After Y pipe Installation
I finally got the y pipe, sounds and feels amazing!! However during the installation the y pipe was too long to bolt to my test pipe. So they cut the middle of the test pipe and made it smaller by welding on a shorter pipe.. So now everything fits.
I'm not sure if that's the problem (shorter test pipe) but whenever i full throttle, I can feel the something rattling under my feet. The guy told me that I needed to change my motor mounts but I honestly didn't know what to make of it.
(The car does have 210k miles and I'm not sure if the previous owner ever changed the mounts)
What do you guys think?
Check the heat shield that fits above the exhaust pipes. I used to hear a rattle after I put my 3" set up on my car, and when I finally inspected it, all it was was a single bolt that wasn't holding a corner of the shield up, so it was scratching and rattling when I drove.
Perhaps that could be the issue? If so, extremely easy fix.
Probably the heat sheild but another possibility could be a bead from the welds they did rattling in the exhaust pipe. I had that same problem you describe and the exhaust shop cut my cat off tipped it over and a small bead came out. He just welded it back on and the noise went away. When you check the heat sheild try banging on the exhaust with your hand to see if you hear anything inside the pipe.
Violator
09-09-2015 10:14 AM
