1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Weight Question
Old Apr 10, 2007 | 11:13 PM
96blkonblkse's Avatar
Weight Question
This may seem like its been asked before, not sure whether it has or hasnt but here it is. Yes i have looked but im kinda curious to what some of you peopl think.
Q. What is a good weight to get the maxima down too?
My 98 SE 5spd with sunroof, leather, auto climate, bose etcc., with absolutely no weight reduction, everything in the car as it came from the factory, half a tank of gas, spare, washer fluid full, im sure a lot of other stuff that added weight. I got weighed at a local dumping yard and it came in as 3278LBS. thats including me (115lbs). So i figure 3163 without driver.
I dont want the car to be stripped or anything, i still want it to be streetable, quiet like it should be, nothing drastic, but id just like to hear some different opinions on what the maxima should weigh. Im guessing around 2900-3000lbs would be nice?
Old Apr 11, 2007 | 01:24 AM
Nealoc187's Avatar
SLOW
i can never figure out why maxima weights vary so much. my all stock 95 weighs like 3105 with me in it and nothing but the spare tire removed. So that's 2960 without me.
I think alot of the discrepancy comes from different scales honestly. I just don't see sound deadening and leather and heated seat equipment and some extra crash protection adding 200lbs to the same body style car, but maybe i'm wrong.
Old Apr 11, 2007 | 12:44 PM
eng92's Avatar
Don't forget the Canadian maximas came from the factory with VLSD so they all got full sized spares. I still have the original 16" alloy rim with a never been used Toyo Proxes tire on it in my trunk.
That is good for a few extra pounds.
Old Apr 12, 2007 | 11:14 PM
I know what you mean, i guess its along the same lines as 1/4 results. driver skill plays a huge roll, and in weight the scale plays a huge roll. This scale i cant imagine being very accurate #1 reason being is, when i went there i told her i had to dump some stuff, and the car weighed 3378, but i didnt take anything out, just a lame excuse to weigh, then coming back it weiged 3278. Even tho i didnt take anything out it still showed i lost 100lbs. So i figure it could easily be 100lbs off, which would knock me around normal weight.
Also i do have a full size spare, a good 38LBS i beleive, still with the original proxes A05 which is brand new. Still has the rubber hairs
The 4th gens are still pretty damn light for what they are considering most of htem are fullly loaded. My freinds 07 Jetta GLI weighed in at 3698lbs. given hes about 175lbs, but its still pretty damn heavy.
Old Apr 13, 2007 | 06:17 PM
JClaw's Avatar
Stock weight should be 2950-3000 for a 95-96 and 3000-3050 for a 97-99 so yeah they are surprisingly light. Ive never seen a FWD car as big or bigger than 4th gens that did not weight MORE.
Old Apr 14, 2007 | 01:21 AM
SpeedCrazie's Avatar
My 1995 SE 5spd Fully Loaded w/ Leather, Sunroof, Spoiler, etc, and a full tank of gas weighed in @ 3100lbs.
Old Apr 15, 2007 | 01:41 PM
tavarish's Avatar
fwd gone rwd cr00
without me, my maxima (98 3.5 5spd GLE) weighs in at 2860.
Old Apr 15, 2007 | 03:28 PM
Nealoc187's Avatar
SLOW
I just looked at some of my old timeslips and my 96 gxe was 2760 without me, without passenger seat, spare, and rear seat. So add 45lbs for passenger seat, call it 15 for the spare and 10 for the rear seat and that's 2830 with full interior and 1/4 tank of gas. That car had other weight reducing items like a CF hood, light wheels, suspension that was lighter than stock, but it also had SFCs which added aout 25-30lbs to the weight of the car.
Old Apr 15, 2007 | 04:13 PM
krismax's Avatar
Father of the 00 VI
ok the pass non power seat is around 40 lbs. the spare is 27 lbs 6 oz. total rear seat not just bottom 95 cloth is 30 lbs 0.0 oz even.
guys cars with different years(4th gens) and trim can swing 100-150 lbs in weight i have accounted for it and iam in the process of weighing many things.
Just the 95 aluminum bumpers save around 30 lbs over the 96 and the 97-99 bumpers are heavier than the 96's.i dont have a exact weight yet because i havent weighed the 96 stock front yet.
so what iam saying is you will see huge weight differences because they are really there.
Old Apr 15, 2007 | 04:16 PM
krismax's Avatar
Father of the 00 VI
this is another thing all maximas dont have a spoiler it all adds up that weighs 4 lbs 5.6 oz
Old Apr 19, 2007 | 11:45 PM
thx for all the replies..im heading down to the track tomorrow(mission raceway) so hopefully ill get some good runs down and ill post the results.
thanks
Old Apr 20, 2007 | 11:34 AM
allwiredinc's Avatar
usually big weight differences are cars with moonroofs, larger rims, and automatic transmissions.
Larger rims:
1) weigh more
2) are often taller overall than stock wheels
to go a little faster there is a couple of tricks you can do
1) put a smaller diameter tire on the front. This will raise the rpm faster, and cause your car to accellerate faster. you should see a couple of 1/10s with that
2) deep stage. when pulling up to the starting line, once both the prestage and stage lights come on, creep up a hair further until the prestage bulb goes out. this will give you a faster reaction time, as well as a faster ET, but it will show a little less MPH...
be sure to write DEEP on your window so the tower knows you are planning to deepstage
Old Apr 20, 2007 | 02:07 PM
Nealoc187's Avatar
SLOW
stop breaking up your ideas into different posts unless you want to get banned. that's ridiculous.
Old May 6, 2007 | 10:00 PM
ok so i went to a truck scale, half a tank, with me, no spare, jack, took everything out of the car that wasnt needed(i usually have quite a bit in the car), the car weighed in at 3056lbs. Much more around what i expected. Also came back 2 hour later without the passenger seat and rear seat removed and weighed in at 2981. Althought for 75lbs id rather keep those in there. The pass seat was a PITA to remove. stupid side airbags lol.
Old May 6, 2007 | 11:43 PM
Ceasars Chariot's Avatar
Old Maxima Legend
man i saw an auction on ebay for a rear bumper for a 97 maxima, i thought i would see if they would ship to NZ, im so tired of the sarona rear. i asked him to weigh it right, he emails back says he cant ship to NZ and that the rear bumper is 50 lbs ? What tha ? that cannot be right!
guess im stuck with sarona rear but it doesnt weigh a hair over 19 lbs, if memory serves me right.
Old May 7, 2007 | 07:15 AM
DandyMax's Avatar
3.5 in the works
He probably thought you wanted the whole thing, as opposed to just the skin. The support is around 38, 43.. something like that IIRC... the rest is the skin
Old May 7, 2007 | 04:38 PM
1chewabacha1's Avatar
??? Is that right guys? You'd be able to accelerate faster however the tires are smaller so you're actually covering less ground aren't you? Therefore decreasing the amount of area you cover per tire revolution and inevitably lowering trap speed.
Old May 8, 2007 | 09:42 PM
Well from what i can gather, it would allow your car to accelerate faster, which means your et will be lower, but your trap would decrease. Im not too sure, but a smaller tire/rim combo (lighter, but keeping same overall diameter), will always help.
Old May 13, 2007 | 08:40 PM
aznsap's Avatar
wow so taking out the seats and spare before the track is a pretty easy ~100lbs
Old Mar 11, 2008 | 08:13 PM
zsrbpk's Avatar
i weight my maxima and it was 3260 with driver so you should be able to get it to 3060 if u do alot to it
Old Apr 5, 2008 | 04:15 PM
331TwistedWedge's Avatar
staging deep WONT improve your ET ... once you break the beams your time starts, regardless of your reaction time ... you can sit there all day and it WONT hurt your ET, just the same as if you got a perfect light ...
((and)) it doesnt hurt your MPH ... where are you getting this info???
Old Apr 6, 2008 | 09:57 AM
RacerX1320's Avatar
The weights can vary so much due to options and trim levels. But id say a GXE is the best to start with. The 4th gens are pretty light to begin with though. Id say id agree with you, right around 3k even is roughly a good weight. I will weigh my 00 gxe 5spd in the spring at a local recycling plant. Ill update in this thread what my mods are and the ending weight.
user 11122324
42
Jul 18, 2022 03:35 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Socalstillen
Sep 26, 2015 12:01 PM
