1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
ran the 1/4 mile today
Old Mar 16, 2003 | 02:02 PM
bill4max's Avatar
I have a 97 5-speed with a budget y and frankencar intake. I took it to the strip today and turned up 15.5 and a 15.6 backed by another 15.6. I am a little disappointed as i thought my car would do better than that. My 60 foot times were 2.25 and 2.26 and my mph was 88-89. I thought i would run a 14.8-15.2, Maybe its the bad Knock Sensor?
Old Mar 16, 2003 | 02:04 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
Re: ran the 1/4 mile today
What would back knock sensor do? would you get a CEL for a bad Knock sensor??
Old Mar 16, 2003 | 02:05 PM
CoasTek240's Avatar
hey those are decent times... whats a franken car intake?
Old Mar 16, 2003 | 02:08 PM
Vyrus's Avatar
They are decent but definitely could be better. www.FrankenCar.com for the intake.
Do you use premium gas? When was the last time your oil was changed? Spark plugs? What was the weather? Most '97+ don't have the knock sensor problem but its definitely worth looking into.
-Cyrus
Old Mar 16, 2003 | 02:13 PM
Craig Mack's Avatar
All YOUR grammer belong to me
No, those times suck, no offense, just being honest. A 4G 5spd with i/y should be in the 14's. Your trap speed should be in the low 90's, so it suggests that your car is sick or that your way above sea level. Also, a bad knock sensor can really kill performance, so if your's is bad then that's why.
Old Mar 16, 2003 | 02:16 PM
bill4max's Avatar
i was only 800 feet above sea level ultra 94 octane gas temp was like 65 degrees and my knock sensor is bad as i have checked it.
Dev's Avatar
Dev
hey, could you give all the figures from your timeslip?
seems like you're driving damn good judging by the launch, but your max isnt making as much power as it should be.
trap speed is low - indicator of lower than normal power, esp for intake/ypipe.
check your engine codes for knock sensor (won't have CEL), spark plugs, ignition coils, fuel injectors, clean throttle body. something is holding you back from making a lot more power.
once you find it...you're definitely in the 14's
Old Mar 16, 2003 | 02:17 PM
KsuMax's Avatar
Cheesing away...
Run the codes from the ecu and see if you get the knock sensor code.
Old Mar 16, 2003 | 02:23 PM
bill4max's Avatar
R/t .622
60' 2.259
330 6.539
1/8 10.048
mph 70.18
1/4 15.655
mph 88.31
And
R/T .795
60'2.255
330 6.491
1/8 9.996
mph 70.29
1/4 15.596
mph 88.62
Old Mar 16, 2003 | 02:55 PM
1SikMax's Avatar
60'2.255
330 6.491
1/8 9.996
mph 70.29
Wow, that is what I usually run in the 1/8th. That's with everything stock and 80 degrees outside and 80% humidity. I hope it's just your knock sensor.
Old Mar 16, 2003 | 04:29 PM
Dev's Avatar
Dev
if you're stick then thats pretty bad too. if you're auto then tahts right on target.
bill4max, switch up that knock sensor for a good one, and im pretty sure you will see a 0.8 second improvement
Old Mar 16, 2003 | 04:54 PM
deezo's Avatar
R/t .622
60' 2.259
330 6.539
1/8 10.048
mph 70.18
1/4 15.655
mph 88.31
And
R/T .795
60'2.255
330 6.491
1/8 9.996
mph 70.29
1/4 15.596
mph 88.62
Check your knock sensor. You should be running much faster than that with your good 60' times. I ran 15.62 with a stock automatic.
Old Mar 16, 2003 | 08:16 PM
Nealoc187's Avatar
SLOW
Looks to me like your car is down about 40 hp from where it should be. Better start checking things, your traps should be about 6-7mph higher than they are.
Old Mar 17, 2003 | 08:20 AM
bill4max's Avatar
well my ks is bad definetlly as code 0304 comes up by itself also i have checked it and there is no resistence meaning an open circuit. I dont get it though because i have good 60 foot times. Do you think more is wrong than just the knock sensor?
Old Mar 17, 2003 | 08:30 AM
ejj's Avatar
ejj
Yes, your 60' times are good, but you aren't making any top-end power with a dead KS.
Doubt it.
Old Mar 17, 2003 | 04:46 PM
virus99's Avatar
Doubt it.
how can u tell if the knock sensor is bad?
Old Mar 17, 2003 | 06:51 PM
Dev's Avatar
Dev
car will feel weak
and if you check your engine codes from teh ECU, it will show 0304
pktaske
May 6, 2016 07:49 AM
captchaos
Mar 15, 2016 12:18 PM
pktaske
Sep 4, 2015 08:40 AM
crazyespn
Sep 3, 2015 01:30 PM
