Can all these codes be associated?
I recently had my immobilizer control unit replaced and about a week after getting my car back i started having this issue.
Car wont start unless I'm applying about a quarter inch of throttle for a few seconds. Other wise it starts and stalls out.
Thought I had bad gas but 5 tanks later and an injector cleaner still doing it.
Pulled code and this is what I got: (each line displayed, not sure if any lines are together)
P1800
Mil off
Monitrs
0 Inc
7 Ready
Misfire
Fuel Comp
Catalyst
Evap
02 Sensr
02 Htr
Passed Emissions, Runs great once started. 2002 w/192K miles
P1800
Mil off
Monitrs
0 Inc
7 Ready
Misfire
Fuel Comp
Catalyst
Evap
02 Sensr
02 Htr
The only thing you typed in is the P1800 at the top of the list. Everything after that is unintelligible gobbledegook. If there are more codes than the P1800, please list them.
P1800 is the VIAS control solenoid valve. It is mounted on the intake manifold on the right side towards the front corner of the manifold. Get that fixed and there is a good chance the starting problem will disappear.
see page 24 for a locator diagram.
See page 686 for more info on P1800.
http://boredmder.com/FSMs/Nissan/Maxima/2002/EC.pdf
At first with this problem I was only getting the P1800 code with "No" engine light on. Yesterday the engine light can on for its first time with an additional code P0506 "Low Engine RPM". After further research I replaced the vacuum hoses to the VIAS and cleaned the throttle body...
Problem Solved!!!!
Codes reset, fingers crossed they don't come back.
Problem Solved!!!!
Kyle Lee Cleveland
09-28-2015 09:01 PM
