To People that had an auto Slippage
Old 05-30-2002, 05:26 PM
2001SE's Avatar
Did the slippage only happend between 1st to 2nd?
did it happen frequently? how much gas did you need to press in order for it to happen? did you need to floor it and manaul shift to 2nd?
2001SE is offline
Old 05-30-2002, 05:53 PM
20th maxstyle's Avatar
1st - 2nd and 2nd - 3rd
This is my second trans.
20th maxstyle is offline
Old 05-30-2002, 06:05 PM
2001SE's Avatar
ehhh....some more info please
2001SE is offline
Old 05-30-2002, 06:18 PM
Maximam's Avatar
Mine slipped between 2nd to 3rd, like a slight delay in shifts. They finally found metal shavings in the tranny and replaced it under warranty. The new tranny has not slipped once.
Mark
Maximam is offline
Old 05-31-2002, 07:28 AM
BuddyWh
Re: To People that had an auto Slippage
1st-2nd only. With 1/2 throttle... especially noticeable when accelerating uphill.
BuddyWh
Old 05-31-2002, 09:14 AM
lcf
lcf's Avatar
i havent driven any other 5th gens so i dont know if im slipping or not. i only have a problem in the mornings... so im thinking that its just the cold engine? the owners manual says to turn overdrive off when going up hills... it helps. apparently OD isnt very good at downshifting up steep inclines.
i want to have the nissan fux0rz take a look at my tranny and check for slippage. is this going to cost me the $7X.00 they always charge for bringing it in?
lcf is offline
Old 05-31-2002, 01:21 PM
BuddyWh
It think it is to keep the tranny from cycling into/outof OD as you apply more power to maintain speed uphill. It is a really annoying cycle... downshift,speed up.... upshift, slow down... downshift, speed up... an so on.
BuddyWh
Old 05-31-2002, 01:57 PM
2k1seae's Avatar
Mine slipped from 1st to 2nd and from 2nd to 3rd under pretty heavy throttle. Did it when shifting in drive or shifting manually. I told the dealer about it and informed them of TSB. They fixed it after I complained about 3-4 times. SM was very nice about about it but was surprised that I new about TSB. Transmission still slips a bit but much better than before. SM is good and overall has been a good experience/relationship so far. There is a lot of info that can be searched for.
2k1seae is offline
Old 05-31-2002, 02:10 PM
littledog's Avatar
Mine slipped from 1st to 2nd at close to full throttle. It gets more frequent as time goes on. It used to do it once in a month or so to everyday on the same route. You don't need to manually shift it, just in D is fine. Also it occurs more frequent when it's cold and/or under load (uphill + 5 persons in car).
littledog is offline
Old 06-01-2002, 01:35 PM
scmaxima2k's Avatar
Mine slips in the mornings too but once it warms up it shifts better...but still seems to slip from 1st to 2nd, and from 2nd to 3rd, but on a hot day after driving for a while its fine...damn automatic transmission lol
scmaxima2k is offline
Old 06-22-2002, 06:18 AM
CAN YOU PUT IT ON THE WALL?
IWNTMORHP!!'s Avatar
it seems like i am always the odd ball...mine slips severly in reverse when i try to pull out of my driveway in the a.m. sometimes if i back in, it does it in d also...it almost feels like the e brake is on, and the engine is on morphine...no pep at all, like it is lagging. i don't stomp on the gas when i first leave, just try to leave normal...i have a 1/2 gravel driveway for now, so obiously i am not goosing it...the max has enough paint chips already n e ideas? do you think it pertains to the tsb? vb calibration? or just gremlins?
IWNTMORHP!! is offline
Old 08-08-2008, 12:09 PM
dewd's Avatar
happends to mine aswell but it seem if i put the O/D Off button to where it lights up (O/D off trigger) it somehow helps the slipping though my slippin only seems to happen from 1st to 2nd..
dewd is offline
Old 08-08-2008, 05:10 PM
FlipCpt45's Avatar
holy 6 year thread reunion batman!
FlipCpt45 is offline
Old 08-08-2008, 05:51 PM
wyche89's Avatar
lol.. i was about to respond too... i always get caught by that!
wyche89 is offline
Old 08-09-2008, 07:32 AM
KRRZ350's Avatar
The cold morning slippage in ours goes away for a few months after changing the fluid. As well as the long delay between 1-2, and the sometimes violent 1-2.
KRRZ350 is offline
Old 08-09-2008, 07:57 AM
User 12822's Avatar
1st to 2nd and 2nd to third.
From my experience it seems like 1st and 2nd and reverse are the first to go. I was still able to drive around in 3rd and fourth gear.
User 12822 is offline
Old 08-09-2008, 08:18 AM
dewd's Avatar
yea it seems to not always happen but its definitely happening to mine so im worried about how long ill be able to use/drive this car before it dies in the middle of the road on me lol or drives me off a cliff. started last week for me.
and since 1st-to-2nd gear seems to be on its way out does that mean eventually ill have to start taking off from (2) or (1) instead of (D) in the mornings?
edit: oh and im sorry for bumping a older thread i know how mad you trollers and forum police get, but i truely mean it...and besides this thread seems very useful.
dewd is offline
Old 08-09-2008, 08:25 AM
dewd's Avatar
Hey what do you mean "sometimes violent" dont you scare me! i think i might need to be prepared for that..
dewd is offline
Old 08-09-2008, 07:47 PM
KRRZ350's Avatar
It's not going to set the airbags off or anything, lol.
But it's like vroo(normalshiftpoint)ooooooooo(wtf, it's still not shifting!)ooooooBANG.
KRRZ350 is offline
Old 08-09-2008, 08:04 PM
yogi's Avatar
since i bought the car with 16k on odo (in 04) always had slippage btw 1st and 2nd...everything else is fine
yogi is offline
Old 08-10-2008, 08:28 AM
Torgus's Avatar
i don't slip.
Torgus is offline
Old 08-10-2008, 04:29 PM
dewd's Avatar
you had it slipping since 04 and your trans is still going strong?
well something i noticed on my 00 max is it only seems to happen on occasion or when i ride for a while then it will eventually just go into slippagEEE mode
dewd is offline
Old 08-11-2008, 10:43 AM
Wise-1's Avatar
I have slipping on my tranny (this is my third one) from 2nd-3rd. Only under light throttle. Under heavy throttle the car shifts crisp. A little hard from 2nd onwards, but thats because I had the transmission shop increase the valve pressure a bit when they rebuilt it last time.
Wise-1 is offline
Old 08-11-2008, 11:21 AM
yogi's Avatar
so far so good with tranny
just 1st to 2nd slippage - all good besides that
yogi is offline
Old 08-11-2008, 01:30 PM
dewd's Avatar
yea it seems im experiencing the same thing man hopefully it sticks it through and just works for a very long time.. cause its actually a pretty nice car.
dewd is offline
Old 08-12-2008, 10:49 AM
That's Mr. Detail to you
Scottwax's Avatar
Soft 2-3 shifts in cold weather at part throttle until the engine is warmed up. Full throttle shifts are fast and firm.
Scottwax is offline
Old 08-12-2008, 01:36 PM
itsyounotme's Avatar
I get a slight "thud", like a hard shift, from 1st to 2nd under hard throttle sometimes but it seems fine otherwise. I just don't gun it anymore. It's not as much fun but I need to save gas anyway .
itsyounotme is offline
Old 08-12-2008, 02:56 PM
Curb Rash Repair 100 a wheel
Maxima112's Avatar
get a MAF cleaner to fix the thud/jolt feeling. I just thought this was natural. did the MAF clean and now when i gas it it pulls through the gears, not just reving high then a thud... its only like 6 bucks for the can.
Maxima112 is offline
Old 08-12-2008, 04:22 PM
dineth00i30's Avatar
Mine doesn't slip( maybe it does ) but it does shift wierd when shifting from 1st to 2nd. Its like tranny is just throwing it on gear and not happy about it... Its like a little kick that I can feel through the throttle... Other than that its fine and this is the only reason that make me regret About buying this car..
dineth00i30 is offline
Old 08-13-2008, 01:00 AM
sixteenXnine's Avatar
I get peeved that my GXE has a hard, pulling/jerking 1st-2nd shift anywhere above half throttle, while my GLE shifts butter smooth no matter what the temperature, rhyme or reason.
MAF clean? Huh? I was gonna replace my TCM, but what's this about MAF? What, clean my sensor? Do explain.
sixteenXnine is offline
Old 08-15-2008, 01:44 PM
Thanks, I thought it was my tranny so I baby it...most of the time .
litch
123
01-04-2024 07:01 PM
AaronL
08-08-2020 10:31 AM
Maximeltman
09-28-2015 07:19 PM
dshinn
09-26-2015 08:07 PM
Quick Reply: To People that had an auto Slippage
