MAF, TB, IACV, and EGR cleaning for dummies
Old 05-06-2011, 04:44 PM
  #81
speedvision's Avatar
just did mine
just did my maf, iacv, tb, and egr tube. Whew. what a pain. Feel very cool now knowing all that nastyness isnt there anymore, also adjusted idle... purrrrr's like a happy kitty alright. (on my 98 gxe max auto 175k)
($15 - maf cleaner/ tb cleaner/ carb cleaner -$5/ea)
+1 everyone who hasn't should do this.
+1 Thanks for the Great Tutorial ! ! ! Excellent job!
speedvision is offline
Old 05-16-2011, 06:54 PM
  #82
sanchalanam's Avatar
Thank you for all the pictures and info. My car was stalling almost at every traffic light. After i cleaned MAF, IACV, TB on my 96 Maxima, stalling problem is completely gone. However, Check engine Light came back for KS & IACV (code 34 & 25). I reset Check Engine light multiple times but its back again after few miles. Can I ignore IACV code as my Maxima is not stalling any more?
Thanks for any suggestions.
Sanchi
sanchalanam is offline
Old 09-02-2011, 09:27 AM
  #83
domano 68's Avatar
Just cleaned my MAF, TB and new plugs in my 99 with 70k miles. Did this due to stalling at stop lights. It still is stalling.
I did not take the MAF out of the maf tube, just pulled the maf tube out of the car and sprayed the MAF with CRC from both ends. I have searched for pics here of the MAF cleaning process and have found none. Do I have to pull the MAF out of the tube to spray with CRC? Just wondering here if I did not do a good job of cleaning the MAF.
So if maf was cleaned correctly what else can i look into, pcv? TIA!
domano 68 is offline
Old 09-06-2011, 02:49 PM
  #84
Caticorn's Avatar
The MAF doesn't come out of the tube. You just do it like this.
I did it once, and it fixed my problems temporarily, but my loping/stalling/hesitation slowly came back, so I did it again and it fixed it, but even more temporarily. I eventually had to replace the MAF and now it's gone for good.
You might be ready to throw in the towel and get a new MAF, but be absolutely sure it's the cause before doing so. 70k seems pretty early for the MAF to go out. Have you done the EGR and IACV?
Caticorn is offline
Old 09-06-2011, 03:11 PM
  #85
chico102388's Avatar
i already did the TB and MAF now i have to find time to clean the EGR awesome write up.
chico102388 is offline
Old 12-16-2011, 05:39 PM
  #86
acvc's Avatar
IACV
I've got the IACV code on the ck engine. I took it off today and cleaned it good according to previous post. The ck engine light and same code still returns . Any suggestions?
acvc is offline
Old 12-27-2011, 09:40 PM
  #87
browne's Avatar
great write up.. wish i saw this earlier. i just cleaned the throttle body and maf but didnt know where the iacv was.
do i need to take the whole throttle body out to get to the iacv or can i unplug the 3 socket and 1 vacuum tube and then unscrew 3 bolts thats holding the iacv???
browne is offline
Old 12-28-2011, 04:01 PM
  #88
nab911's Avatar
I just got a 95 se and it runs perfect except on start up. Right after cranking I have to blip the throttle and then it runs great. I just seafoamed but might try cleaning some of these pieces (brand new MAF so no need to go there) and see if I can't help it out.
nab911 is offline
Old 12-30-2011, 05:43 AM
  #89
browne's Avatar
i'm not sure if it was cleaning the maf or tb or both but my car starts a lot better. i was having trouble starting in cold weather but now it cranks pretty hard. my idle is also hovering around 700-800 before it was around 600.
browne is offline
Old 12-30-2011, 11:55 AM
  #90
ddcoons's Avatar
I spent what seemed like hours trying to get the carbon out of my EGR tube. I used carb cleaner, wires, pipe cleaners, degreaser, water and nothing would budge the gunk in the middle of the pipe which was just out of reach. I even let it soak overnight with no apparent improvement.
Actually, my tube became more thoroughly clogged with my attempts to clean it.
So it occurred to me that perhaps oven cleaner might help. I got a cheap can of cleaner at the dollar store ($1). I sprayed as much as I could into the tube on both ends, then I set the tube in the oven and ran the oven through a cleaning cycle.
After this, I was able to break loose the carbon in about 10 minutes.
ddcoons is offline
Old 01-01-2012, 01:27 PM
  #91
95max87's Avatar
Thank You for this thread. I know I am posting on a kind of old thread but I just started having the same problem on my 95 max. The pic by pic is a great way for people to follow along. will post results when I am done.
95max87 is offline
Old 02-26-2012, 08:30 AM
  #92
Darkstonian's Avatar
Great write up man, after lurking here for a year, I finally tackled this job for my 98 I30. PITA for the hacking, and removal of that 1 bolt. 1/8th a turn took forever, lol. Though for you guys that do plan on it, remember to clean out the hole that the egr guide tube connects to the throttle body. That was completely blocked as well. It's like a little bowl, so now I see why it clogs like that. the end of a wire hanger and a small screwdriver worked best for me. I also used a can of compressed air to blow the carbon deposits out after I loosened them. I was lazy, I just bought a brand new guide tube for 30 bucks from the dealer. Runs smooth as butter now @ 170k, and idles quiet. Long live the I!!
Darkstonian is offline
Old 02-26-2012, 10:28 AM
  #93
lyhnedk's Avatar
nice write up... i will be doing this to mine after i have seen this
lyhnedk is offline
Old 05-17-2012, 09:05 AM
  #94
seoulfulwon's Avatar
I can't see any of the pics; even from the printable version, the links are not displaying an image. Does anyone have these pics or is there another way to see them? The write up is great, but I would like to have the images to ensure that I'm performing this properly. Thanks
seoulfulwon is offline
Old 06-02-2012, 08:12 AM
  #95
Cebby's Avatar
I need these pics also. Throwing P0400 & P0325 codes. Heard that the KS code is a ghost so I just need to clean my EGR guide tube to fix. Need to do this for inspection!!
Cebby is offline
Old 06-03-2012, 07:27 AM
  #96
carsnwomen91's Avatar
Originally Posted by mikeg75
I took out my throttle body today and cleaned it, thanks to this post. I would never have had the nerve to do this without the pictures and the play-by-play. Thanks a lot.
I didn't have time to do the IACV or EGR (new ebay $95 MAF is on order). Can I leave the throttle body on next time I go in there to do the rest of this?
i hope you don't run into problems with the ebay maf... just go the the junkyard and yank an oem one off. should be around $50
carsnwomen91 is offline
Old 08-18-2012, 04:29 PM
  #97
ash0621's Avatar
Originally Posted by 96i30azn
I cleaned my maf, tb, iacv, and egr guide tube last week after some extensive research here on the org. I felt like none of the threads included directions for a total newb to do everything. Doing everything at the same time makes sense b/c if you're gonna get to the egr, might as well attack everything else while you're at it so here it is. My car is a 1999 Infiniti i30t, your car might vary slightly in terms of hoses, tubes, and plugs.
1st off, what you're gonna need:
Tools:
- 3/4 racket
- 8, 10 socket wrenches
- 3" and 6" socket extensions
- 12mm deep socket
- 12mm box end wrench (for getting at lower rear nut of egr guide tube
- Flat screwdriver
- Pliers
- paperclips - the type that is in an "X" since they're the biggest
- Large phillips screwdriver
- Hacksaw blade
Consumables:
- Lower EGR guide tube gasket part # 14722-38u02 $5.86 (Connell Nissan prob rip me off)
- Upper EGR guide tube gasket part # 14722-38u01 $3.75 (@OC Nissan in Garden Grove)
- IACV gasket part # 23785-AD100 $3.88
- TB gasket part # 16175-31u01 $3.65
What they look like
The brush is a heater chute cleaner, but I didn't know the EGR guide tube was only the size of a finger
here's a picture of the engine bay labelled for future reference
Steps - airbox:
- use 10mm box ends to remove Neg battery terminal and then positive
- disconnect MAF
- detach hoses on airbox (next to the "MAF sensor" label in pic)
- Undo the 4 clips holding the box w/ the air filter not shown in pic
- use pliers to slide airbox hose clamps off - squeeze them all the way will make them slide a lot easier
- Pull of the 2 big hose and a small hose (tubing really)
- Loosen the big hose clamp next to the throttle body
- Lift airbox out
It should look like this:
notice you can see one of the large airbox hoses and the rubber tubing
WHERE ARE THE PICTURES
ash0621 is offline
Old 08-27-2012, 12:46 PM
  #98
mikeg75's Avatar
The ebay MAF I bought in Jan 2010 to fix the stalling issue I was having at that time gave out a month ago, and horrible stalling ensued. Luckily I had the original MAF in the garage and just cleaned it and put it back in. It ran 100x better but with some hesitation and occasional stalls with the original MAF put back in, so I ordered a new ebay one, this time for $45 vs $95 for the other one. The stalling is completely gone now but it still has some hesitation, so next weekend I'm going to take out the TB, IACV and EGR tube and clean everything up. I've got all new gaskets and to save time, I bought a new EGR guide tube so I hope this job is relatively painless and fast, once I start it.
I'll post back once I've done the job, to relay the results.
Thanks again to the OP for the informative step-by-step and to JHolley re-posting the pictures.
mikeg75 is offline
Old 08-27-2012, 01:21 PM
  #99
dwapenyi's Avatar
Maybe you should try this first;
http://forums.maxima.org/5th-generat...troke-oil.html
dwapenyi is offline
Old 08-27-2012, 06:47 PM
  #100
richard.miller11's Avatar
I was looking to clean my IAC valve too. Is there a way you can fix the images I can not see the images you posted.
richard.miller11 is offline
Old 08-27-2012, 06:53 PM
  #101
never mind, after I registered I can see the images on the last page. Sorry.
Old 08-29-2012, 12:56 PM
  #102
Mod her. Ate her.
phenryiv1's Avatar
First post fixed.
phenryiv1 is offline
Old 08-30-2012, 07:19 PM
  #103
mikeg75's Avatar
Originally Posted by dwapenyi
I'm planning on tackling (attempting) this project on Saturday since I already have all the parts but I will also be picking up some of the 2-cycle marine oil additive as that sounds promising as well.
I hope to get the slight hesitation on accelerating to go away after I clean the TB and IACV, and put in the new EGR guide tube I bought. I'm going to clean out the orifices and vacuum out the crud after scraping them. My only concern is that the studs attaching the EGR guide tube on the bottom, get stuck, like some of the recent posters have mentioned.
mikeg75 is offline
Old 09-01-2012, 06:10 PM
  #104
mikeg75's Avatar
Holy shnikies was this a difficult project!
Started at 8 am, finished at 8 pm, but halfway through, I was ready to quit before even removing the EGR guide tube, which to me, would make the project a fail. The EGR-BPV and the EGR valve being in the way make this job really hard. I ended up leaving both more-or-less in place, and working around them. I used a piece of plywood to lay flat and saw off the end of the stud on which the nut for the lower right EGR guide tube is attached, but I had to constantly flip back and forth from using the plywood to going at it from the driver's side. A lunch break and reviewing a couple threads on here gave me the courage to start taking off the EGR guide tube bottom nuts. Once I got them to break free, I committed to finishing the job.
Without taking the car for a drive, I can say that the idle seems more solid. When I put everything back together and started her up in the driveway, it idled at 900 vs 650 RPM prior to the job, so I adjusted it down to around 650 or so. I haven't had the chance to take her for a test drive but I'm confident that this effort made a difference in how my car idles, and I bet it will save gas now that the idle has been adjusted down.
I'm planning in putting a little 2-stroke marine oil which I just picked up yesterday at Walmart to see if it lowers the amount of noise I hear at idle but I can already tell that the stick shift seems to vibrate the way I remember when the car was new to me, in 1999 (4 yrs old at the time).
My joints ache more than anything else, from the constant shifting around.
mikeg75 is offline
Old 09-01-2012, 06:46 PM
  #105
ShocknAwe's Avatar
lol congrats on a DIY completed! Instead of 2 stroke I would use MArvel Mystery oil.
ShocknAwe is offline
Old 11-24-2012, 09:55 PM
  #106
ck1995's Avatar
To make using the hacksaw blade easier, I used a leftover pull handle from an lawnmower pull cord. I shoved one end of the hacksaw blade into the pull handle and was able to use that as a handle for the hacksaw blade. Made it a lot easier to use and only took a few minutes to saw the bolt off.
ck1995 is offline
Old 01-08-2013, 04:12 PM
  #107
72240z's Avatar
Awesome write up... I have to be honest guys, my Maxima and I have nearly parted ways a few times. It's not her fault, a teenager took the best years from her. He abused her for years and then he was ready to send her to be `picked a part` in some desolete South Dallas junkyard.
Ok, so all we need now is a new movie titled, `Les Misarables de Maxima `...
Feel good maxim.org ... this forum helped `impove her quality of life` ...
72240z is offline
Old 03-03-2013, 09:39 AM
  #108
signals's Avatar
I am having aweful time getting bpt valve (with two screws on top and a bottom connecting nut) out of the way to access the bottom nut holding thr agr guide tube. How come no one has encountered this among many obstacles to reach to the bottom nuts og the egr tube? I am desperate. Can some one please clarify clearly step by step? I have removed both the screws on top and the bottom nut attaching the bottom bent tube. The assy still does not move away. What is holding it?
Thank you guys
signals is offline
Old 03-03-2013, 10:53 AM
  #109
dwapenyi's Avatar
Thank you guys
When you're doing the EGR tube, you should leave the 2 top nuts in and first saw off the stud of the the non-threaded part of the bottom to get the bottom nut off.
From the instructions.........
EGR guide tube removal:
- Unclip the large coolant hose clip (2 pictures up) with a flat head screwdriver
- Locate EGR guide tube - it is attached to the plug whose bracket you just removed
- Locate the lower rear stud of the EGR guide tube not be confused with the EGR tube that is located forward left of it
- Hacksaw the non-threaded part of the stud off (you need ~ 3mm off of it to get egr guide tube out), this is for me the most painful step as I had to do it with a hacksaw blade - can't fit a whole hacksaw in there
- leave the 2 upper EGR bolts alone - it'll make removing the lower ends easier
- Get in with your 12mm box end to undo the nut - you'll likely only get one wrench tooth position's worth of rotation each stroke but it comes out fast, you can turn it with fingers
- Carefully remove the nut and 2 washers 1 by one as not to drop it
- Use your 12mm deep socket to remove front lower nut of EGR guide tube
- Also remove the nut and 2 washers one by one
- Use your 12mm socket to remove the 2 upper bolts of the EGR guide tube
- Pull EGR guide tube off
- Remove gaskets with flathead if needed - my lower one was quite stuck, spray it w/ carb cleaner
dwapenyi is offline
Old 03-13-2013, 08:43 PM
  #110
signals's Avatar
Some missed steps in the write up?
[QUOTE=96i30azn;7085286]I cleaned my maf, tb, iacv, and egr guide tube last week after some extensive research here on the org. I felt like none of the threads included directions for a total newb to do everything. Doing everything at the same time makes sense b/c if you're gonna get to the egr, might as well attack everything else while you're at it so here it is. My car is a 1999 Infiniti i30t, your car might vary slightly in terms of hoses, tubes, and plugs.................
Very good write up and tips! Unfortunately, no one has mentioned solutions to unexpected problems and difficulties that I encountered with my 97 maxima which is similar to infinity 4th gen. Here are the problems:
1. How to remove the coupled plugs (gray plastic housing) mounted on a bracket that is bolted to the IACV. Unbolting the brkt is quite tedious! Is there a trick to slide out the gray housing from the bracket without having to remove the brkt?
2. Some of the hoses are impossible/ hard to pull out (of course after sliding out the clamps), especially from the tubes with two expanded collars at the end! I am still struggling with the lower of the two hoses (in the picture they are shown as close together one below the other- top one goes to fuel filter can)! Is there some trick to pulling them out some what easily? Cant get any leverage with a flat head screw driver to push the end of the hose out of the tubing's 1st "collar"! These hoses are obstructing access to the upper bolt of the bottom part of the guide tube.
3. There is a bent tube below the BPR valve that obstructs access to the upper bolt of the bottom part of EGR guide tube. How to move this tube away?
I guess after these difficulties are resolved I would be on the home stretch
Would some one please illustrate the solutions? Thanks a lot! Item # 3 is the worst problem!
signals is offline
Old 03-13-2013, 08:49 PM
  #111
signals's Avatar
Oops! I meant item #2 is the worst problem!
[quote=signals;8748386]
1. How to remove the coupled plugs (gray plastic housing) mounted on a bracket that is bolted to the IACV. Unbolting the brkt is quite tedious! Is there a trick to slide out the gray housing from the bracket without having to. remove the brkt?
2. Some of the hoses are impossible/ hard to pull out (of course after sliding out the clamps), especially from the tubes with two expanded collars at the end! I am still struggling with the lower of the two hoses (in the picture they are shown as close together one below the other- top one goes to fuel filter can)! Is there some trick to pulling them out some what easily? Cant get any leverage with a flat head screw driver to push the end of the hose out of the tubing's 1st "collar"! These hoses are obstructing access to the upper bolt of the bottom part of the EGR guide tube.
I guess after these difficulties are resolved I would be on the home stretch.
Would some one please illustrate the solutions? Thanks a lot! Item #2 is my worst problem!
signals is offline
Old 03-14-2013, 05:02 PM
  #112
wxm
wxm's Avatar
I thought I read somewhere on this board that the hacksaw can be avoided. Was I dreaming or can some one confirm it?
wxm is offline
Old 03-14-2013, 07:27 PM
  #113
signals's Avatar
Project w/o hacksaw
yes, some one in Marktab's thread said that he worked from underneath the car, loosened the 30mm nut and could move the obstructing pipe away a bit to let the nut (lower part of ERG guide tube) come out.
signals is offline
Old 03-23-2013, 06:01 PM
  #114
BobMax's Avatar
Thanks to the OP - Just did the TB and IACV. I think I've cured my cold start idle problem. I'll need a few more starts to confirm.
One addition on cleaning the IACV - after removal clean the manifold surface, inside the manifold opening, and the surface of the IACV.
Then you need to clean the actual valve. Remove the two screws on the backside of the IACV that hold the valve in place in the unit (not the three that hold the electrical unit on, you don't want to disassemble that). Pull the mechanism out, and clean inside there. There's a conical valve plunger that needs to be cleaned as well as the seat it closes against. That's the actual valve. Mine had lots of goo on it, and the car only has 90K miles.
Be sure to loctite the three screws holding the cover mentioned in the original posts back in - wouldn't want one coming loose in the manifold and getting sucked in.
BobMax is offline
Old 04-02-2013, 07:30 PM
  #115
xplicitMAX's Avatar
quick question, got a code for a KS and EGR regular flow, so assuming i should prob clean my EGR. Should i also clean the MAF, TB, IACV along with the EGR?
xplicitMAX is offline
Old 08-14-2021, 07:05 PM
  #116
AMnissan's Avatar
IACV:
- Remove the 3 electrical (in my case) plugs to the IACV
- Remove bracket that holds the rearmost plug
- screw bolt back on IACV to prevent loss
- use 12mm sockets to remove the 3 bolts that hold the IACV
- Pull IACV off and remove gasket if it sticks
Your engine bay should look like this now
Here's a pic of how I attacked the lower front nut of EGR guide tube
any way to remove the egr bottom nut without the hacksaw?
AMnissan is offline
Old 08-14-2021, 07:37 PM
  #117
JvG
JvG's Avatar
[QUOTE=AMnissan;9240088]any way to remove the egr bottom nut without the hack saw.
Nope.
the hack saw is the only way.
We don't use this method for fun or because we get off on masochism and pain.
It's because we have to.
JvG is offline
Old 08-15-2021, 07:40 AM
  #118
AMnissan's Avatar
[QUOTE=JvG;9240089]
Nope.
bet. Thnx
AMnissan is offline
TallTom
50
07-08-2022 09:54 AM
04-16-2020 05:15 AM
BobTX10
10-07-2015 08:43 AM
fx4five
10-01-2015 04:58 AM
Quick Reply: MAF, TB, IACV, and EGR cleaning for dummies
