Official 00VI thread
#41
What's the best way to run wiring from the cabin to the engine bay?
1. Drill a hole in the firewall?
2. Run the wires with the existing engine harness....through that hole.
3. Run it underneath from the gearbox? I hear that the manual 5 speeds have some space there....not sure about the autos.
DW
DW
#44
DW
DW
use an aleady exsisting hole
#47
One good resource/tip we could all benefit from would be the vacuum diagramming. I spent almost 2 days figuring out what went to what since I didn't exactly place the lines to what they went to, not to mention I had to shave off metal pieces from the vacuum galleries so I could make the TB/IACV fit.
I'm going back to my 01VI in the next couple of months, and I reaaaaaaaaaly wanted to keep my stock 4th gen LIM and rails since I don't want to have to solder and add harness wiring to my existing setup. What is honestly the best cost effective way and is there an exact link that shows what to drill into the 4th gen LIM for using the UIM? I know how to use JB and it worked very well when I did the 5th gen LIM for the valve openings, but the drilling, that's what's scary. Hence why I'd get a secondary junkyard LIM and rear valve cover. Unless there's a way to use the 4th gen LIM and 5th gen valve cover... What do you guys think?
#48
You guys are recreating the wheel.
Everything you need to know is here.
http://tatanko.boredmder.com/
#50
i wish i could help with the lower but im useing a 5th gen lower so hopefully someone else can chime in on that one
#51
Well, once I was able to get the vacuum lines sorted it was smooth sailing, but in the beginning there were the leaks, or some vacuum lines were reversed. And some had to be tee'd off, or modified. I drive the 96, and now know how it goes onto the 5th gen setup, but I'll have to redo it and this time see if it will work by using 4th gen components. But I'd be more than happy to mock up a setup for 5th gen only into a 96 for example, that way it could be more user friendly and served up in the 00VI thread stickies.
I'll be extensive when it comes to doing my 4th gen LIM and all, since I wouldn't want others to get steered in the same direction. If I do get it down with my eyes closed, who knows, I might even start a service for a drop in 00VI swap using pre-drilled and prepped 4th gen LIM/valve cover setups for a hustling penny of course
Thanks though Maxed!
-Axel
-Axel
#53
#56
i modified a 4th gen rear valve cover to work once and i hated it. it was so much work, of course i didn't have a good dremel at the time, but it was so much time wasted in modification so i ended up just buying a rear valve cover from the junkyard for $20
#58
#60
also here to help
i have all the 5th gen parts except the TB and IACV are from a 4th gen.
i have a question for anyone using the 5th gen TB. what is the diameter and what did you need to do to make it work with everything else i got? is the pathfinder TB harder to install?
I heard the 5th gen tb is bigger due to the bigger intake manifold entrance on the 00vi compared to the USIM. I'd like to make a 3" MAF but i don't want to have the gains of this super flowing air intake negated by a smaller TB.
i'll post pics of my setup on the weekend.
lets keep this as a post 00vi discussions or different 00vi setup thread for referencing. the how to is already handled somewhere else... btw does tatanko's build link include the "00vi" manual? its not really a how to but something worth reading if you wanna know stuff about the 00vi.
#61
if anyone needs help around in and around toronto i can lend a hand.
As far as the size difference, going by memory, I believe they are the same diameter. But I can very well be wrong. The PFTB on the other hand is alot bigger. But you will also need to make an adapter plate for it to bolt up. (or figure out some other ingenious way).
#62
5th gen TB is easier in my opinion because you don't need an adapter plate to install it. Also, the IACV is on the TB for 5th gens. Some have gotten this to work with the 4th gen ECU by simply rewiring it. That will take care of the IACV (if you get it working) and the block plate for it. There's 2 less things to fabricate. Either way, the car can run fine without an IACV unless you're concerned about the CEL.
i'm already running without iacv haha i mean its connected to the ecu but its not being used to keep the car idle, my tb is cracked open for that lol
i'll hook it up after exams are done but i got a question for that too... i wasnt the one that unscrewed it to keep it open and they don't remember how many turns they did :S but they remember it being sensitive and it took very little to change idle +/- 100rpm.
i don't want to just hook up my iacv and then find out its not doing anything because there's too much air going through the tb cause the throttle plate isn't closed enough. i took a look at my USIM and my old tb and its pretty much shut at no throttle... should i leave the engine running and then gradually move the screw till the engine dies or has a hard time to idle ?
#63
ok well i have an issue that im pretty sure i have came to the answer but i would like some input
i have a NR-G adjustable fpr with a liquid filled gauge
my problem is a hard start when i turn the key to the on position (the position just before you start the engine)
the fuel pressure jumps to 35 then immediately drops to 0 i have no residual pressure
my question is;
how likely is it my pump is dumpin out?
what are the symptoms of a weak pump?
and what are the symptoms of a bad fpr?
99
229k
my question is;
99
229k
#64
That's not true. However the 5.5gen TB is larger. You will still get gains from a 3" MAF, but you NEED to tune for it.
#66
5th gen TB is same size as 4th gen TB. With the stuff you have, you'll need an IACV adapter plate. More or less, you need to buy or make a set of adapter plates for the PFTB and port match the TB opening on the uim. Otherwise the install is the same as a 5th gen TB.
#67
Here's my setup
As mentioned...
vacuum and fuel line setup, birds nest lol. its a mess but somehow i know where most hoses go without reference
IACV setup, 4th gen w/ block off plate. hooked it up last week finally. drove 14k km with only TB holding idle... awesome engine.
Electronics. VAFC 2 and AEM UEGO wbo2 with super ghetto-a$$ mounting lol. i order a guage pod last night.
Note the over sized bolts... i stripped the threads in the LIM TWICE fml. yes i was using a torque wrench, aluminum is very soft and i realized the UIM only needs to be snug.
intake setup. K&N>MAF>stock res box>3" steel pipe>stock accordion reducer. this is my 4th setup... never buy weaponR. make it yourself or buy anything else but. Next setup is place racing CAI behind the splash guard. i haven't yet decided if i want to keep the little breather or attach to the stock res box...
Went to the junkyard today and found an 01 max and decided to take off the oem EGR block off plate. Will be needing this for EGR delete when i get OBX V2 headers next year. why they made the tube attachment i'll never get lol
The only issue i still have is a lightly fluctuating idle... when i first did the swap i only used 1/2 bolts to secure the egr to the headers. ya i'm dumb lol. i was crying about the 00vi taking forever so i left it like that, don't remember if it even has a gasket. now i gotta go back and fix it... price you pay when you're a lazy lil b!tch haha. i'll post some pics of the build.
#68
Build
old parts
Ready for note taking and hose labelling
Tools. The Motul oil was from my bike... i use a bit on gaskets.
00vi and all bolts in order
Old gasket
Old vs New LIM gaskets
new LIM and 5th gen injectors
Another view
Parts:
00 VI
00 LIM
00 Injectors
00 VC
4g TB with block off plate
4g IACV with block off plate
My $0.02:
-Take your sweet a$$ time
-have your local forum or this one handy for questions
-Don't stress if it doesn't work. stop, take a step back and think about it.
-buy an 00vi "kit" if you're not crafty or handy. get one with the 5th gen LIM. mine came with everything but an rpm switch.
-buy vafc 2 and a wideband o2 so you can tune (even if you don't get the 5th gen injectors). does a pretty decent job of tuning and the 12v VTEC signal is our 12v VIAS signal (rpm switch)
-Use pathfinder TB if you know how to hook it up.
its complicated yet simple. The concept is simple, all you're doing is replacing intake manifolds that bolt on... complicated part is EGR crap and all the hoses/wiring that go with the install.
If you got a kit sitting in the garage shut up and do it. make sure you got other transportation so you don't stress and have your laptop in the garage open to your own 00vi installation thread. when you ask questions about certain parts add pics and point to what you're talking about.
happy 00vi-ing
Old gasket
Another view
Parts:
00 VI
00 LIM
00 Injectors
00 VC
My $0.02:
happy 00vi-ing
#70
I think mevi's are just as good. who cares about the 6hp difference? come to think of it i think it has to do with heat soak cause the mevi's metal vs 00vi plastic so if you get the spacers you'll get that 6hp and maybe even gain 1-3 on top of the 00vi.
Mevi's are much less of a headache and look much nicer under the hood imo
#73
I stripped those same two bolts in front, never bothered retapping the holes though.
#74
#75
Unfortunately, I didn't take a pic of my 00vi swap, but it was extremely easy to do. Way easier than a lot of ppl are making it out to be. What I did was strip the paper and lower IM, injectors, and got rid of all unneccesary vaccum lines and egr. Then installed the Obx V2 headers/y-pipe from the 3.5. My upper and lower IM came from the 2001 with the egr block off plate. I also used the 5th gen injectors along with the 5th gen tb and iacv with (broken clip) method. And 5th gen rear valve cover and coil packs. When it was all said and done, this swap seemed to me to be somewhat of a direct bolt on as the ONLY modifications I made besides the headers was the iacv broken clip and egr elimination. Wired in the Vafc2, and had it set to open at 5000rpm, also 4in 4out. Car was untuned soi ran rich, but the y-pipe went back into the factory exhaust and OMG with a cai the car sounded amazing to the point where I didnt even really want to do the exhaust again lol. Car pulled like a bat outta hell, just ask the g35 I skated on and the 5.5 6spd that couldn't shake me lol. But only downside was that I was untuned and once I did a WOT pull, I had to be ready to hit the gas station smdh... IMO Best combo of mods for the 4th gen.
#77
yaaa baady!! i saw like 5-10hp on the butt dyno from street tuning and better fuel economy... he might see 10-15 with them headers
#78
no, not really its like 6 or 7 whp difference... with spacers it'll be like a 2whp difference. i'm comparing 00vi with 4g injectors to the mevi.
http://www.youtube.com/watch?v=M6NmiIt2XhE
with the right mods like spacers to keep the MEVI cool, mevi'd 4th gens are just as good as 00vi
#79
#80
those guys in the video had a couple of runs (check the other vids in his channel) which were pretty good. so to keep up with a fully bolted 6spd 5.5gen all you'd need is a mevi, y pipe back and a tune... imagine what it would be like if the 4th gen had headers
