Transmission swap information needed--please
I have to replace the automatic in my 85 Maxima. What other transmission(s)will fit, with what mods? This is urgent. I asked some questions before and got nada. I have a decent home shop and access to several boneyards. This early series 85 Maxima automatic transaxle is not very good. I want to put a later model one in it. Does anybody know anything about Maxima transmissions.
Re: Transmission swap information needed--please
The best bet would be a good 5-speed manual box out of a 3rd gen (89-94) Max. This does require some fabrication to install, as there are different mounts, etc...but it is possible, as Maxima86SE has had it done. If you want the easiest way out, find a 5-sp 85-88 Max in a bone yard, and buy EVERYTHING (might be easier to buy the whole car, to use as a donor...) - clutch assembly, M/C, line, S/C, tranny, flywheel, front cross member (it's different between the 5-sp & the auto), the linkage, the shifter, and the interior finishing pieces and boot for the console. You may also want to swap the ECU. Not sure if it'll make a huge difference, but I know the timing curves, etc..., are a tad different between the two computers...might make a big difference.
Re: Re: Transmission swap information needed--please
Originally posted by MaxWgn
Basically, the entire line of auto slush-a-matics in the Max series blows chunks. Some tend to be better than others, but in general, they are quite problematic.
Re: Re: Re: Transmission swap information needed--please
Yeah I agree about the automatics, I put five in my first 85 Maxima, over 160-odd K miles, but I punished it playing with V8s. I put a 2700 actual miles Z31 motor in it at 120K. I rolled it a couple of years ago. This one is ready for its second, I bought it needing one. It runs fine in first, second, and reverse, and has been doing that through two previous cheapo owners I know. I gave $300 for it. The body is pretty good and I put the interior from the first one in it. The thing is, my wife likes automatics and these are pretty stout cars if wrecked. I also like the 85 because it does not have those automatic seat belts.
Good luck!
Sarin
The Max Manual trans, RS5F50A, are seeming hard to find. Will any of the other Nissan models match up RS5F50 (C) (V) (Y)? I am swapping auto to man, so I need the crossmember, pedal..... Wish I could find a 85-89 Max. Trying to widen my net.
sctludwig
09-01-2022 01:32 PM
03-12-2020 12:06 AM
James92SE
10-08-2015 04:57 PM
The Wizard
24
10-01-2015 08:47 PM
