1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
horrible times
Old Sep 17, 2003 | 11:04 PM
quansung 2's Avatar
horrible times
just got back from the drag strip and my car is running horrible. 64 deg and low humidity i could'nt do any better then 14.7 at 94mph and a 14.8 at 93mph ,my 60 ft was 2.3's for both runs.usually a 2.3 60ft would get me a 14.4 at 97mph .i did'nt change anything on the car and ran with about 3-4 gallons of gas. the last time i got times like this it was 90 deg at the track.
Old Sep 18, 2003 | 07:06 AM
TheMax95's Avatar
damn bro whats up with ur car? traction problems? Last time I saw you at the track u said you were getting some slicks. Changed your mind?
-Paul
Old Sep 18, 2003 | 07:29 AM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
The decent 60' shows the engine is still making decent torque, but the low trap speed suggests that you're missing a lot of top-end.
Are you sure your variable intake manifold is still switching over at 3800 rpm like it should? Stuck variable intake manifold is not a common problem, but not unheard of either. There are maybe a dozen or so 00-01 guys that have had this issue. I wouldn't be surprised if it pops up on the vq35's also.
Old Sep 18, 2003 | 07:30 AM
Blu's Avatar
Blu
the tits
try this:
http://forums.maxima.org/showthread.php?t=249106
Old Sep 18, 2003 | 07:31 AM
NYCe MaXiMa's Avatar
maybe it's the 18s?
didn't you say you bogged a little on one of the runs?
Old Sep 18, 2003 | 08:09 AM
SteVTEC's Avatar
18's would hurt, but not that much.
Old Sep 18, 2003 | 12:06 PM
TheMax95's Avatar
yea they wouldn't hurt that much. He has Mile Miglia Evo5 rims which are about as heavy as the stock 17" rims on the 02-03 Max. I think you should get the slicks since you go to the track so often and I see you there everytime I go to etown.
-Paul
Old Sep 18, 2003 | 01:31 PM
quansung 2's Avatar
well looks like your right it's not switching over , before when i went wot as soon as it hits 3800-4000 rpm you feel it kick in ,now there's no bump in power till redline. does anyone know how to fix this?
Old Sep 18, 2003 | 04:20 PM
SteVTEC's Avatar
Oh beautiful.
Quick checks you can do yourself are the vaccuum lines (wherever they are) to the actuator and make sure they're not kinked or blown off. Try your hardest to figure out what is wrong and fix it yourself, because many the 00-01 DE-K guys that have had this issue have had a bear of a time convincing the Nissan service idiots that there was even something wrong to begin with.
Try searching in the 5th Gen forum with various combinations of "VIAS intake manifold stuck jammed" as your search terms and you'll find the old threads. Most of the threads will probably be 00-01 guys, but the key info to pick up on is how they got Nissan to actually fix it. You might find some diagnostic tips also.
Old Sep 19, 2003 | 05:19 PM
quansung 2's Avatar
reset the ecu ,drive by wire ,and checked for loose hose and wires. just got back from the track and ran a best of 15.09 at 90 mph with a 60ft of 2.309 . ran 3 times my highest trap speed was 91mph , i'm taking the car to the dealer monday.
Old Sep 19, 2003 | 05:35 PM
SteVTEC's Avatar
ouch. good luck
Old Sep 19, 2003 | 07:04 PM
Larry H's Avatar
shoot dennis, sorry to hear that all that stuff didn't fix the problem. hope you have her up and running in no time...
Old Sep 22, 2003 | 09:28 AM
quansung 2's Avatar
i'm running a 2001 maf which causes a ses light so i borrowed a 2k2 maf ,reset the ecu and took it to nissan this morning. they did'nt find any codes , they said that bad coils ,vias controler and transmission would throw a code .i also had my timing advanced to 17deg a few months ago ,i'm thinking if 87 oct fuel was used it would cause a drastic decline in performance. i'll be going on the dyno later today hopefully i see some good #
Old Sep 22, 2003 | 09:53 AM
SteVTEC's Avatar
they said that bad vias controler would throw a code
That's not what I remember from the VQ30DE-K guys woes. The only things that will throw a code (usually) are things that can affect emissions. The VIAS has nothing to do with emissions - only performance - and therefore would most likely not throw an SES.
That sounds like an excuse to not do a warranty repair to me.
Old Sep 22, 2003 | 12:34 PM
quansung 2's Avatar
i just put my car on the dyno ,181 hp and 208 ft-ibs uncorrected. i'm going to check my spark plugs.
Old Sep 22, 2003 | 12:59 PM
SonicDust187's Avatar
Hey Dennis. How much was the dyno?
Old Sep 22, 2003 | 01:02 PM
Blu's Avatar
Blu
the tits
wow something is definatly wrong. I would check the compression while your checking the plugs.
Old Sep 22, 2003 | 01:04 PM
quansung 2's Avatar
75$ for 3 pulls.
Old Sep 22, 2003 | 01:09 PM
Wow man, nice price. I may want to dyno my car in a few months. I still cant understand how you were able to stay with me on the highway while I was spraying.
Old Sep 22, 2003 | 04:47 PM
quansung 2's Avatar
i think my car was running ok that night but got worse later. here's the dyno
Old Sep 22, 2003 | 04:59 PM
still, I am making like 300 flywheel hp, I should have pulled on your 240 flywheel hp rating.
Old Sep 22, 2003 | 05:36 PM
quansung 2's Avatar
the air fuel ratio chart shows my max as 17.5 at 3300 rpm then it skydives down to 11 at 3500 and hovers around 11 to 12 until fuel cut off, is that normal?
Old Sep 22, 2003 | 08:24 PM
SteVTEC's Avatar
Your VIAS is definitely working.
Old Dec 15, 2003 | 12:07 PM
quansung 2's Avatar
here 's an update. after 4 months and 4 dealers found out one of the problems was multiple cylinder misfire so i had the coils ,spark plugs , injectors and throttle body replaced and cleaned and now i dyno 188hp at 4800rpm and 226tq .
Old Dec 15, 2003 | 12:10 PM
deezo's Avatar
You may have a lemon.
Old Dec 29, 2003 | 10:50 AM
2k3TitaniumSe's Avatar
So, is your car better now. Go to the track and post your results.
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
kjlouis
Oct 3, 2015 05:29 AM
trungg86
Sep 4, 2015 04:58 AM
Wareagle92
Sep 3, 2015 07:18 PM
