what are the mph at which a 2k2 auto shifts at during each gear under wot? im going to the track soon hopefully and im probably going to keep the shifter in 3. however, i might manually shift and if infact i do id like to know at what mph redline is during each gear.
Quote:
go out and figure it out man. every driver will be slightly different. If you feel a loss in power at the top of the RPMs shift to 4th...my guess is you will have to go to 4thOriginally posted by slickrick
Quote:
Originally posted by Nealoc187
He's in an auto... an auto can probably go to 130mph in 3rd gear. He won't have to shift to 4th.
neal knows best...i was just guessinOriginally posted by Nealoc187
actually im jus curious
ive seen a mildly modded 02/03 max "6spd" get into 13s...
is it possible for an auto with removed spare, full street trim, good tire PSI set up(stock tires), and full interior to get high high 13s jus with intake, ypipe, and UDP? or maybe only low 14s at best......?
hey, i got an 02 gxe auto max, and all i did was add a 25 dollar cone air filter from autozone and i ran a 14.59 at 95mph with a 60" time of 2.259. Everything else was stock, and i had my spare out. So low 14's should be easy with more upgrades. Hope this helps!
Quote:
any slips? thats a great time.Originally posted by dlyrikal
