1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
my time slip numbers look a little odd..
Old Mar 16, 2004 | 11:57 AM
Zipp028's Avatar
my 1st time..
MOds- y pipe back, intake
street tires 35 psi
r/t .464
60 2.626
330 6.792
1/8 10.156 @73.34
1000 13.027
1/4 15.426
mph 92.14
is there something wrong with my car?
Old Mar 16, 2004 | 12:14 PM
Ceasars Chariot's Avatar
Old Maxima Legend
the 60 foot time looks very high, how are the tires on the car ? im thinking if you get a good launch/60 foot your times would be in a more normal area.
Old Mar 16, 2004 | 01:20 PM
MrEous's Avatar
^ Jeff™
With a 1/4 mph of 92 you should definitely be at least 3 tenths better. Your 60' definitely hurt you, I agree with Caesar.
You're 5spd I assume?
Was this your 1st time at the track?
Old Mar 16, 2004 | 06:20 PM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
Yep, your 60' time was very slow, meaning you need to work on your launch a lot. For every one-tenth you can improve your 60' time (launch) by, you'll get about two-tenths on your ET. So if you can bring your 60' time down to even a 2.3xx, you should be able to run a 14.8 or better. Your trap speed should also pickup a bit as well.
Old Mar 17, 2004 | 11:31 AM
Zipp028's Avatar
yes this was my 1st time, my tires are ok.. i didnt drop them to 25psi or n e thing.. yes this is 5 spd thanks for the input SteVTEC, MrEous, Ceasars Chariot. I will practice launching, i did seam like she bogged at the start, i guess i was a little to nervous being my 1st time and all
Old Mar 17, 2004 | 06:13 PM
Old Maxima Legend
yeah practice that launch.. it will take time to learn the track and how it hooks up, and learning the car to see what she will do.
a good light set of wheels, with some sticky tires will help you out alot. when i had the khumos on the chariot, i had much more wheel spin than the toyo t1-s. this could all be redneck theory, you might have to get steve to verify it.
but im thinking lighter car, lighter rims and smaller, and sticky tires are going to get you lower 60 foots in a maxima.
but then again im not sure.. maybe mods play a big part on this too which open up some more hp to play with.
almost forgot: i dont think there is anything wrong with you max
Old Mar 17, 2004 | 07:47 PM
Nealoc187's Avatar
SLOW
You could run a 14.8 or 14.7 if you get your 60' time into a reasonable range. You wasted at least .5 seconds right there on the launch.
Lakersallday24
Jun 16, 2019 01:35 AM
SmokinMax02
18
Sep 11, 2015 12:25 AM
Team STILLEN
Aug 10, 2015 04:29 PM
yat70458
Aug 3, 2015 01:16 PM
