1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
1st time spraying! 75 wet 1/4 results
Old Mar 31, 2006 | 10:52 PM
smotz's Avatar
Brain phuck
14.663 @ 99.82 with 2.488 '60 spraying 2nd 3rd and a hair of 4rth..
Other mods are ws Y, hi flo cat, cat-back, k&n Intake, fidenza flywheel, UR Udp.
For some reason I am thinking I should of ran faster? Sucks I was only able to get 1 run in. Would pulling a 2.2 '60 have helped much? Was 1st run since last year I was super nervous.. Also my first time running the spray. Any advice for next time? Like what rpm to shift at? And should I try spraying 1st?
Old Mar 31, 2006 | 11:23 PM
s0ber's Avatar
Your trap seems kind of in spec, but I think your E/T should of been lower.
Old Mar 31, 2006 | 11:34 PM
michaelnyden's Avatar
wow...I was expecting a full second faster with all your mods and a 75 shot
Old Apr 1, 2006 | 01:15 AM
Brushedpewter's Avatar
I ran .4 faster by mounting a floor switch and adding an intake.
The floor switch was in conjunction with a WOT switch. WOT switch alone will make you spin your tires because you want to go WOT to go faster. The floor switch allows you to start spraying nitrous as soon as you feel you have traction.
1. Put floor switch
2. Start spraying in 1st at 3000rpm. If at 3000 no traction then go to 4000rpm. No traction at 4000rpm, you get the picture.
I have a 4 cylender nissan and with the WOT switch alone I couldn't stop spinning until 3rd. By installing a floor switch I was able to spray in 1st at 2500rpm. If I had slicks I would of sprayed from a dead stop.
I got the idea of a floor switch from Jime.
Old Apr 1, 2006 | 06:43 AM
ajcool2's Avatar
Thats what I was thinking. But it was his first time spraying.
Old Apr 1, 2006 | 09:01 AM
icedout's Avatar
yea you should have deff been in the 13s,just keep practicing with the spray and you will get better times.
Old Apr 1, 2006 | 11:34 AM
MaxGordon7's Avatar
yea people are running much better N/A times. Id try do do some good N/A runs then add the nos sauce. i think should at least have 15 s N/A then your gettin there. maybe a dyno????
Old Apr 1, 2006 | 12:34 PM
BEJAY1's Avatar
Conecarver
Agreed. Try to practice your launches to get a 2.2x down consistantly. That'll drop you .4-.5 I believe right there.
Old Apr 1, 2006 | 07:41 PM
smotz's Avatar
Brain phuck
Thanks, thats really good advice.
Old Apr 1, 2006 | 11:08 PM
Blu's Avatar
Blu
the tits
that trap speed looks to be about 5mph low for a 5 speed with bolt ons and a 75 wet shot.
Old Apr 2, 2006 | 11:20 AM
SonicDust187's Avatar
I think its more like 3 mph low. I ran 97.5 mph with 75 shot spraying 2nd, 3rd and 4th. I had intake, ypipe and stock clutch that couldnt handle 75 in first gear.
Old Apr 2, 2006 | 01:18 PM
Blu's Avatar
Blu
the tits
IMO 97mph running I/Y/E and a 75 wet shot is not good at all. You should gain 5mph+ with a 75 shot and a 5 speed. With those bolt ons you should run a lot better than 92mph NA unless the knock sensor is dead or something else is going wrong.
Old Apr 2, 2006 | 02:08 PM
I didn't have a catback. Plus stock clutch that could barely hold 75 shot. I don't think its too bad given on a hot day. BTW: my cat was almost clogged.
Old Apr 3, 2006 | 07:06 AM
Blu's Avatar
Blu
the tits
well with a clutch that can hold and everything else in working order you should trap 102-103 fairly easily with a 75 wet setup.
Old Apr 3, 2006 | 08:41 AM
ajcool2's Avatar
Do you have a bottle warmer and what psi was the bottle at?
Old Apr 3, 2006 | 09:17 AM
JeEvE's Avatar
I traped at 104.79 with a 75shot and only ran a 13.8. I was spraying end of 2nd, all of 3rd and into 4th. That was the first and only run I got in last year before the track closed. Mods were, intake, y-pipe (stock catback ) and 00 VI.
Old Apr 8, 2006 | 06:21 PM
smotz's Avatar
Brain phuck
I don't have a bottle warmer or a n20 pressure guage. Should I look into getting the bottle warmer? I am going to get a n20 guage next time I fill up my bottle.
I deffinatly need practice in launching the car. Haven't launched it hard since last year.
Old Apr 8, 2006 | 07:06 PM
JeEvE's Avatar
Definitly need the warmer, it is very important in getting the bottle to the proper pressure, otherwise its not hitting like its suppose to.
Old Apr 8, 2006 | 11:49 PM
ajcool2's Avatar
Yup. When Dongfun first went to the track with his n2o he didnt warm his bottle on the first run and ran a 14.8. When he warmed it for a while he got a 13.8 by the end of the night. So it makes a big difference.
Old Apr 10, 2006 | 08:58 AM
my bottle heater wasn't needed during the day because it got so hot in the trunk that my bottle pressure was 1400psi.
During night and evening it's needed
Matt93SE
May 24, 2019 02:58 PM
Slamrod
Sep 3, 2015 07:38 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
criminalslang810
Aug 16, 2015 08:12 AM
jchronis2552
Aug 13, 2015 07:48 AM
