Need Help in Brake Part Identification
Old 06-14-2010, 07:25 PM
Portugue's Avatar
Hey Guys! I recently had to replace a seized rear caliper on my wifes 01 maxima. Along with the piston being seized, one of the guide pins was also seized in the bracket so I got a new one. I installed everything, put the new guide pins in and tightened everything up. Now there is this loud rattle from the rear when I hit bumps. I noticed the rattle would stop when I hit the same bumps and pressed the brake pedal. So I think discovered that the caliper has some wiggle. Everything is tight, but I can rotate it slightly. Its almost like the guide pins are snug enough or something. There was also this part which I couldn't figure out what the heck it was for or where it went. I bought the bracket at autozone and the caliper at pepboys. Here is a pic of the part:
http://i120.photobucket.com/albums/o...01249Large.jpg
Thanks in advance!
Portugue is offline
Old 06-14-2010, 07:28 PM
2slow's Avatar
That's a spring clip which are usually used to keep the pads from rattling.
I lost one when doing a rear brake job on another car which caused a rattle over bumps but disappeared while braking.
2slow is offline
Old 06-14-2010, 07:31 PM
Portugue's Avatar
I thought of that, but how and where do you install it? It will help, but the caliper (although all brackets are tight) is still kind of loose with the guide pins which is the source of my rattle.
Portugue is offline
Old 06-14-2010, 07:43 PM
2slow's Avatar
It's a little hard to see (*B), but it goes between the pads and the top of the caliper (the picture has it rotated 180 degrees):
2slow is offline
MAXSE5SPD
09-17-2022 04:00 AM
mvm062
11-30-2020 09:00 AM
AcuraLegend
10-17-2016 08:47 PM
AcuraLegend
09-22-2015 04:22 PM
A32goldylocks
09-02-2015 06:39 AM
Quick Reply: Need Help in Brake Part Identification
