1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Ran a 13.007 today before my engine ****ing seized
Old Sep 21, 2006 | 09:33 PM
  #41
gtr_rider's Avatar
192.168.1.1
HEre are the vids:
http://vqpower.com/tmp/Sept%2016%20Seized-b.asf
http://vqpower.com/tmp/Sept%2016%20weird%20launch.asf
http://vqpower.com/tmp/Sept%2016-13z...o%20cutout.asf
Old Sep 21, 2006 | 10:58 PM
  #42
GodFather's Avatar
Made in Taiwan
Sorry to hear that, Dandy. You're an inspiration and a pioneer. Hope you get your things sorted out soon.
Old Sep 21, 2006 | 11:17 PM
  #43
DandyMax's Avatar
3.5 in the works
Thanks Peter and thanks Luke for hosting!
SOrry the vids are a bit shaky... I had a novice videographer that day...
Old Sep 22, 2006 | 05:28 AM
  #44
MardiGrasMax's Avatar
Dam dude, good luck with the new motor. Maybe add some cams?
Old Sep 22, 2006 | 02:33 PM
  #45
JClaw's Avatar
Yeah, exactly what I was thinking. Get some high lift 3.0 aftermarket cams. That way, when you put the 3.5 in, you don't have to drill anything and you already have aftermarket cams that match the 3.0 cam sprockets ready to go in. Little downtime, more top end.
Old Sep 22, 2006 | 04:20 PM
  #46
DandyMax's Avatar
3.5 in the works
My 3.5 swap is going to have VTC's.
But I'm open to suggestions on which cams to put in the 3.0... $$$ may still end up dictating what I can do though.
I have been looking at the specs on a bunch of different ones but there seems to be hardly any good test data/dynos to be found for cams in a 3L. Furthermore, if I use VQ35 cams the cam timing will become crucial since there's no such thing as VTC on the 3L.
Old Sep 24, 2006 | 12:06 AM
  #47
KRRZ350's Avatar
that is an AWESOME time, regardless of what happened and not breaking that barier you should still know thats ill.
Old Sep 24, 2006 | 08:28 PM
  #48
GodFather's Avatar
Made in Taiwan
Dandy, Don't go with JWT cams if you are staying 3.0. The loss of torque is humongus in my 3.0 setup with the JWT S1 cams. Then I had some problems with it and took it off. Now I am riding with these same cams on my 3.5 setup, the result is waaaaay better. I still feel this 3.5 should see more torque, but I know that the cams and my mevi were the 2 major limiting factors. I know you have an optional 00vi, so that's my only uncertainty in this advice.
Basically, my mid range works very funny, almost disappointing. Floor it from idle, it pulls hard till 3k rpms, then dips a little power to 3.5k and pulls to 4k, then dips to 4.5k, then pulls all the way to redline without any signs of hp loss. At high revs, it's a honda vtec at large. I've ridden in a 2002 6-speed maxima and a 6-speed altima, both pulled really hard in the mid range, but got no juice left at higher bands. I have also driven in my brother's 2000 auto maxima w/3.5 swapped in, it's got no juice after 5.5k rpms. My setup with JWT 3.0 cams in my 3.5 motor is totally opposite of those 3.5's I've just described. That should give you a good idea where you'd be if you do 3.0 jwt cams. I just wouldn't recommend JWT S1's on a vq30, unless you'd get the cams dirt cheap.
-Peter-
Old Sep 24, 2006 | 10:15 PM
  #49
michaelnyden's Avatar
how many miles did you have on your engine? this is so weird...some guys on here run 14psi with 350whp and a small shot of nitrous with over 100K miles on their engine and they drive it like they stole it and their oil pump never grenades, but others stay NA, put out less than 250whp and this happens...
I really wanted to see your next dyno to and see where your power peaks now without cams...
I am sorry to hear your misfortune and have been following your project 3L with 00VI and the emanage ultimate for some time, kept watching your dyno #'s go up and your ET's go down! I say stay the course and hit 12's NA with the 3.0L...I think JWT cams with the 2 step limiter would do well...maybe throw on a mild port and polish on your heads while they are out...
Old Sep 25, 2006 | 08:21 AM
  #50
koolguy4u's Avatar
damn, time for some forged Rods
Old Sep 25, 2006 | 02:45 PM
  #51
Hoooper
yep, cause that was the problem..........read the thread before you post, even if youre just trying to get to 15
Old Sep 25, 2006 | 04:07 PM
  #52
DandyMax's Avatar
3.5 in the works
Oil pumps failing probably wouldn't have much to do with the power level, more to do with the high rpm revving.
Yeah it's too bad the dyno will never be known now. I've said it before but my guess based on datalogging and just how the car felt etc was somewhere in the 230-240whp range and peak around 7000-7200 rpms. Not like I can prove it now though.
Old Sep 25, 2006 | 04:19 PM
  #53
TomV's Avatar
230-240 is totally believable based on times and traps by my math. If you have a known time and trap speed at a known power and weight for the car, you can easily get a good estimate of the new power by using the inverse cube of new vs. old (ET or trap, works about the same, or use both and average them). Its pretty reliable but won't account for slicks vs streets for example.
Old Sep 25, 2006 | 09:27 PM
  #54
how did you get it to peak so high...considering your last dyno peaked at 6600 without cams...you didn't take out your power valve in the 00VI did you? Cause I know that can shift where it peaks...
Old Sep 26, 2006 | 06:14 AM
  #55
DandyMax's Avatar
3.5 in the works
I think I'm going to see if I have any good EU datalogs from the last couple weeks before the engine seized. If I do I'll develop an equation for the slope of the rpm line, then doing a little calculus should give me a good estimate for the peak power point. Now things like road grade, wind direction etc could influence it since any logs I could use were taken all over the place on various back roads, but maybe it'll give me an idea. And yes the last few months I pulled the valve out, I don't know if it moves the peak point or just increases the top end a bit. Oh and you asked what my mileage on the engine was before, IIRC it was around 117k.
Old Sep 26, 2006 | 09:13 AM
  #56
how did you low end and midrange feel with the PV pulled out? how how much of a top end increase did you perceive?
Old Sep 27, 2006 | 07:06 PM
  #57
DandyMax's Avatar
3.5 in the works
Hard to say just going by the butt dyno. There was probably a small low/mid loss and a small gain up top. The car was not sluggish or anything down low, plus the tuning probably helps to compensate.
Old Sep 27, 2006 | 10:03 PM
  #58
so the difference in top end wasn't huge either?
Old Sep 27, 2006 | 11:54 PM
  #59
VIP Maxima
dandy, performance mods list please
Old Sep 29, 2006 | 12:05 PM
  #60
DandyMax's Avatar
3.5 in the works
Mods for the 13.00 run:
00VI swap
Greddy EU
PF TB
Motostorm UDP
Custom intake
Cattman h/y/catback (plus cutout but it was closed, so basically like a test pipe)
Low temp T-stat
Deadhead fuel rail w/ AFPR @ 46 psi
Some weight reduction
K-Sport coilovers
Belts: alternator only
Full ES bushing set and motor mounts
24.5x8.5x15 M&H slicks on 15x7 Kosei's
Courtesy STS
That should be most of it I think...
Old Sep 29, 2006 | 05:53 PM
  #61
BlackBIRDVQ's Avatar
drag racing is for wussies
Dan, U coming over ?
Old Oct 2, 2006 | 02:28 PM
  #62
DandyMax's Avatar
3.5 in the works
Got to do a VI swap for someone up here first. How much are you paying me?
Old Oct 2, 2006 | 02:42 PM
  #63
how bout a 4 dozzen pierogis with cabbage and mushrooms ?
I might be dropping off my Maxima in WI for some FI work.... I got all winter to get it runing, I got a winter beater.
Old Oct 2, 2006 | 04:24 PM
  #64
Kevlo911's Avatar
Kevlo for President
Why you teasin me
Old Oct 2, 2006 | 04:43 PM
  #65
I'm not, unfortunatelly there are no good turbo kits out there, and I reather be roots blown anyhow.... instant low end power.
Old Oct 2, 2006 | 04:49 PM
  #66
JClaw's Avatar
Is that an M90?
Old Oct 2, 2006 | 05:08 PM
  #67
Kevlo911's Avatar
Kevlo for President
Yeah the only SC setup I would do is roots too
Old Oct 2, 2006 | 07:31 PM
  #68
GodFather's Avatar
Made in Taiwan
Wow, a new toy coming our way for the community? Nice, hope you git-r-dun soon.
Old Oct 2, 2006 | 09:55 PM
  #69
Is that an M90?
Upgraded SVT Cobra unit
Old Oct 3, 2006 | 10:15 PM
  #70
Duckman540i's Avatar
VE Powah!!!
So In That Case, The Eaton M112.
pktaske
May 6, 2016 07:49 AM
BkGreen97
Apr 2, 2016 05:47 AM
ballerchris510
Sep 10, 2015 09:35 PM
nbstriker10
Sep 4, 2015 04:26 PM
pktaske
Sep 4, 2015 08:40 AM
