1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
2K2 6spd---Slow traps?
Old Apr 23, 2003 | 08:43 AM
SEturner's Avatar
Hi,
I took my bone stock (down to original air filter) 2k2 6spd Max to track last night. All "normal stuff" was in car including spare, golf clubs, single sub box, and my 240 lb lard butt. My best run:
R/T............ .446 Here, .000 is redlight
60'............ 2.323
330............ 6.323
1/8............ 9.603
MPH............ 75.68
1000........... 12.419
1/4............ 14.804
MPH............ 94.65
Ran against modded 2k2 Mustang GT (exhaust, had aftermarket hood?)
.... Me .............. Him
R/T .... .280 ............ .515
60' .... 2.457............ 2.154
330 .... 6.444............ 6.077
1/8 .... 9.720............ 9.270
MPH .... 75.54............ 77.85
1000 .... 12.555........... 11.995
1/4 .... 14.958........... 14.298
MPH .... 93.64............ 97.91
I was Smokin'(getting smoked). My wheels hopped so bad, my wipers came on. Also, got caught staring at 'Stang instead of tach, and hit limiter in second. My other run was a 14.97@93.66MPH against modded lightning. I almost had him 12.222@111.05
Old Apr 23, 2003 | 11:54 AM
Dave B's Avatar
Not DAVEB the parts guy
Re: 2K2 6spd---Slow traps?
Originally posted by SEturner
Hi,
Though many will COMPLETELY disagree with me, I think your car is running normal. I've never seen any spectacular topend from the 2k2+ as witnessed by running against a G35 and 2k3 6 speed at my track. Get your 60 foots into the lower 2.2s and you'll be looking at 14.6s@95mph.
Dave
Old Apr 23, 2003 | 03:22 PM
2k2PhatMax's Avatar
Sold 2 99Silvermist SE :)
Re: Re: 2K2 6spd---Slow traps?
Dave
i also have 2.4-2.5 traps... i do u get them lower... i know its possible cause i seen slips...
and um my wipers have come on 2... embarrassing!!
Old Apr 23, 2003 | 04:16 PM
TheMax95's Avatar
Re: Re: Re: 2K2 6spd---Slow traps?
I can't even imagine. You must have had some very intense wheel hop. Try to go easy on the launch, maybe rev lower and slip the clutch quicker I don't know. Wheel hop sux and is scary. I know I've been through it in my max.
Old Apr 25, 2003 | 07:31 AM
2K2_6spd's Avatar
Take all that crap outta your trunk, and get those 60's down. I regularly cut 2.2 60's in my 2k2, and trap around 99-100mph with just a couple of mods. When mine was bone stock it went 14.55@96.
Old Apr 25, 2003 | 07:39 AM
SEturner's Avatar
What is your technique for launching? My times and speeds look like I would get similar numbers to yours stock if I got my 60' down.
Old Apr 25, 2003 | 07:44 AM
2K2_6spd's Avatar
I launch like I'm leaving a stoplight, just get the clutch fully engaged while gradually applying the throttle, when the clutch is all the way up, nail it. And shift at a tach indicated 6800, or just into the redline, this will keep you in the powerband. That should get you there, just be smooth, smoothness is the key. And that clunking noise you're hearing.....sounds like you broke a motor mount.
Old Apr 30, 2003 | 05:11 PM
JoesMAX's Avatar
when i went to the track i was trapping at 97 mph, but my ET's were only in the 14.7's due to bad traction at the track
(all i had was an intake at the time)
and 2k2, i was thinking about trying that method, thats what i usually do if im messing around off the line when its cold out, since my tires will spin way too easily in 1st when its cold out
Old Apr 30, 2003 | 07:56 PM
Chinkzilla's Avatar
Dave
Why are you such a hater?
I ran 14.4 with a crappy 2.3 60' at 96 mph... maybe he just had too much crap in his trunk?
Old Apr 30, 2003 | 08:15 PM
SEturner's Avatar
As far as driving skills....
My launches were low 2.3s on other runs, which is not good, but not horrible. I nailed every gear shifting very fast, in fact I think spinning in 2nd may have slowed me down. What was apparent was that with my trap speeds, there was no way I was going to do a whole lot better than I was. My car, with good shifts, was only gaining 18mph over the last 1/8.
TallTom
57
Oct 14, 2025 05:16 PM
ArcticMax
Mar 13, 2001 10:27 AM
JimW
Nov 20, 2000 05:57 AM
madmax2k
Nov 1, 2000 12:04 AM
