Injector question
Old 06-26-2016, 11:44 AM
Michael Stibbard's Avatar
Injector question
Just bought my baby back for the 5th time. Gonna build her this time. What are my options for bigger injectors? I have a 92 se, just wanna know what would be compatable with the VE motor. Any input is appreciated
Michael Stibbard is offline
Old 06-26-2016, 05:16 PM
Jesus was a Zombie.
BenStoked's Avatar
Stock ecu, stock injectors. Piggyback, nistune, or standalone will get you bigger.
Stock injectors are side-feed, unless you get or make an aftermarket fuel rail.
BenStoked is offline
Old 06-27-2016, 10:20 PM
No turbo, no care!
Maxpwer's Avatar
Actually I've found an easy way to use cheaper and better top feed injectors vs expensive side feeds. A VQ35 injector rails lines up perfectly with our injector bosses. Weld two L shapped brackets to each side to match up with bolt holes in the intake manifold. Cost me $30 total and 6 top feed 550cc injectors can be had for $300.
Maxpwer is offline
Old 06-28-2016, 05:50 AM
Ad·min·is·tra·tor
DanNY's Avatar
does it clear the stock intake manifold?
DanNY is offline
Old 06-29-2016, 11:01 PM
No turbo, no care!
Maxpwer's Avatar
P
The latest ( last I checked) Bosch EV14 injectors come in 40mm, 48mm and 60mm. A stock injector is around 58mm and I'm fairly certain aleast the two smaller EV14s will fit with a stock intake manifold. A pathfinder manifold gives you a little more room.
Here is a link to Deatschwerks 40mm top feed 700cc injectors, $369 for 6.
http://www.deatschwerks.com/products...-0065-6-detail
You are only limited by knowledge.
Edit: Do you're own research on the quality of the EV14s, I've read they are top of the line a few years ago but opinions and experiences may have change since the last time I did research
Maxpwer is offline
Old 06-30-2016, 06:15 AM
Ad·min·is·tra·tor
DanNY's Avatar
ahh man where were you when i was shopping for 550s? this is good to know...i'll keep that in mind if/when the side feeds i have goes.
DanNY is offline
Old 07-05-2016, 08:14 AM
TonyJr's Avatar
94-96 q45 infinite fits there 370cc
Of course sr20det, 300zx tt also fits and there 370cc also..
TonyJr is offline
MagikHype
20
08-26-2016 07:36 AM
frank5079
06-24-2016 11:58 AM
hacura3000
06-23-2016 03:59 PM
collije
06-20-2016 03:02 PM
BGTONIO1991
06-01-2016 03:39 AM
Quick Reply: Injector question
