1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
First time @ the track: 5th Gen Auto
Old Jun 11, 2007 | 11:30 AM
MaximumPower01's Avatar
Mods:
~Intake/Timing Advance/Hi-Flow Cat/Weight Reduction (spare tire, jack, back seat)/ and Drop Resistor (on last run only)
~17" Factory Rims on 225/50/17 Nexen3000 tires, lowered psi to 23
~Approx Weight (w/me in it): 3400lbs.
Went to the track with 4x4 Max, in Cincinnati, and like he described, the weather conditions were very humid, with temp at about 75-80 degrees; (although it was starting to cool down when we made our first runs around 6:30/7:00pm).
Being my first time at the track, I was a bit late lineing up each time, so I never really got a chance to brake torque, like i wanted. Also worth mentioning is I ran in lane 2 each time, which both 4x4 and I agreed, it seemed to be a bit slow/lopsided w/lots of rubber on the starting area.
1st Run: 16.332
2nd Run: 16.238
Final Run (w/Drop Resistor Mod): 16.122
*(I'll post the full slips when I get home)*
I only managed to get in 3 runs before I decided that I'd let my car go cool off a bit, and grab something to eat. Came back 20 minutes later, tried to start the car when all the sudden she wouldnt start..........It would crank over ever so slightly, almost catch fire, then die.........We were all like, uh wtf?.......
Started checking fuses, cable lines, and even tried to jump the battery, but it wouldnt take the charge......Cranked on it a few more times, battery runs completely dead w/jumper cables on it.....So then we assumed it may be the battery........Ran down to Autozone (about an hour to and from) and picked up a battery.....STill nothin!
By this time it was almost dark, and we had run out of daylight.......
Well, long story short, I ended up having to leave my car down at the track overnight (thankfully they let me keep behind the gates, in a secure area) and had to have it towed on a trailer all the way back to my house (AAA)
I get it back and do some by-pass testing to check the starter and surprise surprise.........She was dead!
Just my luck, finally get make my way down to the track and my friggin starter goes out. Took me about an hour to take out my intake, brackets, and remove a bunch of clips to finally get to the starter. Managed to get a socket-wrench on it and in about two minutes, the new starter was installed. Put everything back together and she fired right up.
To say the least, it was definitely an interesting day at the track. I guess it only get better from here, eh?
(More info below)
Old Jun 11, 2007 | 11:49 AM
Also, my times seem to be very slow for the setup I ran with....
While changin out the starter, I went ahead and took the TB completely off and cleaned it up real nice w/TB cleaner and a tooth brush.....(on a good note: the intake manifold was clean as a whistle!!).
I then started trying to take off the VIAS, so I could check it out and then jb-weld the spring back in place (im 80% sure its out)........but, the PITA soft screws wouldnt budge.
Even with the TB off, I only managed to loosen ONE of the screws on the VIAS, and even with the #4 phillips, still managed to tear up two of the screws on the VIAS. Now I've read somewhere you can tell if the VIAS is working by checking to see if it is reaching its peak, at 6500 rpm (which it doesnt) (my cut off seems to fluctuate between 6k and 6200)
Originally Posted by TomV
You should be noticing a very definite change in power from 6-6.5k as compared to USIM, as in, it just keeps pulling. If the vias isnt working it will be nearly the same as the USIM (maybe a little worse up top). My traps went from 91.5 mph (USIM) to 96.1 mph (00vi) and i didnt even do an SAFC tune yet... my ET was not spectacular at 14.7
Does this hold true for Automatics, too?
Also, after reading a bit more today, Im thinking my Knock Sensor is out and could be the culprit to my slow responding RPM's. Seems like when I hit the gas at WOT, it just falls on its face and then 1-2 seconds of hesitation, then WOT kicks in from 2-3k rpm to 6K rpm (like normal.) The MAF was changed out last year, and it doesnt feel like that at all. Its just that 1-3 seconds of hestitation that has me thinking my Knock Sensor is also out (or possibly the VIAS, or both)
http://images.google.com/imgres?imgu...3D10%26hl%3Den
Any thoughts or suggestions would be much appreciated!
Ty
Old Jun 11, 2007 | 01:24 PM
4x4Max's Avatar
I'll come help you with the VIAS, shouldn't be much of a problem....go get your ecu scanned at autozone, they'll tell you if your KS is bad or not. It's free.
Old Jun 12, 2007 | 01:00 PM
Any other advice/comments are always appreciated
Ty
Old Jun 13, 2007 | 06:19 PM
slips, in case anyone's interested.......
My camera isnt workin properly right now, too blurry........so I copied the slips instead, onto here:
(first time @ a 1/4 mile track)
1st Run:
R/T: .944
60' : 2.605
330: 7.023
1/8: 10.617
MPH: 69.01
1000: 13.684
1/4 : 16.325
MPH: 84.24
2nd Run:
R/T: .604
60': 2.528
330: 6.931
1/8: 10.523
MPH: 69.06
1000: 13.593
1/4: 16.228
MPH: 85.32
3rd Run: (w/Drop Resistor removed)
RT: .741
60': 2.466
330: 6.865
1/8: 10.457
MPH: 69.08
1000: 13.528
1/4: 16.167
MPH: 84.38
How did I do?
Improvements?
(bare in mind, first timer @ the track and my VIAS was out)
Old Jun 13, 2007 | 08:56 PM
bigirish's Avatar
Teh real important thing is that you had a blast! Once you go, you are hooked forever!
Old Jun 14, 2007 | 12:51 PM
DragdMax's Avatar
you need to work on your 60. your 60s kinda sucked.
get it down and your times will be faster.........
Old Jun 15, 2007 | 10:46 AM
Well, I just threw a P0430 code (Bank 2, 02 sensor & precat) today and am planning on fixing the VIAS this weekend.....
So hopefully that brings my times down all around, to say, 15.4-15.6 range.......(where I thought I should be)
Should help the 60' times, as well.
Quick question to anyone reading:
I've read many orger's using NGK o2 sensors over bosch......Is there any difference between a bosch o2 sensor and NGK o2 sensor, and if so, what?
Ty in adv. for your time.
Finkle
Sep 27, 2015 09:53 PM
WeetoddA32
Aug 16, 2015 12:45 PM
Max Nu-BE
Aug 11, 2015 06:34 PM
