Oil or fuel smell on a cold morning
Old 01-30-2015, 07:47 PM
Max40
Maxie40's Avatar
When I start my SE up on a cold morning, I notice I see some exhaust smoke coming by the driver side door in the area where the catalytic convertor is. I also smell a strong fuel/oil smell when I turn on the air. Both dissipate when the car is warmed up. Currently I have a check engine light caused by my EGR valve needing to be cleaned. Car accelerates and runs fine but with my check engine light on and those problems on a cold morning, my Maxima needs some work. Based on what I described is the cat going? Never replaced the exhaust system. I recently replaced my MAF and my intake manifold gasket. Could doing this work cause some other issues? Have been the only owner for a now 20+ year car.
Maxie40 is offline
Old 01-30-2015, 11:09 PM
TurboA32's Avatar
You most likely have a hole in the exhaust
TurboA32 is offline
Old 01-31-2015, 05:01 AM
uttadms31's Avatar
On these cold mornings look down underneath to see where the exhaust is leaking. I've had leaks at my flex pipe and resonator that I've ignored for a few years and haven't gotten much worse. Only can really hear it above 2.5k RPM / or on the highway, but with music on it's not that noticeable. I wonder if it will affect engine power at all?, but for now I don't plan on fixing it as the hangers are holding up things fine.
uttadms31 is offline
Old 01-31-2015, 06:48 AM
Quickywd01's Avatar
Classic y-pipe flex pipe hole? Replace it with a warpspeed y-pipe $200, magnaflow hi-flo cat $50-$100, stock or performance catbacks are also available.
Quickywd01 is offline
Old 01-31-2015, 09:16 AM
uttadms31's Avatar
I assume leaks downstream in the resonator are not as big a deal, but as for the flex pipe, besides the noise and state inspection issues, will the hole cause any engine/power or fuel economy issues?
Old 02-01-2015, 09:02 AM
max ride 41's Avatar
just replaced my y-pipe, and the whole cattback as last winter rusted it to death. if you have an exhaist leak it can rob you of power and your gas mileage will suffer.
max ride 41 is offline
Old 02-01-2015, 05:43 PM
mikeg75's Avatar
I had the smell of fuel until I replaced a small section of fuel hose right before the fuel pressure regulator. Those little fuel line sections get dried out after 20 years or so.
I actually witnessed dripping fuel on a very cold start, which is what prompted my changing those lines. My mechanic never smelled it because it only happened outside, on very cold starts. Inside his garage, I presume the lines were warm and more supple, rather than brittle and freeze dried/corroded.
Good luck.
mikeg75 is offline
VQ'ed
Forced Induction
02-29-2016 08:05 AM
RWCreative
09-21-2015 11:01 AM
bumpypickle
09-20-2015 08:22 AM
97_GXE
09-15-2015 06:47 AM
Quick Reply: Oil or fuel smell on a cold morning
