Small CLUNK coming from rear??????
Our 2014 Maxima is perfect, except for a small clunk that can be heard coming from the back. It does it every time the car is initially started, and the clunk occurs between 30 and 40 mph.
It happens one time only, never happens again until the car is parked and turned off. Then, when started back up and put into drive, we wait for 30-40 mph and hear it again.
It's done it since we have owned the car - bought it in August. My wife drives it most of the time and we had it three months before she told me about it.
Anyone have any suggestions? I've crawled under the car about 10 times looking for something shiny from being hit or bumped, pulled the wheels, and grabbed and pryed on everything under the car. Then I moved to the trunk looking for something to stand out at me....nothing!!! I even removed the back seat hoping to see something or change the volume of the clunk...no good.
Please help if you can...thanks
Unfortunately, this is a Maxima mystery. I have 147,000 miles on my car and I have heard that clunking since I've owned the car (27k). The car has run fine and has had no issues. There has never been a culprit for this issue. It's just a "Maxima" thing?
ABS self check
This "clunk" noise you are hearing is the ABS self check and it will happen only once at the same speed each time the vehicle is started from a cold start. Although it does not sound normal it is very normal for this model, mine has done it since it was new. If you drive the same way each time you leave your house you will notice it at the same location each day. Look at your speedometer when it happens and you will notice it happens at the same speed each time.
