1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Need racing tires no grip but fast trap still! 13.7(1/4) 110 mph
Old May 4, 2007 | 10:12 PM
mooseq30's Avatar
I really need to find me a good set of rims and racing tires or slicks,
With some better grip my turbo 2000 se 5sp maxima is good for 12's and 115-120 mph trap speed. My ¼ mile is garbage 9's all I do is spin but it grabs in third and really pulls! 13.7 ¼ mile with trap of 110.5, it was my first time there!!
mods:
-Turbo t3/t4 to4e @ 7-8 psi (~420 hp to the crank, ~330-340whp)
-Same side dual port front mount bar and plate with less than 3.5 feet total cold piping!!!!!!!!(it is the genius behind all the power!)
-38mm and 50mm waste gate and blow-off valve
-full turbo back 2.5 inch mandrel bent exhaust with high flow magnaflow cat and straight through resonator and muffler.
- Walbro 255
-cartech FMU 4:1
-AFC neo
-GS6 brake pads (work really well, agressive bite)
-sway bar
-short shifter
-deck and speakers, stock sub and tweeters
-alarm and starter with turbo timer
_The Nissan dealer near me is really nice I bought the extended 2 year warranty and got all this new replaced so far:
Tranny 5spd
Clutch stock
Alternator
Engine Belts
Rear cables
Both front tables
Both ball joints
Both tie rod
Both links
Computer stock
Maf stock
Seal kit for breaks
Calipers 1 year old stock
Old May 5, 2007 | 05:44 AM
Kevlo911's Avatar
Kevlo for President
I'd buy a stronger clutch and some drag radials.
Old May 5, 2007 | 11:09 AM
Tatanko's Avatar
Bacon Lover
Get a dyno in as well
Old May 5, 2007 | 02:00 PM
mooseq30's Avatar
I really want to dyno i think I'd put down ~420 hp to the crank, ~330-340whp i already put 270 whp down with 3.63 psi running 7-8 psi its alot more power now and i cant wait to see it on the dyno!
Old May 5, 2007 | 10:05 PM
Nealoc187's Avatar
SLOW
How about a timeslip... what's it look like?
you'll likely pick up about 2-3mph on stickier tires, perhaps 4 if you are really not doing the right thing on street tires. If your 330-340whp estimate is correct you could probably trap 112-113, 114 at most I'd wager. I could probably give a better estimate if you posted the entire timeslip.
Old May 6, 2007 | 01:55 AM
Ceasars Chariot's Avatar
Old Maxima Legend
as neal would say, get some slicks, im running hoosier drag radials and they are better than street tires but looks like some slicks would (just guessing) have you knocking on a high 12.x
h2kfrosty in his 5th gen had close to the same power, he ran a 13.2@110mph i think it was with a typical 2.1x 60 foot. going off that with some slicks that should be good enough to land you in 12 city.
and please dont run 12's and come back without slips and videos , rofl !
his 13.2 second run is in this real weird maxima video
http://www.filefactory.com/file/f1d8f6/
click that Download for free with FileFactory Basic
and some popup window opens up for download
Old May 8, 2007 | 05:37 PM
Nismo3112's Avatar
Custom User Title
Correct me if i'm wrong, but don't slicks tend to result in a slightly lower trap? (but much better ET)
Old May 9, 2007 | 12:08 PM
mooseq30's Avatar
Originally Posted by Nismo3112
Correct me if I'm wrong, but don't slicks tend to result in a slightly lower trap? (but much better ET)
If more grip is given, than a faster 1/4 mile ET will be met, but when capable of gripping instead of spinning than you can get to a higher top speed in less distance thus the trap speed will increase as the grip increases!!
Old May 9, 2007 | 12:17 PM
mooseq30's Avatar
Old May 9, 2007 | 12:19 PM
mooseq30's Avatar
I'll do better next time, When i went it was freezing on the track and grip was terrible! I'll go try again this week or next!!
Old May 10, 2007 | 03:21 PM
niceguy's Avatar
You're probably making about what you mentioned, in the low-mid 300 whp range....A friend w/a '95 Altima turbo is running the same trap as you and has made some 12.7 passes so you definitely have some better times ahead...
He put down around 320whp so you're in the ballpark...
Jeremy
Old May 10, 2007 | 05:34 PM
Nealoc187's Avatar
SLOW
my traps have done nothing but go up with slicks. Even when I was NA I was trapping higher with slicks.
Old May 13, 2007 | 10:42 AM
JClaw's Avatar
Originally Posted by mooseq30
Holy ****! I had no idea you lived around here. Watch out for a beat up VQ35 S13 coming to Napierville sometime in the next two weeks.
Some good nissan competition - Ill beat your ET but not your trap
BkGreen97
Apr 2, 2016 05:47 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
bumpypickle
Sep 19, 2015 01:07 AM
Bonka
Sep 14, 2015 11:18 PM
