1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
PB Track times
Old Apr 19, 2005 | 07:54 PM
Epacy's Avatar
Unsuccesful STL Coordinator
PB Track times
Well, the car finally somewhat approached what it was capable of, or maybe I am just driving it better. Either way, I got a 14.82 and 14.84, the last run was with a CEL on and red lighted at 15.01.
I posted 60' times of 2.162 and 2.183, respectively. So it appears the timing advance did help some. My 60's were much better. My previous best 60' was 2.23.
14.82
93.16 mph
14.84
93.00 mph
I know this thing has 14.7's in it. All 3 runs were with the 18's on it.
Old Apr 19, 2005 | 08:50 PM
sooner02r1's Avatar
Nice work, I'm jealous of those 60' times.
Old Apr 19, 2005 | 09:03 PM
whazzzzuup's Avatar
Nice runs. With a 2.1 60' foot time, you should be able to get it down to 14.6 easily. It seems like you are not pulling very hard top end. What did you run before the timing advance? Why did you have CEL?
Old Apr 19, 2005 | 09:19 PM
S00NR1's Avatar
OU > *
Screw you eric, I hate you and your white car.
Old Apr 19, 2005 | 09:29 PM
I30tMikeD's Avatar
Where did you run at?
Old Apr 20, 2005 | 12:10 AM
NmexMAX's Avatar
dot dot dot ...
What was/were your trap(s) on your previous runs, the 15.0x?
Old Apr 20, 2005 | 12:40 AM
steven88's Avatar
Need A Light?
Great times! Great 60ft especially.....I am 6spd with the same mods as you....and I couldn't even get below 2.45....it was my first time out though...i'm shooting for high 2.2's next time out.....not sure if it is achieveable since it will be summer....and the weather will be in the 90's.....
Old Apr 20, 2005 | 04:34 AM
Epacy's Avatar
Yeah the 60' times are good. It defiantely isn't pulling as hard in the top end. Not sure why. Nothing some headers couldn't fix.
14.6 would be nice without a y-pipe on.
I ran at Gateway. It was about 77 degrees out.
The trap on the 15.019 was 92.52 mph. That run was all messed up. A -.057 at the light and from 3rd to 4th it hit the rev limiter. F' that run!
I was hoping for a 14.7, but I was fairly close, 3 hundredeths off. I need to wire up the Drop Resistor mod. Van, do you notice that it helps?
Old Apr 20, 2005 | 04:35 AM
Epacy's Avatar
What do you run with the headers? Any exhaust? How is the VB mod?
Old Apr 20, 2005 | 08:51 AM
juice's Avatar
Def excellent 60fts..but the times are a little slow for those 60's....I wonder why...are you at high elevation? With some headers you should be seeing some low 14's.
Old Apr 20, 2005 | 09:29 AM
Epacy's Avatar
Low 14's would be nice. 13's would be even better but not sure if I can get there. What all do you have done to have that 13.7? That is sick.
Elevation isn't that high here. What could be causing my decrese in the top end? I know just even a y-pipe would help that out.
Old Apr 20, 2005 | 09:42 AM
JClaw's Avatar
You need to check the elevation. Yes, that would hurt your traps.
For example, my closest track is at 165 ft. above sea level. Lower=better.
Old Apr 20, 2005 | 09:47 AM
Dave B's Avatar
Not DAVEB the parts guy
Remove all the stereo gear and the 18s and your trapspeeds will improve by atleast 1.5mph if not more. Also, the weather wasn't great. 77 degrees and the relatively high humidity we've had here in Kansas City and St. Louis isn't the greatest for racing. If you would have raced in dry 60 degree air, you would have been over .1 and 1mph quicker.
Gateway is a good track and from what I've been told by Kansas City guys that have raced there, the prep is good.
Old Apr 20, 2005 | 10:23 AM
Ferbs02SMMax's Avatar
Good times man.
What are your 1/8th mile traps on the two 14.8xx runs? That is a good indicator of top end power.
Anyway, that launch is insane...I can't believe you could cut such a good time on the 18's...As far as getting out of the hole strong, looks like the timing advance might help this, I read people feel it more down low...
Anyway, I too am extremely envious of your 2.1xx short time. My pb so far was done on an atrocious short time (see sig), if the drag racing Gods could smile one time and grant me a 2.15 short time, 14.3 baby! Anyway, as Dave already mentioned, not real optimal weather, but hey you'll take it I bet.
Post your entire slip (or the #'s at least) please for your pb time.
Old Apr 20, 2005 | 10:31 AM
F23A4's Avatar
Looks like you just edged out my best 60' (see sig)
Old Apr 20, 2005 | 01:29 PM
Epacy's Avatar
Originally Posted by Ferbs02SMMax
Good times man.
Here are the pics of the first two runs
First one:
Second one:
Old Apr 20, 2005 | 01:46 PM
S00NR1's Avatar
OU > *
Interesting to note a much better launch with the slower R/T on the first slip. It seems that all my slower R/Ts coincide with better runs as well, lol....maybe more time brake torquing.
Old Apr 20, 2005 | 02:48 PM
NmexMAX's Avatar
dot dot dot ...
I haven't run here yet, high alt 5.4k, I see it like Dave does though, you run what you run ... So I plan on running soon.
No, all I have is what's posted in the sig headers w/ stock cat-back. I plan on getting a b-pipe but not sure which one bolts to the stock muffler. From what I've heard and seen the frankencar does, taht would be my chioce, b/c i know warpspeed b needs a little bit of fabrication for stock fitment. I have to look into this more though.
The VB mod is nice, I think it could potentially help out times by a tenth or 2.
I agree, get the car on jenny craig and wait for some nice (drag racing) weather. Was it at Great Bend raceway? that's a pretty high alt track ... not sure, jsut going by this ... >> NHRA Correction Facotrs for High Alt Tracks
Old Apr 20, 2005 | 03:02 PM
JClaw's Avatar
R/T has nothing to do with your ET. You could sit at the line for 2 minutes and still run 14s.
Old Apr 20, 2005 | 03:09 PM
NmexMAX's Avatar
dot dot dot ...
I think he meant the tranny got better torque for launching off the line being built up, then launching, just like a heavyweights punch compared to a feather weight, mroe wind-up, more punch ..
Old Apr 21, 2005 | 05:24 AM
Epacy's Avatar
I would like to get the VB mod. Anything for time off.
No, this was at GIR, Gateway in Illinois.
Old Apr 21, 2005 | 06:43 AM
NmexMAX's Avatar
dot dot dot ...
It seems to help a lot, and my 1st was slipping bad, and I knew it wasn't the tranny b/c my 2-3 was perfect, and the VB mod helped the 1-2 a lot. I used to shift, and by the time it would stop slipping and finally engage, when shifted at redline 2nd would start at at 4800, and now it's solid at 4000, a little IM modification and extended rev limiter could be a combonation for some good things.
Old Apr 21, 2005 | 07:28 AM
S00NR1's Avatar
OU > *
Eric, personally I would stay away from the VB mod -- I have heard nightmares, especially with the touchy '02 auto transmissions. A better idea would be to just get the DR mod -- you don't race your car enough to need the several hundred dollar expense of the Valve Body mod and the DR would cost like 10 bucks and take about 10 minutes to install. Van and I are putting mine on this weekend.
Old Apr 21, 2005 | 08:30 AM
NmexMAX's Avatar
dot dot dot ...
A VB mod should save the tranny, no 02 tranny equipped with a VB mod has failed that I know. It's usually the ones w/o it. Stage II is fine, it's actually comparble to the STOCK 4th gen shift.
Old Apr 21, 2005 | 09:32 AM
Epacy's Avatar
Take some pics of the install so I can see how to do it.
Old Apr 21, 2005 | 09:51 AM
NmexMAX's Avatar
dot dot dot ...
radio shack + creativness.
Credit: Jime.
Another method.
http://www.cardomain.com/memberpage/218989/15
Credit bigdo
Old Apr 21, 2005 | 10:01 AM
Credit: Jime.
Another method.
Credit bigdo
What does this mod do? I've heard it of it before but never really studied it. What are the benefits and improvements seen at the 1/4 mile with this mod.
Old Apr 21, 2005 | 10:07 AM
S00NR1's Avatar
OU > *
Basically it allows full line pressure to the auto tranny so that the shifts are much harder (and much sharper, I might add). It reduces the amount of slippage the tranny might experience when shifting down from the high RPMs.This is only to be used at WOT.
I would say that you would most likely see a difference in a consistent .1-.2 at the track.
Old Apr 21, 2005 | 10:12 AM
NmexMAX's Avatar
dot dot dot ...
http://jime.homeip.net/DR%20Mod.html Here's jimes page with a little more ifno.. its on a 4g, but the crcuitry is the same, onyl diff is the pic on top where the wot switch is placed under the accelerator.
Old Apr 21, 2005 | 10:17 AM
S00NR1's Avatar
OU > *
I am pretty sure Van and I are going to put the switch on the little panel to the left of the steering wheel. I will take some pictures so you can see.....I think the WOT switch would take a lot more work and there wouldn't be much difference.
Old Apr 21, 2005 | 10:33 AM
NmexMAX's Avatar
dot dot dot ...
The WOT swtich does make somewhat of a difference if you're a deadbeat like me and like to mess with other cars around town. I have it on my 95, and someitmes I have to keep watching traffic, and forget to turn the switch off and get the dreaded non-WOT DR shift ouch ... but if only being used at the track, it's a good benefit. I've had the DR for along time on my 95 and can truly say that the VB mod is better (IMO) and feels more refined, but if money is an issue, than save it and do the DR mod. I can also say that when going back to normal WOT shifting in my 4g, they are really bad now, sloppy and loooong, but I think I can credit that to the car having 227k miles.
Old Apr 21, 2005 | 11:04 AM
eckohb's Avatar
no no no, all automatic 4th gens have that dreaded crappy and looooong shift without the DR, its not just yours. I've got 120k, and its the same way.
Old Apr 21, 2005 | 11:11 AM
NmexMAX's Avatar
dot dot dot ...
Hey man, my tranny was NICE when I first got, I had the car for 135000 before i installed the DR mod, and never showed any sings of mercy, shfted like my 03 does now with the stage II VB ...
Old Apr 21, 2005 | 11:23 AM
eckohb's Avatar
mine sometimes shifts hard and pulls very nicely, sometimes its like, ok when is it going to shift. i use the DR switch at the track only, i too forget to flip it when ****ing around with other cars
Old Apr 21, 2005 | 11:33 AM
NmexMAX's Avatar
dot dot dot ...
Yeah that scares the **** outta passengers ..
Old Apr 21, 2005 | 07:33 PM
Epacy's Avatar
So the DR has really hard shifts? Are the shifts actually crisper though?
Old Apr 21, 2005 | 07:35 PM
whazzzzuup's Avatar
The shifts feel hard only when the car is not WOT. When it is, however, the shifts are swift and crisp.
Old Apr 22, 2005 | 01:10 PM
NmexMAX's Avatar
dot dot dot ...
The DR and stage II feel about the same, though the DR is much harder under normal driving that's why the best way is to have a wot switch.
Old Apr 22, 2005 | 03:18 PM
Ceasars Chariot's Avatar
Old Maxima Legend
nice runs !!!
Old Apr 22, 2005 | 04:18 PM
NmexMAX's Avatar
dot dot dot ...
Belive me you don't want the DR enabled during normal driving ...
