My grounding kit, let me show you...plus some questions
Old 03-22-2008, 09:26 PM
That's Mr. Detail to you
Scottwax's Avatar
I did a search but couldn't find any pictures, pretty much every link in the threads that popped up had dead links in them. The site I have my pictures hosted on isn't going anywhere soon so they will be around for future reference.
Anyway, I got a grounding kit from a fellow .org member, PandaXpress. He sent me a total of seven wires using nicely crimped terminals and 8 gauge wire. I ended up using 5 of them. I used the suggested mounting points in another grounding kit thread in the 5th gen classifieds, but I couldn't figure out how to attach a wire from the throttle body to the firewall without drilling a hole in the firewall-anyone have a picture of both connection points and is it recommended with the drive by wire TB? Battery to chassis, block to chassis, intake manifold to chassis, timing chain cover to chassis, alternator ground to chassis. Took about an hour, poking around, trying to find good places to run the wires.
First impressions. Smoother. Everything seems smoother. Lights are a touch brighter (but not OMG brighter), shifts are noticably smoother, downshifts seem quicker too. Biggest change I noticed is from a 50 mph roll, the car starts pulling hard the instant it downshifts. No lag at all. More actual power? No idea, my butt dyno isn't *that* sensitive. Quicker response and more overall smoothness is good enough.
The mounting points that aren't visible are noted with red arrows. If anyone has any better suggestions, I am all ears. I am thinking about attaching one to the transmission and chassis. I saw in some of the other threads something about a "daisy chain" method but really didn't see a clean way to do that.
There is a small bracket on the intake manifold under the engine cover I attached the wire to.
Engine block bracket attachment here:
Attached to the battery tray mounting bolt that looks like it goes into the chassis:
The wire going up under the engine cover from the front of the engine is bolted to the timing chain cover:
Arrow points to what appeared to me to be where the alternator is grounded. You can see on the chassis where 4 of the wires are connected to 3 points. Only the middle bolt is actually there on my car, but I had some 10mm bolts that fit into the already threaded holes above and below the already existing bolt.
Scottwax is offline
Old 03-22-2008, 10:55 PM
Armon's Avatar
pretty blue wires
Armon is offline
Old 03-23-2008, 06:57 AM
mist max2000's Avatar
notice any difference?
mist max2000 is offline
Old 03-23-2008, 07:12 AM
Scottwax's Avatar
I guess you missed it.
Scottwax is offline
Old 03-23-2008, 07:40 AM
nsnrider's Avatar
proops man, a few things i would have done different is ground the tranny to chassis (as you allready mention you want to do) and route the wires neater and zip tie them to exsisting wires/tubes. The way you have wires just lying/hanging around there might cause some bad grounds in the future which would depict the whole point of having them there in the first place, not to mention that if you ever have to change something under the hood, those things would be in the way and you'll constantly be moving them around.
Good job otherwise though.
nsnrider is offline
Old 03-23-2008, 07:55 AM
amomaxima's Avatar
I did almost the exact same DIY setup as you but my wires are ugly red
the tranny is easy but you have to remove the stock airbox scoop.
when you get that out in the middle of the tranny their is a plate with four bolts on it. I took on of the top ones out and put the ground wire on their.
As far as difference. Smoother idle, less power drain from amps, smoother acceleration when i am not punching the gas.
amomaxima is offline
Old 03-23-2008, 08:09 AM
大陆弟弟
n3985's Avatar
You should ground:
1. Tranny - located in left wheelwell
2. Coilpacks - under the engine cover there's 2 of them
3. Fusebox - next to driver headlight
4. Block - underneath the intake scoop
n3985 is offline
Old 03-23-2008, 09:20 AM
Toolie
knight_yyz's Avatar
instead of the firewall for grounding point you could use the bracket bolts on the fstb. It's close enough to the firewall
knight_yyz is offline
Old 03-23-2008, 03:37 PM
Scottwax's Avatar
Thanks for the comments and suggestions, definitely want to do the tranmission one, if I remember right from reading the Nissan service manual for my car, one of the fixes for transmission issues has to do with grounding.
Scottwax is offline
Old 03-23-2008, 03:54 PM
大陆弟弟
n3985's Avatar
That relates to the ground point inside the pan, it somehow corrodes or breaks loose, FYI.
n3985 is offline
Old 03-23-2008, 10:37 PM
Toolie
knight_yyz's Avatar
Found this on my hard drive. Not the best wire to use but it shows some handy places.
Old 03-24-2008, 01:11 PM
amomaxima's Avatar
i used the stock ground points on the car and it works perfect, there are two
one either side of the engine where you can see wire running to
just shaved them smooth and used them
Old 03-24-2008, 03:22 PM
titanbk's Avatar
do these grounding issues apply to the 4th gens as well? Its is the first I've heard of it, whats the theory behind this?
titanbk is offline
Old 03-24-2008, 08:28 PM
Scottwax's Avatar
The theory is that the minimal grounding done by the factory isn't sufficient for the best operation of all your electrical components. Adding additional grounding with heavier gauge wires should allow better performance of your electrical system. Some magazine tests have shown minimal power gains (2-3 hp in most cases) but I think it is more likely you just get more consistant performance due to increased electrical efficiency.
Scottwax is offline
Old 03-24-2008, 09:26 PM
LA02MAX's Avatar
meh, there's probably no difference. Sometimes my car feels really peppy and sometimes I think it feels slow...I noticed no difference after installing my grounding kit...
LA02MAX is offline
Old 03-25-2008, 07:49 AM
Scottwax's Avatar
I bet the inconsistancy (I've noticed it too) has a lot to do with the drive by wire throttle.
Scottwax is offline
Old 03-28-2008, 06:05 PM
crazy97's Avatar
If you have a 5spd, your starter could eventually lose it's ground from the engine/tranny----see below.
crazy97 is offline
Old 03-28-2008, 06:50 PM
Mauja He Mauja
ZIPPIN's Avatar
I did not notice any difference on my 00. Have not grounded my 03 yet.
ZIPPIN is offline
Old 03-28-2008, 07:01 PM
大陆弟弟
n3985's Avatar
Big 3 > 1000000 wires grounding kit
n3985 is offline
Old 03-29-2008, 12:29 PM
drzcrazychulo4u's Avatar
hi any one living in NY towards the queens area want to help me install the hks grounding kit i have a 06 nissan maxima please i will pay and buy lunch thanks
drzcrazychulo4u is offline
Old 03-29-2008, 01:28 PM
Cletus
SoonerFan's Avatar
i had this done on my 00 and noticed a difference...havent done it on my 02 but i have powerpoint slides on my HD that shows all the locations.
SoonerFan is offline
Old 03-29-2008, 04:58 PM
Armon's Avatar
a must-do if you have an auto tranny
Armon is offline
Old 03-29-2008, 05:00 PM
Cletus
SoonerFan's Avatar
agreed...me and irish both had 00s....mine auto, his MT...made more of a difference on mine
Old 03-29-2008, 07:25 PM
Scottwax's Avatar
I wonder if it has anything to do with a small bump in mileage? Been getting 20.5 mpg (doing the actual math) vs 19.5 before. Probably take several tanks though, to see it is a consistant improvement, could also be due to it getting warmer and less time in closed loop.
Still, 70 of this was freeway, the rest light to moderate city traffic. Reset when I filled up.
Scottwax is offline
Old 03-29-2008, 09:45 PM
Cletus
SoonerFan's Avatar
whats is that line of letters and numbers between the tach and speedo
Old 03-29-2008, 10:33 PM
CMax03's Avatar
Auto transmission gear indicator!
CMax03 is offline
Old 03-29-2008, 10:37 PM
Cletus
SoonerFan's Avatar
thanks....for getting the joke
Old 03-30-2008, 04:35 AM
maxximaa's Avatar
are all grounding kit the same? where should i get one? im from the cold white north..
maxximaa is offline
Old 03-30-2008, 10:36 AM
RacerX1320's Avatar
Im probably going to do this in the near future but i was looking into the kits by buddyclub and apexi that not only include the wires but also a voltage regulator.
Anyone using this method?
<---just saw minor mpg gains when i switch to NGK IX
RacerX1320 is offline
Old 03-30-2008, 01:32 PM
Active procrastinator
Afronaut's Avatar
I did the grounds with a kit bought from a fellow org member and noticed a difference in the start and acceleration on my '00 auto.
Afronaut is offline
Old 03-31-2008, 07:34 AM
gaby617's Avatar
I finally got around to install my ground kit that i purchesed from blehmco. i def felt the difference. the only way i can describe it is that it felt like the time i changed my maf and didnt realize how much i was losing. I have an 00 and start up sounds more solid, acceleration seems to be better and def my lights illuminate nicer. i thought the leds where bright before, after the ground kit they seem brigther.
gaby617 is offline
Old 03-31-2008, 08:31 AM
jdm01se's Avatar
That's definitely something I need to do.
So just message 'PandaXpress'.....?
jdm01se is offline
Old 03-31-2008, 08:34 AM
Cletus
SoonerFan's Avatar
they all do the same thing...some are just overpriced. make your own.
Old 03-31-2008, 08:39 AM
Maxima Grounding Kit Spec
Shinjiduo's Avatar
Yeah ground kits do make a difference but I notice that most people my self included use entirely too much wire thinking the more the better and wind up adding a whole bunch of weight with marginal gains. I actually did a ground set up and the big three together in 1/0 Gauge stinger wire and found out that about 5 short wires supplied 80 percent of the gains and none of them were attached directly to the transmission. (Although I do have a starter ground.) The other 20 percent for the most part was due to the positive battery terminal to the positive alternator ground. The key is to set up the least intrusive neatest set up with the shortest wires possible. Something that took weeks of testing to find out. Basically what I am saying is that you shouldn't need to have wires criss crossing your engine to get the benefit of the kit about 4.5 ft of audio grade or marine grade tinned (for corrosion resistance) 4AWG (not crappy SAE or home depot 4 Gauge) will do. Not to mention it will save you weight.
Shinjiduo is offline
Old 03-31-2008, 08:43 AM
Shinjiduo's Avatar
Or you can message me.
Old 06-03-2008, 08:24 PM
parapeligicdrumr's Avatar
do you mind putting it up?
i'm interested in doing this soon
parapeligicdrumr is offline
Old 06-04-2008, 01:47 AM
dahsraw's Avatar
nissan ground kit
http://www.courtesyparts.com/Merchan..._Code=GRND-A33
dahsraw is offline
Old 07-10-2008, 12:49 PM
pyroz's Avatar
what is considered the big 3 for grounding? thanks.
pyroz is offline
Old 07-10-2008, 02:42 PM
Insane Maxima's Avatar
anyone got any pics?
Insane Maxima is offline
Old 09-10-2008, 10:27 PM
navigator82's Avatar
hey man i know you are a very busy person but can you take pictures little more clear please i traid to put my and these is the only research i culd find pleaseeee thanks
navigator82 is offline
Quick Reply: My grounding kit, let me show you...plus some questions
