1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Have a big problem with my horrid time....Take a look..HELP!
Old Feb 23, 2003 | 04:10 PM
99Maxima5sp's Avatar
Ok, well my first attempt at the track last weekend yeilded me a 15.6sec time, granted this was in horrible conditions. I went back to the track today to find out i was still running where i shouldnt. My best time was a 15.01 and just shy of 92mph, WTF? I know i should be weeeell into the 14s with my Y-pipe alone. And yes, i can drive a 5sp very well, my friends stock 5sp (except for panel filter) ran a 15.1 today. Has anyone had any problems with their Y-pipe, more particularly the flex section collapsing?! I havent got to take a look at it yet...
eric
EDIT: Also, ive raced my friend in his 5sp, and i cant pull at all on his car (from a roll) like i should...
Old Feb 23, 2003 | 04:11 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
can you post your slips please?
Old Feb 23, 2003 | 04:50 PM
Ok, heres some pics, sorry if some are fuzzy, took um with my diggy real quick (no scanner)
those were the best out of my 26 runs i made today
eric
Old Feb 23, 2003 | 04:52 PM
the rest
eric
Old Feb 23, 2003 | 05:26 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
hmmm. i was hoping to see high 60 ft's or something. Everything on your slips look to be in order and consistent. is your car cali spec?
Old Feb 23, 2003 | 05:45 PM
well my 60fts arent impressive by any means...kinda bad i think, i could use some better tires ( running on non-grip friendly allseason-540treadwear rated tires), but thats the thing, everything looks consistent, but SLOW, my friend ran almost as fast as i did (.1 off), not something that should happen when a y-pipe joins the equation..
eric
Old Feb 23, 2003 | 07:04 PM
Nealoc187's Avatar
SLOW
Your car is definately not making the power it should be. What elevation is your track at? Check that Y-pipe too.
Old Feb 23, 2003 | 07:25 PM
im in FL, so below or right at sea level pretty much... Yeah, thats my thoughts...gonna be checked in a coupla days...
eric
Old Feb 23, 2003 | 10:33 PM
Victim64's Avatar
eric
Yeah, that looks like you still have a stock y-pipe? What type of y-pipe is it anway?
My car at 500ft ran the times in my sig with just y-pipe and intake, so my bet is on a bad flex section.
Old Feb 23, 2003 | 10:34 PM
Victim64's Avatar
Oh, you did take the subs out of the trunk right??
Old Feb 23, 2003 | 11:45 PM
VeeTec's Avatar
My times went from 14.4 to 15's, once my y-pipe closed up almost completely.
If you have a Cattman, I would suspect thats the problem. That was with my 97 SE 5 speed, with JWT Intake, 2.5 inch custom exhaust, and the Cattman Y-Pipe.
Old Feb 24, 2003 | 07:05 AM
MaxSpeedSE's Avatar
eric
What track do you go too? I live in FL
Old Feb 24, 2003 | 07:11 AM
maxfreak_98's Avatar
Those times aren't too bad. And you improved almost a half second from last week, so you're going in the right direction.
Are you keeping the car in third gear at the end, or are you going to fourth? I know our cars lose power past 5.5K but I've gotten my best times leaving it in third.
Also, what's the condition of your spark plugs/fuel filter?
An intake wouldn't hurt either
Terry
Old Feb 24, 2003 | 09:04 AM
Victim64's Avatar
Terry
I think it depends on how fast you shift. I was never able to break 15's stock while leaving it in third, but a quick snap into 4th put me into 14.9's? This of course has been discussed and beat to death though lol
Old Feb 24, 2003 | 10:13 AM
ok... My best runs were by launching a tick over 2Gs with minimal spin and no bog, and leaving it in 3rd all the way, however i was at or past the redline every time (6600). My Y-pipe is from Budget exhaust. And yes, those are the times of a STOCK (exception of K&N panel filter) MAx, friends ran a 15.1-- with very similar 60fts...I went to Desoto Speedway in bradenton...also my tires were set at 19psi with my best run...
now my pipe is coming off wednesday for a meticulous check and i pray somethings wrong, it doesnt pull like it used to, perhaps a collasped flex section?
eric
Old Feb 24, 2003 | 11:15 AM
Quicksilver's Avatar
OT n00bs FTMFCSL
eric
If it's not pulling, it's probably not breathing very well (from one end or the other). If everything in the intake system is good, then I'd say it's the exhaust.
Old Feb 24, 2003 | 12:35 PM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
Try shifting to 4th at around 6000rpm instead. Also, where are you shifting at up through the gears? The 4G motor has no top end, so it's actually quicker if you short shift a little bit. Redline on the 1-2, about 6200-6300 on the 2-3, and about 6000-ish on the 3-4.
19 psi is a little low and might actually be slowing you down even more. Try lower 20's instead. Also, considering all the stereo equipment in your trunk, your 15.01 @ 92 really isn't a bad time. How much would you estimate all of that stuff weighs, and did you remove any of it? It can make a pretty noticeable difference.
eric
Just because one person gets a 14.7 with only a y-pipe doesn't mean that you will too. I know Dave B has mentioned this in another post, but all tracks are different. If you can run a 14.7 at one track, you might not be able to get below a 15.0 at a different track.
Have you dynoed your car at all?
Old Feb 24, 2003 | 03:16 PM
MaximaRider's Avatar
the only advice i can give you is to work on your R/T. I say this because on one of your runs you have a 1.25~ reaction, i am sure that run could have been in the high 14's with a better R/T.
Old Feb 24, 2003 | 03:47 PM
Victim64's Avatar
R/T has absolutely nothing to do with ET!!!
Old Feb 24, 2003 | 04:22 PM
Nealoc187's Avatar
SLOW
Pet peave?
Old Feb 24, 2003 | 06:30 PM
well obviously RTs mean squat, you can sit there for 25minutes and still run a 14.5 , all they determine is your REACTION TIME from the moment the lights turns green and you move...And when i wanna get a kick *** RT, i can, got a .522 last week
anyways, 19psi is a bit low, but they provided the best and worst grip of the day. You have to remember, first im running on wrong sized tires, its what came from the dealer, small *** 205/55-16s, and they have a 540treadwear rating, their hard as rocks compared to my last tires on my old car (Yokos AVS ES100, great tires!) I tried lowering the pressure to about 25, they built up to around 28, lowered to about 21.5, and the built up to 24.5, so i just decided to go real low (19PSI), and low and behold, i had my best run IMMEDIATELY after that, a 15.01.
Also, i had my stereo removed , and i guestimate it weighs 60-70 (?) lbs, not to heavy. I mean i tried everything to get a better time, even removed my filter, lol, that yieled a .1 SLOWER time, consistently....
And quicksilver- theres no way it can really be my exhuast itself, ive noticed the downfall in power AFTER i installed the y-pipe. When i first installed it, i couldnt grip in first, i could floor it at any time in first and i would lose control a bit from lack of grip, yeah that doesnt happen now. I dont get that wonderful pull, all i get now is a rediculous rasping noise thats getting worse and worse, almost sounds like a damn air leak now coupled with ratting. I know its got to to with that damn y-pipe and i hope it does...
ill keep you guys posted since its getting looked at real soon
Oh yeah, also, has anyone had their Cat prematurely clog after installing the Y-pipe, since its letting more **** go to the actual cat. Just curious...
And another question, i noticed that when i was crossing the line on one of my runs, i saw the speedo well over 95ish mph, yet my slip said 91 and change, wtf? are our speedos that far off at that high of speed? I remember reading something that one of the org members said, saying that the max speedo is 3mph off??
eric
Old Feb 24, 2003 | 07:15 PM
Victim64's Avatar
Pet peave?
Yep.
Old Feb 24, 2003 | 07:27 PM
OT n00bs FTMFCSL
Dude, that's what I'm talking about. Your Y-pipe is part of your exhaust now...so R&R it, make some more runs, then see if that helps.
Old Feb 24, 2003 | 09:53 PM
Victim64's Avatar
qn[
Old Feb 25, 2003 | 05:57 AM
SteVTEC's Avatar
Your 1/4 mile trap speed is averaged over the last 60' (I'm pretty sure it's 60 feet) so the speed on your slip will be slower than the speed on your speedometer. Plus the speedo is probably at least 2-3 mph fast at those speeds.
Go get your car dynoed and see what it's putting down to the wheels. I think that's the best thing you can do at this point. Either it's putting the power down or it isn't and there's something wrong, and a dyno will help to determine that.
Old Feb 25, 2003 | 07:33 AM
Victim64's Avatar
qn[
not sure what the hell happend to this post of mine, but it was basically what stev said? lol
Old Feb 25, 2003 | 07:35 AM
Victim64's Avatar
I am anxious to get my car dynoed too. Would like to see the A/F/R. That would be part of the dyno right?
Old Feb 25, 2003 | 09:59 AM
theres no dynoes near me that i know of, i live in Spring Hill, FL 45mins or so north of tampa, anyone know of one near me?!
eric
Old Feb 25, 2003 | 10:04 AM
MaxSpeedSE's Avatar
eric
Jacksonville, FL here
Old Feb 27, 2003 | 05:41 PM
AssyrianRacer
Whao
Something is wrong here, Maybe its a worn out injector or something. Get a tune up. Are you elavated at all, elavation=Slower times
Old Mar 11, 2003 | 07:21 PM
Mal5spdMax's Avatar
AssyrianRicer id like to see you go to the track see if you can still beat that z28...
Old Mar 12, 2003 | 02:06 PM
StygianMax's Avatar
Was the humidity level high during your runs?
Old Mar 12, 2003 | 08:41 PM
nope. Weather was great, got a lil hot toward the end of the day...
eric
Mar 12, 2020 12:06 AM
JoshG
51
Sep 21, 2015 10:41 PM
slowlifer
Sep 8, 2015 05:53 AM
