to the underside of the rear deck between the 6x9's)
Finally, I opened up my sub and de-soldered the posts on the control **** for the "level" ****. I ran a thin wire back up to the front of my car and attached the **** in one of the open panels. I had to use a dremmel to clear out some of the plastic in the back side of the plastic panel I was installing the **** into, and then I used a center punch and drilled a hole in it from the back. Here's pictures of the whole setup.
Doing this allows me to control the "volume" of the sub while I'm driving.
Hope this is helpful. I'd recommend this sub. It's got a nice crisp sound that plays nicely with the bose system.
Old Apr 2, 2014 | 03:09 PM
Ghozt's Avatar
nice work with the sub gain ****! love it.
Old Apr 2, 2014 | 03:17 PM
Thanks brother. I did it as an after thought after driving around without any control for like a week.
Old Apr 2, 2014 | 05:13 PM
1996blackmax's Avatar
Great write up! I really like what you did with the remote gain.
Old Jan 14, 2020 | 03:54 PM
Justin@0310's Avatar
Pink = +
Blue = -
Brown = +
Red = -
Attachment 24358
Attachment 24359
Attachment 24360
Attachment 24361
Attachment 24362
Attachment 24363
how did you get the piece out that you installed the **** onto? I can’t get mine out
Jun 6, 2017 02:01 PM
trsandrew
17
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
doctorpullit
Dec 12, 2015 09:39 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
