1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Am I doomed with my heavy wheels
Old Dec 2, 2002 | 08:37 AM
I30tMikeD's Avatar
I always knew I had heavy wheels. Recently found out my 17" ASA KA3's weigh 23.5 lbs each!! Add my 950's and I am at 45 lbs.
I have been to the track once, and am too embaressed to post what my ET was. I was only able to pull a 2.28 60', which was probably due to my lack of expierence.
How much of the 1/4 mile are heavy wheels effecting me? Just the 60 foot? All the way to 1/8 mile? Is there any point to continue moding untill I get lighter wheels? Are there 5-speed 4th gens getting mid 14 sec 1/4 miles with heavy wheels?
Also.
I am a little encouraged by the fact that I had my shift points backwards. I was shifting at 6200 1-2, 6500 2-3. Finishing in 3rd. I should have shifted 6500 1-2, 6200 2-3. I did correct my shifting error on the last run. The last run(with the correct shift points) I was able to match my best run(with incorrect shift points) even though I missed 3rd gear and finished in 5th. This tells me my shift points were my real problem maybe not my wheels???
I am driving a 96 I30t 5-speed. Only had an intake at the time. Any input?
Old Dec 2, 2002 | 10:13 AM
ejj's Avatar
ejj
Re: Am I doomed with my heavy wheels
Also.
A 2.28 60' time isn't bad at all. Its quite good on street tires actcually.
I found that going to a heavy 17" wheels setup to a 15" steel setup dropped my time from 14.7 to 14.5 without any other changes.
I purchased (and have for sale!) a light set of rims (16" 300zx) with drag radials for track use. Just swap 'em on when you go to the track.
Old Dec 2, 2002 | 01:43 PM
Nealoc187's Avatar
SLOW
Mike, your wheels are actually not that heavy for 17's. The set of 15" aftermarket alloys (not stock) that came on my car were 41 lbs.
I found that in changing from a 36lb (light) wheel/tire combo to a 30lb (really really light) wheel/tire combo I gained about .1s and 1mph. So let say you got a 36lb combo, you are probably looking at a similar improvement. I think it was your shifting strategy that was holding you back. You've probably got .3 seconds hiding in just that. We'll head to the track in the spring and I bet you run much much better.
Old Dec 2, 2002 | 03:14 PM
I30tMikeD's Avatar
I was hoping you would respond.
So you think my main problem was just my backwards shifing strategy. You were actually the one who corrected me on my shift points. I only got one run after you informed me but I missed 3rd
My best run with fuked up shifting was just about equal to my run with missing a gear and shifting correctly. I had a .2 sec advantage at the 330' with a 6500 1-2 shift.
I really do not want to drop more money on wheels and tires.
Check your PM's later tonight concerning my brake set up for the race track this summer. I will have to upgrade before I do any hot laps.
later, I got some one-piece cefiro headlights to install tonight
Old Dec 2, 2002 | 10:27 PM
Dave B's Avatar
Not DAVEB the parts guy
Why waste money on wheels and tires when the stock 15s will do just fine? A 45lb wheel combo isn't terrible seeing that the OEM 15" wheel/tire setup weighs 40-42lbs.
Dave
Old Dec 2, 2002 | 10:36 PM
I30tMikeD's Avatar
Dave
My stock set up weighed 34lbs. I had the touring BBS wheels which I guess accounted for the lighter set up. I don't know the weight of the rim by itself.
I would put on the stockers if I had not sold them.
Old Dec 4, 2002 | 12:21 PM
Dave B's Avatar
Man, that sucks. Those BBS would have been flat out ideal. Essentially the 15" BBS wheels would have weighed ~12-13lbs.
I hate to be the bearer of bad news, but I think your 17" combo weighs more than 45lbs. I weighed my brand new 17" ASA LS5 rims with 235/45 Sumitomo HTR+s. Total weight was 42lbs. The LS5s weigh 17lbs which means my tires weigh ~25lbs which is normal for a 235/45. Have you weighed your wheel combo? Because I believe the 950s weigh 25-27lbs in the 225-235/45 sizes and team that with a ~24lb wheel and you're looking at a 49-51lb wheel combo.
Dave
Old Dec 4, 2002 | 02:58 PM
I30tMikeD's Avatar
Dave
Why you gotta tell me that **** dave
Your right, I checked into my combo weight a little more. I got the 45lb combo weight from weighing them on my bathroom ditgital scale. I actually got 45.5lbs. Not the most scientific method.
Looked up the specs on my 950's. 29lbs for the 235/45 R17!!! Which give me a grand total of 52.5 lbs. That sucks!!
Now my stock set up was The forged touring BBS 15" wheels with Turanza 205/60 R15 which weigh 20 lbs each. I had the combo weighed by a postal scale for shipping purposes and they were at 34lbs. So my stock BBS wheels were 14lbs each.
This is not good. 52.5 lbs, that has to be hurting me. I should have never sold my stock wheels. It was one of those things I did before I knew much about unsprung weight. I did fetch a hell of a price for them on Ebay though. Which ultimately paid for my new rims.
The Wizard
24
Oct 1, 2015 08:47 PM
ajahearn
Sep 19, 2015 03:03 PM
pktaske
Sep 4, 2015 08:40 AM
