Sponsored by:
Sponsored by:
Radio/stereo removal
Old 12-18-2016, 02:24 AM
Scribbles956's Avatar
Talking Radio/stereo removal
Remove trim under stereo using trim stick then remove vents and a/c heater controls. Stereo will have 2 black philips screws and 4 silver philip screws that need to be removed. Unplug wire harness from rear of stereo.
Remove torx screws...4 on each side
Should look like this meow
Easy plug and play when you buy the harness
Assemble in reverse order
And if youre gonna run an amp and subs run the rca's through the passenger side. Power cable will be ran through the driver side.
Scribbles956 is offline
Old 12-18-2016, 12:28 PM
thekevinwright's Avatar
Quick and simple write up!! Definitely gonna save this for the future. Did you get the BT one tho?
thekevinwright is offline
Old 12-18-2016, 08:08 PM
KGMtech's Avatar
Does the new head unit have back up camera option?
KGMtech is offline
