Sponsored by:
Sponsored by:
09 max heater not getting hot
Old 01-06-2017, 02:12 PM
timmwg's Avatar
my 2009 max had the heater core replaced & bled the system, heat blows hot when driving, when i stop it blows cool air, when turned all the way up. doing the exact same thing as before. Anybody know what else could be causing this?? THANKS
timmwg is offline
Old 01-07-2017, 06:18 AM
Les7311's Avatar
Pop the hood and check the coolant. Was it drained prior to surgery? Top it off.
While engine cold, and not running, open the radiator cap and squeeze the large top radiator hose for a few minutes. You could have air pockets in the system - will see bubbles coming out. Follow this YouTube link.....burping the radiator
https://youtu.be/cRPEqO06O58
Try that and update us.
Les7311 is offline
Old 04-05-2017, 04:43 PM
timmwg's Avatar
had the heater core replace.....damn heater still cold at idle. Damn, Damn, Damn!!!
timmwg is offline
Old 04-05-2017, 05:50 PM
Les7311's Avatar
was the heater core the problem? Did they / you "burped" the system as shown in the youTube vid?
Les7311 is offline
Old 04-05-2017, 09:35 PM
BronxSleeperMax187's Avatar
Burp system...be happy
BronxSleeperMax187 is offline
Old 04-06-2017, 08:53 PM
2000G6's Avatar
has your engine ever overheated?
2000G6 is offline
Old 04-08-2017, 02:05 PM
Bificus99's Avatar
Also check hoses coming in and out of the cabin for the heater core. If they are both hot then its not the heater core, maybe a blend door.
Bificus99 is offline
