1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
World's Fastest All Motor Maxima runs 11s! NEW VIDEO
Old 02-20-2014, 03:11 PM
NWP Engineering.com
Aaron92SE's Avatar
This past weekend, our 1992 Nissan Maxima set a new world record for the Fastest All Motor Maxima in the 1/4 mile with an ET of 11.97 @ 113.3mph! The world record we've had for years just got beat again! It feels good to be the first NA Maxima to bust into the 11s!
Aaron92SE is offline
Old 02-20-2014, 05:30 PM
LeGaspardVQ's Avatar
Congrats! Thanks for keeping the FWD VQ35 market alive
LeGaspardVQ is offline
Old 02-20-2014, 07:22 PM
SLOW
Nealoc187's Avatar
awesome. what 60'? and who is we?
Nealoc187 is offline
Old 02-21-2014, 04:17 AM
Turbo 3.5
t6378tp's Avatar
congraz
t6378tp is offline
Old 02-24-2014, 05:40 AM
jr schultz's Avatar
Very cool! Your car keeps getting faster and faster. Your continued dedication to the Maxima world is why I proudly display your company's sticker on my rear bumper.
jr schultz is offline
Old 02-24-2014, 07:42 AM
joesae01max's Avatar
NIIICE - Congrats
edit: gotta change the sig now
joesae01max is offline
Old 02-24-2014, 08:35 AM
NWP Engineering.com
Aaron92SE's Avatar
Thanks!
1.77 60'
We = NWP Engineering
Originally Posted by t6378tp
congraz
Thanks!
I appreciate all your support!
Originally Posted by joesae01max
NIIICE - Congrats
Thanks. Yeah, I do need to update my sig and replace that 12.04 ET. 11.97 sounds SO much better!
Old 02-24-2014, 04:04 PM
Rods03Max619's Avatar
Congrats Aaron...
Rods03Max619 is offline
Old 02-24-2014, 08:05 PM
NWP Engineering.com
Aaron92SE's Avatar
Congrats Aaron...
Thanks!
Old 03-02-2014, 12:36 PM
TurboA32's Avatar
Are you manually shifting an automatic?
TurboA32 is offline
Old 03-02-2014, 11:02 PM
Quickywd01's Avatar
I caught that in the video too, probably a suprastick.
Quickywd01 is offline
Old 03-03-2014, 06:23 AM
Turbo 3.5
t6378tp's Avatar
any updates from yesterday
t6378tp is offline
Old 03-03-2014, 08:35 AM
NWP Engineering.com
Aaron92SE's Avatar
On this particular day, I had to manually shift since my standalone transmission control unit (Suprastick) was not receiving a speed signal. When I converted over to manual brakes, I removed all the ABS sensors, including the one I needed to create the speed signal for the Suprastick. But I have since put that sensor back in and the tranny shifts automatically now at my specified shift points.
The full details are mentioned in my build thread here: http://forums.maxima.org/all-motor/5...thread-30.html
Please subscribe to this thread to get updates. I try to touch on every single thing I do to this car. No secrets are kept! I want to see other Maximas go fast even if it means me getting beat by one of them one day.
Yeap.
No new records. But I learned a lot about this new Edge Racing converter. Before the day was over with, I was able to achieve a 4500rpm launch. But I had to stall it up in 2nd gear so as to not overpower the brakes. Then, kick down to 1st gear when I launch. But since I had to manually shift to do all of this, it took me a couple passes to get a hang of things. By that point, the big slick cars have stopped running and the street tire guys were chewing up the surface. So I wasn't able to hook up with the 4500rpm launch. But when I do, I think that low 1.7s will be pretty easy to do. 1.6s are my goal though.
More details will be posted later in my build thread here: http://forums.maxima.org/all-motor/5...thread-30.html
Old 03-03-2014, 09:38 AM
Quickywd01's Avatar
I can't wait to see that, you do good work.
Old 03-04-2014, 12:10 PM
TurboA32's Avatar
So your best time was manually shifting an automatic just imagine if you were an actual manual I think you would get a better time
TurboA32 is offline
Old 03-04-2014, 12:20 PM
NWP Engineering.com
Aaron92SE's Avatar
Yes, my best time was when I manually shifted. But I only manually shifted because I absolutely had to. I had no other choice than to just go home. And manually shifting means that I am not hitting my perfect shift points every time. So, I could have shaved a half tenth or so if I was able to shift automatically with my calculated optimal shift points.
If I have a manual transmission, I would be able to lay down more power to the wheels, but it will be harder to launch consistently. Once I get some more tests under my belt, I hope to be able to repeat 1.6 60 foots every time. That's a hard thing to do with a manual transmission.
Old 03-04-2014, 02:11 PM
Quickywd01's Avatar
People need to realize, for drag racing, you can not beat an automatic with a manual. Have y'all seen them new transmissions that shift like superfast. GTR? BRZ? Even them fancy twin clutch DSG's. For driving pleasure you need a manual, but this is a drag car... Don't get mad at me turboa32. I've had two auto maxima's, now have a 5spd '97 SE daily driver, and working on swapping a 6spd into my "beast" '97 gle maxipad. Keep up the good work Arron!
Old 03-04-2014, 06:41 PM
krazy6's Avatar
It depends on the car and how well the automatic is built or what's controlling the shifts. My car is most definitely faster than an automatic 6th gen with the same modifications.
Most people can't drive a manual car to save their lives though so I would agree in almost every case lol.
krazy6 is offline
Old 03-05-2014, 09:32 AM
NWP Engineering.com
Aaron92SE's Avatar
Yeah, an automatic with the right torque converter can be every bit as fast as a well driven manual. But so far, that has not happened yet, not even with my car. A properly setup manual Maxima that weighs 2450lbs and is equally modded will be able to cut 1.7 60 foots all day long. And it will be able to lay down more WHP than my automatic.
What I'm hoping to do is achieve a similar 60 ft that my car would do if it was a well driven manual. But what I like is the consistency. And I haven't even found that just yet. But I'm getting close!
Old 01-08-2015, 10:37 AM
bk2k3max's Avatar
Awesome!!
bk2k3max is offline
Old 01-11-2015, 07:37 PM
aic96max's Avatar
awesome!!!!
aic96max is offline
Old 01-12-2015, 10:56 AM
NWP Engineering.com
Aaron92SE's Avatar
Originally Posted by bk2k3max
Awesome!!
Originally Posted by aic96max
awesome!!!!
Thanks guys!
Old 03-10-2015, 07:31 AM
Crusher103's Avatar
So here is the real question: When you gonna retune your fuel map for that nasty hole that's unloading in 3rd, maybe lengthen the injector pulse another milsecond, tune the NOS timing and run 9s?
Crusher103 is offline
Old 03-11-2015, 08:51 AM
NWP Engineering.com
Aaron92SE's Avatar
Old 03-13-2015, 02:02 PM
grksoccerkid91's Avatar
that's awesome! can't wait to see more updates.
Is there anyway to install a transbrake setup like the big power rwd cars? I'm not familiar with that setup at all.
grksoccerkid91 is offline
Old 03-17-2015, 08:33 AM
VQ Wizard
SR20DEN's Avatar
Great job man! Thank you for keeping the NA Maxima records in NC!
SR20DEN is offline
Old 03-17-2015, 11:41 AM
Crusher103's Avatar
^Wow a real live Unicorn has been spotted^
Old 03-17-2015, 11:57 AM
NWP Engineering.com
Aaron92SE's Avatar
I'm sure there is a way, but not that I have found with this Nissan transmission. So for right now, I have to rely on the flash stall of the converter I'm using at the time. If I had a transbrake though, I'd be able to launch at a much higher rpm with the same converter!
That is why I've messed around with stalling it up in 2nd gear, then kicking it down to 1st as I launch. That way, it doesn't overpower the brakes. But I would LOVE a transbrake in this car!
Thank you. Long time no hear! I hope you are doing well.
Old 03-21-2015, 06:39 AM
aackshun's Avatar
Late to the party.
First hand experience, this guy shifts like a mad-man. Almost equivalent to that Mexican fella w/ the turbo max making Porsche sammiches.
aackshun is offline
Finkle
09-27-2015 09:53 PM
acw
08-13-2015 12:50 AM
spidgeon
08-09-2015 09:26 AM
MikesChevelle
08-06-2015 11:36 AM
silver_i35
08-03-2015 11:20 PM
Quick Reply: World's Fastest All Motor Maxima runs 11s! NEW VIDEO
