hypermiling/tire pressure 2003 maxima?
Hi I am wondering what are the recommended tire pressure to help improve mpg for a 2003 maxima se auto. The car is stock with 17in wheels. I put premium gas in my car. it has about 90k miles on it now.
Thanks.
Thanks.
Stick with the recommended pressure. maybe one or two PSI over.
Over inflating your tires will help with mileage but it will hurt the handling/safety and eat the tires. It will cost you far more in tires than you save in gas.
If you're trying to micro mileage, you should look into doing the 17degree timing advance. Look it up. I saw a 10% increase in my mileage after doing it with regular driving. You'll probably see better since you spend more time at part throttle and low RPM where this mod is effective.
Under inflation will generate more heat and cause faster tire wear.
That's pretty irrelevant. You need more pressure in the front b/c there's a lot more weight on them. IIRC, it's only .1 PSI for every 10 degrees.
No, typically you use a higher pressure on the higher weighted end of the car (front or rear). In the case of Maxima's (front engine and front drive) you want higher PSI in the front if you are going to be using different PSI front versus rear.
Those labels are cold psi so if you want to be **** do at the coldest times you think
you're going to drive the car. It'll go up like 2-3 psi when it gets hot out.
http://en.wikipedia.org/wiki/Cold_inflation_pressure
http://www.goodyear.com/cfmx/web/cor...y.cfm?a_id=371
http://www.tirerack.com/tires/tirete....jsp?techid=73
Depends on the tire's rating. My touring tires are designed to contain up to 44 psi but I routinely run 40 psi. Don't just go with the tired old standard of 35 psi, do research.
Every little bit of rolling resistance I can reduce, if ever so slightly, is a bonus.
Good info there on tirerack.com. Always check and fill your tires cold if possible.
I have been running 36 psi on my 2000 SE with 225/50-17 tires. I increased my tire pressure after I noticed that the tire shops would routinely inflate my tires to 38, even 40 psi, and the car felt good. My experience is that the car people recommend less (32-34) and the tire people recommend more (36-40). Higher pressure is better for mielage, lower pressure for comfort. So suit yourself, as long as you don't exceed safety margins.
Back in the 90s firestone was oem for the ford explorer.
firestone recommended what they felt was safe but ford wanted a lower
pressure of 26psi for comfort. I had one of these explorers, they're actually a rough ride.
But anyway, they overheated and blew the freaking tire because what ford recommended plus a crap tire.
I'm just saying why should people trust the psi sticker nissan puts on
why do they recommend that specific pressure? They tell you to put in more pressure if it's loaded down but why not keep it that way always?
Comfort. Not tread life or grip.
wingsfan24
08-15-2015 07:35 PM
altome15
08-10-2015 07:05 PM
