1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
1/8 mile Sunday 6/24 in Lancaster, NY
Old Jun 20, 2007 | 09:02 AM
Bufflomike's Avatar
Sexier Than Simpson
They are having a Sunday Drag, open to amateurs and street grudge matches on the 1/8 mile. They usually have Tuesday amateur nights but that is my golf league day so I can never go. I am going to run it for the first time and I am anxious and excited.
1. Lower front tire pressure to 26 or so
2. Take golf clubs out of trunk...and the other stuff too.
3. Drop the clutch and hope my HLSD does not break.
4. Shift at redline for 1-2 and 2-3 then around 6k-6.3k if I need 4th
5. Have fun and be safe.
Anything else???
Anyone from Buffalo want to go??
Old Jun 20, 2007 | 10:44 AM
DandyMax's Avatar
3.5 in the works
Street tires?
I'd go a bit lower than 26, maybe 18-22 psi depending on how much sidewall you have. Also you may find traction on the launch will be better using more of a clutch slip technique than a dump. You shouldn't need 4th gear if it's only 1/8 mile...
Good luck.
Old Jun 20, 2007 | 10:53 AM
Bufflomike's Avatar
Sexier Than Simpson
Originally Posted by DandyMax
Street tires?
Good luck.
Dammit I am running 225/50 17 for now do you think 16-22 is safe? Going to get some of the General Exclaims I think sometime this summer and was thinking 245/45 or 235/45.
Old Jun 20, 2007 | 01:22 PM
cardana24's Avatar
Blown
dont dump the clutch unless you have slicks. I still blow my drag radials out if I launch much higher than 2k.
Old Jun 20, 2007 | 02:02 PM
Ceasars Chariot's Avatar
Old Maxima Legend
go gettum bufflomike !!
Old Jun 21, 2007 | 06:08 AM
DandyMax's Avatar
3.5 in the works
Well if you're unsure just start out higher and drop a lb or 2 at a time until you hit the best pressure/60 fts but 20-22 psi is still enough air, even though they'll look a little flatter, sounds like you have about 4.5" of sidewall.
Old Jun 21, 2007 | 06:59 AM
Bufflomike's Avatar
Sexier Than Simpson
I really dont know so I just dont want to blow the tires off the rims right now. I guess going to 22 seems like a good compromise. Getting a good 60' time seems like the most important aspect of a good ET.
Like I said, I am going to be nervous so I am just going to try and have as much fun as I can and not worry about being perfect. I just dont want a 2.9 60', I would be happy at 2.3 I guess. I will let you know how I did even if it is embarassing...thanks
Old Jun 21, 2007 | 07:30 AM
DandyMax's Avatar
3.5 in the works
...I am just going to try and have as much fun as I can and not worry about being perfect...
That's the attitude.
The whole deal is supposed to be fun after all.. haha. Good luck! I've hardly ever met someone who hasn't gotten hooked after ripping down a track the first couple times. 1/4 mile is better than 1/8 mile too IMO so try the full distance at some point too.
Old Jun 21, 2007 | 07:47 AM
Bufflomike's Avatar
Sexier Than Simpson
I will try the 1/4, but this track is close enough so I can hear it on a clear night. My gals brother runs late models on the circle track so we are there a lot. Not sure where the closest 1/4 mile is, but I think its in Leicester which is still close.
Old Jun 23, 2007 | 11:08 AM
MikeSDA's Avatar
yup nyirp.com (liechester) is the closest. If my motor didnt take a dump I would have tried to meet you at lancaster. Let us know how it goes, ive heard mixed reviews on the track quality there though? But good luck!!
JoshG
51
Sep 21, 2015 10:41 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
Socalstillen
Sep 20, 2015 11:46 PM
hntwhttail
Sep 12, 2015 03:43 PM
