"Multiple MisFire?" ---is Jesus Busy ?
Hi Friends,
3.5 is missing and Running Erratic (Almost like a few plugs have gone bad). AT THE STOP LIGHT it misses until i put it in Neutral---then idles better. TACH jumps "in neutral" but "REALLY jumps when i'm in gear" at the light. Missing and Sputtering on acceleration.
Codes come back with:
I'm thinking these steps:
*Your constructive input is greatly appreciated.
Thank You!
p0154 (oxy.sen.--bank 2)
p0168 (closed loop vent)
p0300 (random misfire)
What's the best way to attack these issues?p0168 (closed loop vent)
- Change oxg.sen (front or right)---See if that fixes issue
- Change back coils and plugs (already did the front ones)
Thank You!
Yes, change primary front O2 sensor. Denso O2 is fine. Clear codes and see what happens.
If still problematic change out spark plugs on bank 2. Clear codes and run again. If still problematic change out ignition coils on bank 2.
It looks like the problem is isolated to bank 2.
I don't think that was intended to be a joke. 3.5's are plagued with bad valve covers, primarily the rear cover. Cylinder #3 is the middle cylinder in the rear bank which commonly has the leaky spark plug tube seal. Oil collects around the plug/coil and causes misfires.
Ergo, replace coil/plug #3 and call it a day.
QUESTION: I'm assuming that Bank 2 are those plugs in the FRONT (same location as Oxy.Sens) ? ? ? ---or am i wrong?
ANYWAY, thanks dudes. Hope all is well where you are!
~T
Yes.
Bank 1 = nearest to firewall (cylinders, 1, 3, and 5)
Bank 2 = nearest to radiator (cylinders 2, 4, and 6)
What someone else mentioned as a problem with the cylinder 3 oil, it does not appear to be your problem at the moment since the engine codes point to bank 2 (cylinders 2, 4, and 6). I would focus on the bank 2 right now.
If you have plenty of money it wouldn't hurt to change the valve covers as mentioned, change the spark plugs, and ignition coils. To do all of that you are probably looking around $600 or $700. The ignition coils being the most expensive parts around $80 a piece depending on where you shop.
3. pray to jesus to fix it
or something like that. hence the "do #3 and call it a day"
Originally Posted by "Unclejunebug;
P0300 is random misfire which could point to either cylinder bank. P0154 points to the bank 2 O2 sensor. Totally separate from the cylinder banks.
Ah, sh*t! How could I have missed that?! In my mind the O2 sensor banks were separate from cylinder banks but that makes complete sense that the bank1 sensors correlate to the bank1 cylinders and bank2 sensors correlate to bank2 cylinders. My mistake! Consider me humbled
i have done that
I have done all this thanks to oil in #1 i changed coil on plugs the spark plugs both valve covers all 3 upper intake gaskets and all the vacuum lines going to the upper intake.....multiple misefire still pops up now cat code pulls up.. not sure which one i got pissed and gave up for two weeks oh and i had to change cam pos sensor on bank 2 me n my wife would love anybody's help we ain't even made the third car payment yet....thanks and god bless
I have done all this thanks to oil in #1 i changed coil on plugs the spark plugs both valve covers all 3 upper intake gaskets and all the vacuum lines going to the upper intake.....multiple misfire still pops up now cat code pulls up.. not sure which one i got pissed and gave up for two weeks oh and i had to change cam pos sensor on bank 2 me n my wife would love anybody's help we ain't even made the third car payment yet....thanks and god bless
As i mentioned (in this thread) LINK...i'm getting p0154 (oxy.sen.--bank 2), p0168 (closed loop vent) and p0300 (random misfire).
After SEEING the constant SES light, i pulled the car off the road (asap). Fortunately, i have a spare vehicle (Nissan PU). Am now waiting for the Oxy.Sen Part to arrive from Rock Parts.
NOTE: Started the car this morning and it still missing, BUT the "Flashing SES" light is GONE....and its once again SOLID. Never-the-less, after doing some research, i will not drive the car until this "misfire issue" is resolved.
HOPING that the oxy.sen will solve this misfire Issue. Keeping fingers crossed.
For those of you kind enough to submit constructive input...i say "Thank you!"
~AC
I never looked up the P0168 code before and I finally got curious. So I went and looked it up and my curiosity changed to surprise. I can't find P0168 in either the Infiniti or Maxima service manuals.
According to the book for my OBD code reader, P0168 is "fuel temperature too high". But according to the 95-99 Maxima service manual, "fuel temperature too high" is P0180. However, I can't find P0180 in the 5th gen Maxima or the I35 service manuals.
If I believe my OBD code reader book, this is a possibility. There is a temperature sensor in the gas tank.
I know that there are other codes that are not in the service manual, for example codes in the P161x family that are for NATS.
I hesitate to suggest anything for the P0168 code. All I can do is ask you to verify that the P0168 number is correct.
I'm glad that it's not P0168. I don't know how a gas tank could overheat, but I wouldn't want to be around a car that had that happening.
Hopefully that O2 sensor will clear up all the codes for you.
Thanks Man...a little pressure on me. Got to feed 2 little girls and these cars troubles are cutting into my wallet.
Get a valve cover for a 6th gen. They are made different and they seal better. And as an added bonus, they are less expensive.
Still trying to Solve this Misfire Issue. Changed the Oxy Sensor, bank 1, no change. Car is still Misfiring.
Thanks man..where is the VTC solenoid located?
I've tried searching web---and come up with different information and web images ? ? ?
Thanks Dennis...is the BOTH THE COVER AND GASKET...or Just the Gasket ?
jmlee44
10-02-2022 02:13 PM
TKHanson
11-24-2018 01:39 AM
06-06-2017 02:01 PM
