replacing mounts next week, anything i can do to make them last longer??
Old 12-06-2014, 05:46 AM
max ride 41's Avatar
i have an oil leak and don't want the mounts to fall apart too soon, can i spray something, or add something to make them last longer/make them resist oil??
max ride 41 is offline
Old 12-06-2014, 06:26 AM
njmaxseltd's Avatar
Fix the oil leak, problem solved.
njmaxseltd is offline
Old 12-06-2014, 07:12 AM
next
Old 12-06-2014, 07:36 AM
Poly fill them.
ChrisMan287 is offline
Old 12-06-2014, 07:53 AM
Daniel VQ30life's Avatar
This
Daniel VQ30life is offline
Old 12-06-2014, 07:59 AM
aackshun's Avatar
I think you guys missed the boat here... "replacing mounts next week"
Soooo.....
Just don't drive the car?
Or drive it like.... a maxima owner, not enthusiast.
Not like you're in the middle of a lemons race or something, why bother?
aackshun is offline
Old 12-06-2014, 03:51 PM
asand1's Avatar
Run high mileage oil to restore your rubber motor mounts?
asand1 is offline
Old 12-06-2014, 04:35 PM
I don't see the point in spending the time and money in an attempt to protect something that is going to be replaced next week. They'll last, just take it easy.
The only product I found with a quick Google search that repels oil is this:
http://www.amazon.com/Oleum-274232-N...productDetails
The Wizard is offline
Old 12-06-2014, 07:24 PM
asand1's Avatar
Pretty sure he's talking about making the new mounts last longer.
At any rate fix the leaks or the new ones will fail early as well.
asand1 is offline
Old 12-06-2014, 07:34 PM
^I see.
Yeah, you're just gonna have to fix that oil leak. If you truly love your Max as much as you say you do, and plan to keep the Max as long as you say you are, then fixing the oil leak is a no brainer and a must do item. If your rear valve cover is leaking, you should have taken care of it a week or two ago when you had your injector replaced....the manifold was off.
Old 12-06-2014, 08:25 PM
^I see.
that was replaced and so was the uim gasket. if i had the money to fix the oil leak i would do so, it's the timing cover that leaks, my chain rattles and the harmonic balancer wobbles pretty good too. if i were to tear that apart i'd be opening up a huge can of worms and potentially a lot of problems as the motor is high mileage. i'm going to replace the belts soon and with it a new underdrive pulley. moneys tight and i'm doing what i can to keep her on the road.
Old 12-06-2014, 08:33 PM
Since it's the timing cover, only 1 mount is affected, right? That mount shouldn't get any oil dripping on it; typically only the radiator and firewall mounts get oil dripping on them. You can add a barrier to keep the oil away from it, or maybe try the product I suggested earlier. I can suggest a few barriers that are thermal resistant and should be able to repel oil. Additionally, that mount is really easy to replace, so if the new one fails in 2 to 3 years, no biggie, just replace it.
vingodine
45
05-21-2016 12:46 PM
schmellyfart
09-25-2015 04:47 PM
MaximaDrvr
08-19-2015 08:20 PM
scarletsosa
08-17-2015 09:09 PM
laparka66
08-06-2015 09:36 AM
Quick Reply: replacing mounts next week, anything i can do to make them last longer??
