1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Drag radial question
Old Oct 25, 2004 | 09:01 AM
cardana24's Avatar
Blown
I have BFG Drag radials (225/50/15) mounted on my millenia wheels now. I will be going to the track for the first time on these, so I have a few question. What tire psi should I try first 20ish? Also should I do a burn out with these or should I miss the water box? THanks for the help.
*I have a 98 five speed w/Supercharger
Old Oct 25, 2004 | 09:25 AM
I30tMikeD's Avatar
I have been going with 13psi in my DR's. I have not played around with the air pressure too much. I did try going lower than that on my last couple runs but my 60' go worse....but that was partly due to the temps.
I suggest heating them up. Without a burnout I pull 2.1-2.15 pretty easily with a 4K clutch drop.......still lost of spin so I know gettting them hot could yield me 2.0's no problem.
Old Oct 25, 2004 | 09:26 AM
Redmax's Avatar
Redlinemax Owner
ot Why did you mount DR and not slicks on those things?
Old Oct 25, 2004 | 10:06 AM
cardana24's Avatar
Blown
DR's are street legal....so if I need to drive on them I can...and I dont think I am in the position to possibly replace every thing that could possibly break with a dead hook...but I guess the bottom line is I am a wuss
-Thanks for the advise mike....I will try heating them up and see how they do. I have tested them out and I am still spinning really hard in first and going into second....but then again that with a cold tire and 30 psi in them.
-I think I will probably try ~20 psi then move down from there....
*any more advise will be appreciated
-Carson
Old Oct 25, 2004 | 12:44 PM
DonSupreme's Avatar
Cardana,
I am by far no expert but I used radials for one run at MIR last time i went.
My SCer wasn't running at the time and I dropped the clutch @ about 3.5k to 4K and they did not hook up!
I had a terrible 2.6s 60 ft. I only got one run with them and was very dissappointed.
My point is since you are going to MIR on sunday which means you may not get many runs I would do a normal street launch to start off....
I did a burn out before running, but it may not have been enough to warm them up. If I spun through first while N/A, it is more than likely it will be worse with the SCer!
Let me know how it turns out.
Old Oct 26, 2004 | 12:24 PM
Redmax's Avatar
Redlinemax Owner
I don't think your making enough power yet to be breaking things on a dead hook. Mardigras Launches at 5000rpm and hasn't broken anything yet because of his launch
Old Oct 26, 2004 | 12:31 PM
cardana24's Avatar
Blown
you need to re-read my last point Also Mardigras from stories I hear is a pretty hard core drag racer....I want a fast show car. If I want to do slicks in the future I am sure I will have no problem selling the DR's...so right now I am just trying the DR's and they feel nice....I def. need to heat them up some though...I have been riding on them for a few days just getting some bugs worked out and I am spinning pretty hard going into 3rd (not used to that on 19's)....the car feels good right now, hopefully I can dodge the rain and see what it will do this weekend.....goodluck to you on firday....put some times down that should have been putting down for a while so I can stop giving you a hard time
-also I'm PMing you
Old Oct 26, 2004 | 01:47 PM
Jime's Avatar
Originally Posted by cardana24
you need to re-read my last point ....I want a fast show car.
-also I'm PMing you
A FAST SHOW CAR is an oxymoron.
Old Oct 29, 2004 | 12:51 PM
Jason R's Avatar
aka UNCDooD
I don't make much power either but I have snapped two axles at the track on some hard launches.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
