How To: 4th Gen Plug and Play Interior LED Thread
Old 09-15-2011, 08:15 AM
tigersharkdude's Avatar
1. Disclaimer - I am not responsible for any damages that may occur during this mod. If you don't know what you're doing, DON'T TRY IT. Use the write-up at your own risk!
2. Supplies –
· Tools –
  1. Phillips Head Screw Driver
  2. Thin flat head screw driver
  3. Plastic Trim removal tool
  4. Extending magnetic pickup tool
  5. POSSIBLY 10mm socket and ratchet
  6. POSSIBLY a headlamp light
· LED’s -
  1. Map Light - 20 SMD LED Panel with a BA9s Adapter(can be purchased from your choice of supplier, I prefer ebay because they tend to be just as good and are usually $2-3 each)
    >> Cars with 2 Map lights will need TWO 12 SMD LED Panels and 2 BA9s adapters (can be purchased from your choice of supplier, I prefer ebay because they tend to be just as good and are usually $2-3 each).
  2. DOME Light - 36 SMD LED Panel with a Festoon Adapter (can be purchased from your choice of supplier, I prefer ebay because they tend to be just as good and are usually $2-3 each).
  3. Door Courtesy Lights - 2 x 12 SMD LED Panel and 2 T10 adapters(can be purchased from your choice of supplier, I prefer ebay because they tend to be just as good and are usually $2-3 each).
  4. Cluster Bulbs -
    **95-97 cars - 5(five) T10/194 bulbs (can be purchased from your choice of supplier). For these I recommend that you use at least 5+ SMD LED’s because if you use something with one LED it will look awful and have a huge hotspot.
    **98-99 cars - 5(five) NEOx 5mmbulbs ($2.29 each http://www.superbrightleds.com/morei...panel-led/221/)
  5. ACC Bulbs
    THESE ARE ONLY FOR DIGITAL UNITS. NEOx 4mm bulbs ($2.29 each http://www.superbrightleds.com/morei...panel-led/221/)
    I am working on finding the information for other units.
  6. Vanity Mirror Bulbs - 31mm Vanity 3 SMD LED bulb xenon white ($2.49 each http://www.wardenjp.com/stores/festoon.html) or from your choice of supplier)
  7. REMEMBER that there are several types of LED panels that are available to purchase, 5050 SMD LED are one of the brightest options that you have. Also remember that LED’s come in a wide array of colors, be sure to always check that the LED that you are looking at is the correct color that you want.
· Time -
  1. Map Light – Approximately 5 minutes
  2. Dome Light – Approximately 5 minutes
  3. Door Courtesy Lights - Approximately 5 minutes
  4. Cluster Bulbs – Depending on your level of experience 30-60 minutes
  5. ACC Bulbs – Depending on your level of experience 30-60 minutes
  6. Vanity Mirror bulbs - Approximately 5 minutes
· Space –
  1. You can swap pretty much everything from sitting in the front seats. I took the ACC in my garage when I swapped those bulbs as there are 4 small screws that I didn’t want to lose.
3. Installation
Map Light
*****Installation of the Map light is fairly straightforward
Some cars have 2 Map lights for those you will need to remove/install both sides
  1. Step One - Use your trim tool to remove the lense(s) from your Map light. This is done by inserting the sharp/pointed end of the tool into the grove near the front of the lense(s) and popping the lense out
  2. Step Two - Remove the old bulb(s). This is done by grasping the bulb(s), push down/in, and rotating counter clockwise and pull it out.
  3. Step Three - Installing the LED(s) is fairly simple. For the cars with 2 bulbs, the map lights will be plug and play. But the cars with one map light, they are trickier. Because of the way that the Map light bulb-base is wired, you can not simply plug in a standard LED bulb and expect it to work. I opt for LED board(s) that have a wired connection between the bulb-base and the panel. To make the LED board(s) light up you will need to connect the connection like so ..
    Positive>>>Negative
    Negative>>>Positive
    This will need to be done because Nissan wired the bulb-base in “reverse” and not what is commonly used. IIRC, Instead of getting power from the center contact, it gets power from the socket wall. And visa versa for the ground. Connect the LED board to the BA9s adapter and plug the adapter into the bulb socket (insert the adapter into the socket, push it in and turn clockwise [so that you lock the adapter in place]).
  4. Step Four- If the panel is not lighting up when you plug the LED board in and press the “on” button, then you will need to remove the bulb base and turn it 180° as the socket is polarized and will only work in one direction. *** Note if you have followed all of the above steps and the LED board is still not working, check to see if your Interior Illumination fuse has popped.
Dome Light
*****Installation of the Dome light is fairly straightforward
  1. Step One - Use your trim tool to remove the lense from your Dome light. This is done by inserting the sharp/pointed end of the tool into the grove near the front of the lense and popping the lense out
  2. Step Two - Remove the old bulb. This is done by grasping the bulb, and rotate it counter clockwise and pull it out.
  3. Step Three - Installing the LED. First connect the LED panel to the Festoon adapter. Unlike the Map light, this is simply plug-and-play (+ to +, - to -). Connect the LED board to the Festoon adapter and plug the adapter into the bulb socket (squeeze the adapter together and plug it into the socket)
  4. Step Four- If the panel is not lighting up when you plug the LED board in and turn it “on”, then you will need to remove the festoon adapter and turn it 180° as the socket is polarized and will only work in one direction. *** Note if you have followed all of the above steps and the LED board is still not working, check to see if your Interior Illumination fuse has popped.
*****Installation of the Door Courtesy Light (DCL) is fairly straightforward
  1. Step One - Use your trim tool to remove the lense from your DCL. This is done by inserting the sharp/pointed end of the tool into the grove near the front of the lense and popping the lense out
  2. Step Two - Remove the old bulb. This is done by grasping the bulb, and pulling straight out of the socket
  3. Step Three - Installing the LED. First connect the LED panel to the T10 adapter. Unlike the Map light, this is simply plug-and-play (+ to +, - to -). Connect the LED board to the T10 adapter and plug the adapter into the bulb socket.
Cluster Bulbs
*****Installation of the gauge cluster bulbs is fairly easy, but can be tedious if you have never removed the cluster before. I will say this, be sure to keep the screws in a “secure” place, such as a zip-lock baggy.
  1. Step One. Remove the knee bolster from under the steering wheel (two screws will need to be removed, the fuse panel cover, and one electrical connector once you pull the knee bolster down)
  2. Step Two. Remove the steering column cover (There are 6 screws that are accessible from the bottom of the cover). If you can not access the two screws that are farthest back you may need to remove the metal "cover" that is in the way. This is done by removing the two 10mm bolts and the "cover" should come right off.
    Step Two ˝ . Now open the lever on the driver side of the steering column so that you can lower the column down as far as it will go.
  3. Step Three. Remove the gauge cluster trim CAREFULLY SO AS NOT TO BREAK IT (there are two screws on the top of the bezel and 3 electrical connectors which need to be "un-clipped" in order to remove the bezel)
  4. Step Four. Next, there are 3 screws that hold the cluster in place. Remove those screws
  5. Step Five. Next, slide the cluster out. There are 3 electrical plugs in the back of the cluster that will need to be "un-clipped"
  6. Step Six. Once the plugs are "un-clipped" pull the cluster out and you will see the 4 main bulbs on the back side (pic below)
    Step Seven. At this step you will be installing the bulbs. Do note that 95-97 cars use different bulbs that 98-99 cars
    95-97 cars/Analog odometer- Remove the 4 main bulbs (they will be larger than the other bulbs), this is done by twisting in a counterclockwise motion and pulling the “socket” out. Now remove the bulb from the socket and insert your car T10 LED bulbs.
    98-99 cars/Digital odometer - Remove the 4 main bulbs and the odometer bulbs, this is done by twisting in a counterclockwise motion and pulling the “socket” out, and put the 5(five) Neo-5 bulbs in the cluster, this is done by inserting the Neo-5 bulbs and turning them with a small flat-head or small phillips head screwdriver).
  7. Step Eight. Take the cluster back to your car and connect the electrical plugs in the back and plug the dimmer switch (on the bezel) back up and test your cluster bulbs. I found a good method of testing these (if it is daytime and you are outside), throw a dark blanket or jacket over you and the gauge cluster and lean close to the close to the cluster and turn the gauge lights on.
  8. Step 9. If any of your bulbs are not working you will need to turn them around, as they are polarized and will only work in one direction
  9. Step Ten. Once all 5 bulbs are working, reassemble everything and enjoy what you have accomplished.
98-99 cluster with COOL WHITE bulbs
98-99 cluster with RED bulbs
ACC bulbs
*****Installation of the ACC bulbs is a little harder than any of the other swaps mentioned in this How-To. It can be tedious if you have never removed the ACC. I will say this, be sure to keep the screws in a “secure” place, such as a zip-lock baggy.
  1. Step One. Remove the waterfall section (shifter trim, AC vents and radio/ACC unit). This is very straightforward, if you need more descriptive information refer to this link …................. (insert link)
  2. Step Two. Remove the ACC by disconnecting the two grey plugs, one white plug and the hose that is attached and the 4 screws holding the ACC in the radio brackets
  3. Step Three. Once the ACC is removed, you will need to remove the faceplate (attached with clips) from the unit. At this time you can also clean the display face and plastic lens. There are also 4 silver screws around the edge that will need to be removed.
  4. Step Four. Once the faceplate is off, separate the two pieces (face and back) of the ACC by unclipping the plastic clips. Pull the two pieces apart carefully
  5. Step Five. You will now have the face and back, the face will have an electric circuit board on the back with 4 twist lock bulbs.
  6. Step Six. Remove the old bulbs by twisting them counter clockwise and lifting them straight out. Install the new bulbs by inserting them and twisting clockwise to lock them place
  7. Step Seven. Reassemble the ACC unit and take back to car
  8. Step Eight. Before screwing the unit back into the brackets connect the 3 electrical connections and test the ACC to make sure your lights are all working (if any of them are not working you will have to take the ACC apart again and turn the bulbs around as they are polarized and only work in one direction.
  9. Step Nine. Once all 4 bulbs are working, reassemble everything and enjoy what you have accomplished
    (NOTE: the hot spots aren't that bad, I had to use a somewhat high ISO to take the pic without a tripod)
Picture exaggerates the hot spots...the camera was at an angle
Vanity Mirror Bulbs
*****Installation of the Vanity Mirror Bulbs (VMB) is fairly straightforward. Do note, that some cars do not have lights in their vanity mirrors, for these cars you can skip this section.
  1. Step One - Flip open the vanity mirror cover,use your trim tool to remove the lense from your each VMB. This is done by inserting the sharp/pointed end of the tool into the grove near the front of the lense and popping the lense out
  2. Step Two - Remove the old bulb. This is done by grasping the bulb, and rotate it counter clockwise and pulling them out. Do this for each of the 4 bulbs.
  3. Step Three - Installing the LED. Insert the 31mm bulb into the bulb socket. This is done by simply pushing in place. Do this for each of the 4 bulbs.
  4. Step Four- If the bulbs do not light up when you plug the LED board in and turn it “on”, then you will need to remove the bulb(s) that do not light up and turn them 180° as the socket is polarized and will only work in one direction. *** Note if you have followed all of the above steps and the LED board is still not working, check to see if your Interior Illumination fuse has popped
Stock on Left - LED on right
tigersharkdude is offline
Old 09-15-2011, 11:09 AM
schmellyfart's Avatar
Thanks for the info!
One thing I noticed, you said that you cant find any cheap 20 smd panels, but you linked to a $3 20 smd panel.
schmellyfart is offline
Old 09-15-2011, 11:23 AM
i couldnt find any for a few months, hence what i said. and then when i went to ebay they were there
Old 09-15-2011, 11:29 AM
Daniel1120's Avatar
Good write up. Yes the same neo5 bulbs work for analog cluster, im using them.
Daniel1120 is offline
Old 09-15-2011, 11:31 AM
ive tried in my cousins car and they did NOT fit
Old 09-15-2011, 12:03 PM
cashoit's Avatar
that look good sharkman.
I bought plug and play LEDs. the doors were like 5 SMD. The dome was like 4. Not as bright as yours but all white.
cashoit is offline
Old 09-16-2011, 04:05 AM
Heero88's Avatar
Wow a year ago we had to solder and melt all this together now we can just buy plug and play from eBay hecka cheap lol thanks for the links and the pointer now I sit and patiently wait for the arrival of my LED'S ^_^
Heero88 is offline
Old 09-16-2011, 03:41 PM
sergofast's Avatar
Are those pics of the dash with the interior lights turned all the way up? What does it look like if you dim them a bit?
sergofast is offline
Old 09-16-2011, 04:05 PM
yes those are full brightness, if you dim them a bit its going to dim the bulbs a bit......
I no longer have the cool white bulbs in my car, im rocking red now. New theme for the car....Red panda LOL
Old 09-17-2011, 08:03 AM
renots's Avatar
I have to disagree with you on this, I bought the neo5 bulbs for my 96 analog cluster an they didn't fit, they were to small. They worked for all the warning lights but not the speedo,tach,fuel ect. The neo5's I had were half the size as what was in my car from factory.
Sharky, have you tried LEDs in the sunvisors? I think that's the only thing you don't have LEDs in lol but you could be way ahead of me already lol
renots is offline
Old 09-17-2011, 10:50 AM
I know where to get them just waiting on someone to buy my cluster so I have the money
Old 09-17-2011, 01:01 PM
Tyutyunnik's Avatar
Nice writeup, I'm getting some 20SMD panels in stock in a few weeks, they look awesome!
Tyutyunnik is offline
Old 09-17-2011, 04:01 PM
yes they do, i get tons of compliments from random car peeps when I open my doors and the door and dome lights come on
Old 09-17-2011, 05:47 PM
inyoface's Avatar
does anyone know if we can replace those for the 97 cluster and if so which ones? i love the write up im ordering the rest just wanna find out what the pn# or link....'preciate it lol
inyoface is offline
Old 09-17-2011, 06:19 PM
Im not positive on what the 95-97 cluster uses (hopefully will have a positive answer in a few weeks) but you can search and find the answer
EDIT: 95-97 clusters need T10/194 bulbs
Old 09-17-2011, 07:02 PM
renots's Avatar
Here's a link I found for the 95-97 clusters
http://www.superbrightleds.com/cgi-b...Fwled-whp6.htm
Ima be ordering these in a week or so, I'll post pics when completed
renots is offline
Old 09-17-2011, 07:31 PM
If 194 bulbs do work, you can buy T10 6-smd bulbs on ebay for $1 each
Old 09-17-2011, 07:34 PM
renots's Avatar
Oh nice ima have to look into that thanks for the tip!
renots is offline
Old 09-17-2011, 07:36 PM
http://cgi.ebay.com/ebaymotors/10-X-...#ht_1835wt_939
Old 09-18-2011, 09:18 AM
kel456's Avatar
that one has 120 degrees light pattern. do you have that installed?
kel456 is offline
Old 09-18-2011, 09:19 AM
yes, I have two in my license plate lights. and NO I dont have them in my gauges, re-read the thread
Old 09-18-2011, 12:17 PM
tarun900's Avatar
Is the license plate light setup the same for the 97? Two bulbs?
tarun900 is offline
Old 09-18-2011, 02:11 PM
I have no idea, get under there and take a look. Im willing to put $5 its the same though
Old 09-18-2011, 08:19 PM
dopey15's Avatar
this is so awsome
dopey15 is offline
Old 09-23-2011, 06:45 PM
I will try to get some pics tomorrow for a better how to, just got my camera back
Old 09-26-2011, 10:22 AM
wirelessdude04's Avatar
looks great man
wirelessdude04 is offline
Old 09-26-2011, 10:24 AM
yes there the same 194 bulb size
Old 09-29-2011, 12:28 PM
ChrisN337's Avatar
Did as followed and got the exact same cool white dash lights, looks great!
ChrisN337 is offline
Old 11-16-2011, 07:26 AM
Coming soon, hopefully figure out which neo wedge bulb fits in the 99 AMB ACC unit. Pretty sure its a neo4..neo 3&5 were to small and too big.
Old 11-16-2011, 02:26 PM
maxxxdout's Avatar
love the way these lights work. got mine installed and its a word of difference.. the map light is damn near blinding though.. not the best idea to have on while driving... lol. but they look great at night.
maxxxdout is offline
Old 11-16-2011, 02:30 PM
19GLE97's Avatar
i did all blue led's on my interior, dash, hazard/defroster, climate control, dome, map, door lights, and foot wells, and trunk, i gotta put pics up. still need to do the window switches but idk bout soldering, never done it before
19GLE97 is offline
Old 11-16-2011, 02:44 PM
if you did you hazard/defroster you had to solder those lights in.
Old 11-16-2011, 03:11 PM
flthere's Avatar
Can you please take a picture of the dome light and map light in the day time ? Will the LED panel go inside the dome/map light casing, or do we need to glue them to the outside ?
flthere is offline
Old 11-16-2011, 03:15 PM
VincentXero86's Avatar
Nicely done
VincentXero86 is offline
Old 11-16-2011, 03:16 PM
No you don't. You can reuse the little rubber thing inside the switches. Not the easiest way to do it, but it can be done that way.
Old 11-16-2011, 04:06 PM
Im sure the ORG would love to know what kind bulbs you used, seeing how I can't find a single thread about P&P hazard LED's but found a number of soldered in LED threads
Originally Posted by NHMAX603
i look a little video of some of my leds the shifer u cant realy see to well in the video and i forgot to open the ashtray also the video does my gauges no justice i need a new climate controle mine has a huge crack in it but ive got other things to worry about
http://youtu.be/xOXHxKdafgs
oh and billy, please post the links and pic HERE and not in this thread
http://forums.maxima.org/4th-generat...-interior.html
Old 11-16-2011, 04:11 PM
They go inside the lens just like a normal bulb would. I would take some pics right now BUT im not feeling that great from this recent brain surgery.
Old 11-16-2011, 05:21 PM
NHMAX603's Avatar
i want to see the under side of that switch were the resistor is connected also what are u using for a resistor ?
NHMAX603 is offline
Old 11-16-2011, 05:59 PM
Not my car
Old 11-16-2011, 06:19 PM
It's not hard basically solder postive side of led and negative part
Quick Reply: How To: 4th Gen Plug and Play Interior LED Thread
