1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Disappointed with my first time
Old Oct 24, 2003 | 10:41 PM
worm's Avatar
I had a lot of fun but my best time was only 15.9 about 85mph with a 60' of 2.3xx. Ill post the full slips later but i just wanted to get some basic feedback.
Old Oct 25, 2003 | 12:39 PM
worm's Avatar
Here is all the info from the timeslips:
Temp 41 degrees, humidity 0, barometer 31.3
(1) RT...1.134
60'...2.399
330...6.823
1/8...10.459
MPH...68.23
1000...13.568
1/4...16.244
MPH...83.70
(2) RT... .936
60'...2.415
330...6.724
1/8...10.282
MPH...71.15
1000...13.340
1/4...15.969
MPH...85.76
(3) RT...1.217
60'...2.321
330...6.732
1/8...10.358
MPH...68.51
1000...13.469
1/4...16.145
MPH...83.72
(4) RT... .934
60'...2.354
330...6.747
1/8...10.350
MPH...69.36
1000...13.451
1/4...16.107
MPH...84.49
1998 SE Automatic, with an Injen intake on stock rims. These times were slower than what i expected and my trap speeds were way below. What confuses me the most is how my 60' can be faster on run #4 but i finished in a slower time with a slower speed. Its not like i couldve missed a gear its automatic. I should note that run #2 was the only one in a different lane though so maybe that couldve made the difference i dont know. Some other things that might factor are my tires are not that great, and i didnt really let the engine cool in between runs because i didnt have too much time to get a lot of runs in. Basically 4 races in 2 hours was the most i could possibly get. Any suggestions would help, thanks.
Old Oct 25, 2003 | 07:05 PM
BadKarma99-4spd's Avatar
that dosent seem all that bad, about average, not fantastic but not as bad as ive heard of. intake isnt going to do much for your times, get a y pipe.
also was this your first time?
you can check your ecu for codes?
good luck
Old Oct 25, 2003 | 10:54 PM
worm's Avatar
i knew that intake didnt matter at all, i guess i was just a little hyped up before i went. i am reading an ecu code for evap leak i think but i cant seem to find it.
Old Oct 25, 2003 | 11:31 PM
cant help you there(codes). first time plays a big part, my brother and i would screw around all the time in our cars, but when he finnally went to the track he pulled a 15.5 with his auto ls1 he now runs 13.7 consistantly after his second trip(all stock)
Old Oct 26, 2003 | 08:24 PM
Ceasars Chariot's Avatar
Old Maxima Legend
how did you launch the car ? rpms ? of course your 60 foots need working on, which would help you overall. try to get the 60 foot down a bit.
Old Oct 26, 2003 | 08:27 PM
bigdo26's Avatar
work on the launch, like everyone always says. it'll help a lot - but otherwise, not bad times. it'll come down. get the y-pipe too
Old Oct 27, 2003 | 08:14 AM
TheMax95's Avatar
I don't know if you guys noticed but he's only gaining 14-15mph in the last 1/8 mile. That's really low. Isn't it supposed to be 18-21?
I say check for codes and my guess is a bad ks.
You can definitely do better but high 15s/low 16s are typical for a stock auto.
-Paul
Old Oct 27, 2003 | 08:28 AM
Vigo327's Avatar
yeh he should be gaining a lot more on the last half.. i would suggest knock sensor, except that when the knock sensor goes bad as far as ive seen the cars have trouble breaking 17 flat let alone 16.
Old Oct 27, 2003 | 07:10 PM
worm's Avatar
Am i wrong saying that a reaction time of under 1 second is pretty decent? That felt pretty good too me, and i didnt have too much wheel spin even with the crap tires. For some reason the car just isnt at its best. Will the knock sensor show up on a computer, because i usually run a computer on the car once every 1-2 weeks. I know that i have the evap problem but i havent felt any performance loss from that, unless i just havent noticed it.
Old Oct 27, 2003 | 07:45 PM
TheMax95's Avatar
Originally Posted by worm
Am i wrong saying that a reaction time of under 1 second is pretty decent? That felt pretty good too me, and i didnt have too much wheel spin even with the crap tires. For some reason the <A TITLE="Click for more information about car" STYLE="background-color: #f0f000; " HREF="http://search.targetwords.com/u.search?x=5977|1||||cars|AA1VDw">car</A> just isnt at its best. Will the knock sensor show up on a computer, because i usually run a computer on the car once every 1-2 weeks. I know that i have the evap problem but i havent felt any performance loss from that, unless i just havent noticed it.
Yea Vigo is right. If it was a bad ks then you'd be running high 16s or even low 17s but your times aren't that off. It's just your mph and how little you gain in the last 1/8. If you were to gain say 18 instead of 15, I say you can see a 15.5.
Maybe get a tuneup: plugs, pcv, fuel filter...etc
-Paul
Old Oct 27, 2003 | 09:09 PM
worm's Avatar
The plugs are about 3 months old, awhile back i thought that was one of my problems but it was not. i need to change the fuel filter and pcv, that could be one part of the problem. Any body have any ideas as to why i finished faster in run #2 as opposed to run #4 where i started out faster, i thought that was my best run but it ended up slower, there is definately something wrong. i guess maybe i should do a full tune up, and clean the TB and everything.
Old Oct 29, 2003 | 06:36 AM
deezo's Avatar
1. Which plugs are you using?
2.You shouldn't need to change the PCV valve. Take it out and shake it. If you hear the ball inside moving, it's fine.
3. Check on replacing the knock sensor. You car seems like it's not producing a lot of power.
4. Did you reduce your cars weight?
Old Oct 29, 2003 | 07:27 AM
worm's Avatar
1. Ill have to check this weekend, im at school for the week.
3. Will that show up on a computer? If not, how do i know to replace it?
4. I did not do too much weight reduction other than a sub box.
I think that the problem may be the ECU code that i am reading right now (small evap leak). I have been trying to fix it for a long time now but i dont get too much time to work on my car. What happens is when the car is in drive but stopped, the rpm's drop about 1-2 hundred. Then sometimes if i press the gas lightly it stutters a little as well. Any suggestions...
mvm062
Nov 30, 2020 09:00 AM
kjlouis
Oct 3, 2015 05:29 AM
trungg86
Sep 4, 2015 04:58 AM
iflexsteel
Sep 2, 2015 08:04 AM
coasterswim
Sep 2, 2015 07:43 AM
