1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
What if question - track conditions
Old Nov 12, 2004 | 05:36 AM
BEJAY1's Avatar
Conecarver
Help me guess ET changes based upon this. Day 1 vs 2.
Temperature drops 40deg.
Humidity the same within 5%.
Baro press increases about .5
Dyno cf looks like N/A car power up 5.5%
Wind on the track changes from 10mph headwind to 4mph tailwind.
Or with 5.5% more power and 14mph better wind how much would ET's drop?
Old Nov 12, 2004 | 07:50 AM
bigdo26's Avatar
if you can still get the same hookup on launch w/40 degree lower temps, you could probly drop .2 i'd guess.... but you most likely wont get the same kind of tractino on a colder track, so ET wont get a lot better. However, your trap speed will increase substantially between makin more power and having the tail wind
Old Nov 12, 2004 | 08:16 AM
Dave B's Avatar
Not DAVEB the parts guy
Drops 40 degrees from what? 120 degrees to 80 degrees? 40 degrees to 0 degrees? I'm guessing you're talking about 80s into the 40s. If that's the case, then you're looking at at least .15-.20 and 1mph+.
No change obviously.
Possibly a drop of .1 and a gain of .5mph.
From what I've seen, headwinds don't really effect ET because so much of the ET is based on the 1st 1/8th of the track, but MPHs really do suffer. I've seen 10mph headwinds suck out over 2mph. I've also seen strong tailwinds add mph. When I ran my 14.45@99.51mph, I had a 10mph+ tailwind.
In the end, I wouldn't be surprised if you could drop .3 seconds and gain over 3mph in these improved conditions.
lux97Max
Sep 25, 2015 12:07 PM
AT978
Sep 6, 2015 10:31 PM
lux97Max
Sep 3, 2015 04:51 PM
Johnny9595
Sep 3, 2015 05:18 AM
