1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Q for those with AGX's
Old Oct 22, 2002 | 07:29 AM
StygianMax's Avatar
I went to the track for the first time on Oct. 19. I had my AGX's set to 8 in the rear. I varied the fronts from 4 down to 1 over different runs. As it turns out, my best #s were achieved with the fronts being set to 1.
Q. What do you guys have you settings at for racing?
Here are my best times:
60 ft..........2.271
330 ft........6.378
1/8 ET........9.771
1/8 MPH.....73.78
1/4 ET......15.018
1/4 MPH......93.37
btw, my Toyo FZ4's were horrible! Tire squeal shooting out of the hole throughout first gear & major chirp in 2nd. I need new tires! & learn how to modulate the gas pedal better.
Old Oct 31, 2002 | 12:42 PM
Requin6's Avatar
hey felix...i had mine set all the way tight (4/8) on 4 consecutive 14.80 passes. i ran on the stock "sawblade" wheels, intake, and y-pipe. i had no problem with traction off the line...i do chirp 2nd though. i only launch at 1800rpms so traction is usually not an issue.
Old Oct 31, 2002 | 05:16 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
im auto...
26 psi front/ 40 rear
2/8 front/back agx settings
on 15 inch steelies.... i've pulled a 2.25 60' with this setup.
Old Oct 31, 2002 | 07:10 PM
StygianMax's Avatar
Hey Paul!
Man, nice time! What kind of tires do you have? I launched at 1500 & my Toyo FZ4's squealed like a pen of pigs! The tires are about 1/2 their tread depth. Maybe there's a problem there?
My front tires were around 26 psi & rears 35 psi. What did you have your pressures set to?
A buddy of mine has a nearly stock '97 (only has intake) & he got 15.08x. I have a bunch of plumbing for the exhaust & could only get a 15.018. Something doesn't seem quite right.
seximagtrThx for your feedback too!
Maxima_Joe
Nov 25, 2015 08:19 AM
maxima-junky
Oct 7, 2015 06:13 PM
Maxima_Joe
Aug 27, 2015 12:01 AM
mcros
31
Dec 26, 2001 03:24 PM
