Lowest mph to get in the 12's (slicks)
when I ran the 12.9 in my old 02 Auto the trap speed was 106. 60' was 2.0 but the tranny was dying trying to shift with all the torque. I would say 110+ to get into the 12's on street tires and 105-106 on slicks.
Yeah I agree, about 106. I ran a 13.1@105 on slicks.
http://forums.maxima.org/showthread.php?t=285089
Originally Posted by Stephen Max
Requin6 also trapped 12.9@111 mph on street tires.
Mardi is going to be impossible to catch soon. I think he's putting a built 3.5 in if I'm not mistaken. Better start concentrating on beating on us N/A guys instead.
What size where those M&H? I am planning on buying M&H 8.5x24.5x15 and I calculated that at such a tire diameter, with a 106.00 mph trap speed, I would pass the traps at around 6100 RPM in 4th gear. Considering I have a VQ35 with stock IM (peaks at around 5500), I think it's pretty good. But I am not sure the other mods (headers, CAI, exhaust system) will move the powerband a bit higher...
I don't think I will trap 106 though, not at first. I think maybe 104 without more tuning.
Yeah SR is definately going to be in the mid-12s if he gets a low 1.8 60' and maybe some more tweaking.
I am hoping for at least 13.99 on street tires. I ran 15.00 with 156whp so with 240-ish and 100 less lbs I would hope for 13's.
Depends on the year, but a safe bet is an auto Max with slicks and a shot of nitrous. A nice setup would cost around $1500. Not that much if you think about it. Oh yeah......mad skillz too
That's the best way to do it. If I ever get in the 12s with this setup, it will have cost me about (corrected to US money) 4.5k in mods, slicks included. But contrary to boost, it's on 24/7 and as reliable as a stock max.
Originally Posted by fstbusa
man how much money do you have to stick into a max to make it run 12's.... I don't want to even imagine.
http://members.cardomain.com/whoamax
I have one 104 mph 12.9 with a 35 shot but usually its in the 105 range. I also have a 105 mph 13.5 slip N/A. You have to realize that how a car is setup ie boosted, nitrous or N/A does have a bearing on the time/mph ratio. Nitrous tends to produce quicker times and lower mph time slips than turbo/supercharged application because it produces the HP right out of the hole, no waiting for it to build so its sometimes hard to compare.
Originally Posted by UNCDooD
I think with a little bit bigger shot of nitrous I could be pull off a high 12-second pass at around 107-108. I'm thinking of a 125 shot and slicks. hopefully that'll do the trick.
Originally Posted by blubyu2k2
BOOM!!!!!
got a good pass though 12.1 @ 116 mph. even though there are guys running it with no problems if there properly tuned.
Originally Posted by C MAX
aint that the truth it happened to me. 100 shot and 11lbs of boost, boom.
Yea, I was just giving him a hard time. His car should handle the nitrous just fine. 11psi and a 100shot on a stock motor untuned is asking for it, but it looks like yours held together for a good pass.
the motor was built by vinny ten. i had that motor for three yrs 60,000 miles. the way vinny had it hooked up it was fine. the crazy part was it was a dry set up but i was running a 60 shot when vinny tuned it for me. i had a big race with a audi A4 with a S4 motor pushing 19lb turbo. during testing i ran a 75 shot and it pulled hard and smooth, so i said a 100 shot should be ok. well i wound up beating the guy which i posted had him out the hole 10 cars then by the end of the 1/4 poof and over the finish line with him right on my tail. if i would of have the proper tuning and safegaurds id still have that engine today. blubyu whats the update on your car i get mine back tommorow its all ready to go with J&S safegaurd (got that idea from mardi).
it all depends, your 60' could really suck and then blast it and you could end up with a 12 sec ET and really high MPH or you could be doing brackets and see someone run 12s and let off at the end and have 12s and low mph
Apr 16, 2020 05:15 AM
