1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
NHRA Facts
Old May 8, 2003 | 04:26 AM
Jime's Avatar
NHRA Facts
This may have been posted before but I haven't seen it, thought it was pretty interesting.
COOL NHRA FACTS:
One top-fuel dragster's 500-inch Hemi makes more horsepower than the first 8 NASCAR rows at Daytona.
Under full throttle, a dragster engine consumes 1 1/2 gallons of nitro per second, the same rate of fuel consumption as a fully loaded 747 but with 4 times the energy volume.
The supercharger takes more power to drive than a stock hemi makes even with nearly 3000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into nearly solid form before ignition. Cylinders run on the verge of hydraulic lock.
Dual magnetos apply 44 amps to each spark plug. This is equivalent to the output of an arc welder in each cylinder.
At stoichiometric (exact) 1.7:1 air/fuel mixture (for nitro), the flame front of nitromethane measures 7050 degrees F. Nitromethane burns yellow. The spectacular white flame seen above the exhaust stacks at night is raw burning hydrogen, disassociated from atmospheric water vapor by the searing exhaust gases.
Spark plug electrodes are totally consumed during a pass. After 1/2 way, the engine is dieseling from compression-plus the glow of exhaust valves at 1400 degrees F. The engine can only be shut down by cutting off it's fuel flow.
If spark momentarily fails early in the run, unburned nitro builds up in those cylinders and then explodes with a force that can blow the block in half.
Dragsters twist the crank (torsionally) so far (20 degrees in the big end of the track) that sometimes cam lobes are ground offset from front to rear to re-phase the valve timing somewhere closer to synchronization with the pistons.
To exceed 300 mph in 4.5 seconds dragsters must accelerate at an average of over 4G's. But in reaching 200 mph well before 1/2 track, launch acceleration is closer to 8G's.
Drivers shut off before the finish line, or even dual parachutes will not stop the car.
If all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs $1000.00 per second.
Dragsters reach over 300 miles per hour before you have read this sentence.
Old May 8, 2003 | 04:36 AM
Blu's Avatar
Blu
the tits
interesting facts
Old May 16, 2003 | 10:01 PM
luckee2bhere's Avatar
****...slightly over my head for some stuff...but interesting nontheless...whats also interesting is how fu ckin much I hate my dad right now for treating me like a 10 year old and not lettin me watch a movie with cursing in it........WHAT THE FU CK, ****, cocksuker motherfu cker..argh!!!!
Old May 20, 2003 | 11:35 PM
HitManSE's Avatar
I actually saw this on a Z06 forum a few months ago.
Old May 21, 2003 | 08:12 AM
Nismo3112's Avatar
Custom User Title
Re: NHRA Facts
nothin my max can't handle
PSh YEAH RIGHT!
Dam those things are quick
Old Jul 16, 2003 | 03:33 AM
MrGone's Avatar
are all dragsters big block mopars?
Old Jul 16, 2003 | 08:02 AM
HitManSE's Avatar
What leads you to belive that? Just because alot are Hemi does not mean that Mopar is the one making the engines.
Old Jul 31, 2003 | 06:19 AM
SR20DEN's Avatar
VQ Wizard
There are two block manufacturers in Top Fuel. I believe they are Fulton and Keith Black.
Old Aug 1, 2003 | 07:45 AM
Maxtank's Avatar
how can the drivers shift pulling 4+ g's in a couple of seconds?
Old Aug 1, 2003 | 07:56 AM
SR20DEN's Avatar
VQ Wizard
There is no gear shifting in Top Fuel.
doctorpullit
Jul 20, 2019 09:31 PM
doctorpullit
Dec 12, 2015 09:39 AM
Turbonut
46
Oct 21, 2015 08:28 PM
fastcarny
Oct 12, 2015 07:06 AM
carid
Sep 9, 2015 05:06 AM
