1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Pretty good weather today
Old Oct 13, 2007 | 11:07 PM
Nealoc187's Avatar
SLOW
I hit up the track with maxmaxima91 and some friends today. Weather conditions were pretty awesome - low to mid 50s and baro in the 30.05 range, no wind to speak of.
I'd previously run 14.51 in my beater and I knew if I was ever going to run a 14.4 in it, this would be the day (since my good car is getting close to being put back together, that'll be getting all the track time in the future). I didn't expect to pull off what I did today.
I made 7 runs I believe today. Here's the best one - DA was 630' for this run. I also ran a 14.36 on a 2.07 60' time.
Those are the two best 60' times I've ever pulled on street tires. The 14.36 was taped by a guy I kind of know. I got his email address so hopefully he will rip it and send it to me, if he does I'll post it up.
Race weight showed as 3050lbs but the scale was showing 60lbs before i even got on it, so 2990lbs. Weight reduction was spare tire, trunk carpet and cardboard. I had just over 1/4 tank of gas indicated. I forgot to take my jack out I just realized, not that it matters much, probably only weighs 7lbs or so.
Old Oct 13, 2007 | 11:42 PM
MaximaSpd85's Avatar
wait a minute...this is a stock 4th gen?? wtf, how do you do it?? lol
what kind of psi do you run in your street tires?
Old Oct 14, 2007 | 12:09 AM
Nealoc187's Avatar
SLOW
I had them at 24psi. The times were pretty surprising. I was figuring 14.4s maybe high 14.3s after I made my first couple passes, based on the relationship between my 1/4 mile times and 60' times I usually pull. It's about modulating the clutch just right - there was a very fine line between proper modulation keeping the car at the limit of traction throughout first gear and just spinning the tires or bogging.
Old Oct 14, 2007 | 02:52 AM
NmexMAX's Avatar
dot dot dot ...
I slacked. Weather conditions were always SWELL. I mean 'Ok, let's run @ midnight on October 29th'.
Me = idiot
Old Oct 14, 2007 | 08:40 AM
Tatanko's Avatar
Bacon Lover
Neal, you're ridiculous
Can't wait to see your faster car run again
Old Oct 14, 2007 | 09:25 AM
RA030726's Avatar
I'm nutty for Nissans
cut the ****, seriously
j/k
Old Oct 14, 2007 | 09:49 AM
Nealoc187's Avatar
SLOW
me either, I can't wait to get it back together. i took it apart almost a year ago lol.
Old Oct 14, 2007 | 10:12 AM
kzoosho's Avatar
Hey man ima have to get out there with you next time since i have a boost controller i should be able to crank up the boost and put some better tires on to run also. Great times any ways.
Old Oct 14, 2007 | 10:26 AM
VQrebuild96's Avatar
Now that guy can drive...
Old Oct 14, 2007 | 10:35 AM
DandyMax's Avatar
3.5 in the works
Very nice Neal. Excellent 60 ft.
Which rims are on there and what rpm did you launch at?
I wanted to get out this weekend too, as you said - good weather, but just couldn't swing it. I'm still hoping to get 1 or maybe 2 more track days in yet this year though, see if I can drop a couple tenths before the end of the year.
Old Oct 14, 2007 | 10:38 AM
Nealoc187's Avatar
SLOW
95-96 SE sawblades - tires are Touring TAs I think. I don't really pay attention to my RPMs on launch anymore I just go by feel, somewhere in the 2000rpm range. I'm concentrating on just slipping the clutch properly (btw you could smell clutch pretty strongly after those 2.07s).
Old Oct 14, 2007 | 10:44 AM
DandyMax's Avatar
3.5 in the works
Ok cool that's about what I figured. On hard street launches I used go from about 2500-3000 (on SE wheels though) and just use the clutch to modulate. I've always found it easier to do that (work the clutch) rather than modulate the throttle. Do it too much though and bye-bye clutch, hehe.
Old Oct 14, 2007 | 10:45 AM
1chewabacha1's Avatar
I hate you. Not really.
Old Oct 14, 2007 | 04:08 PM
How much gas do you give it when u slip the clutch?
Old Oct 14, 2007 | 04:17 PM
DasYears
wow. thats better than 90% of stock 6spd 5.5s. amazing. 2.0xx 60' on street tires FTMFW!!!
Old Oct 14, 2007 | 06:47 PM
95maxrider's Avatar
Lightly modded
Why am I not surprised? If anyone was going to do it, it would be Neal. What's your launch technique?
Congrats!
Old Oct 14, 2007 | 07:01 PM
Nealoc187's Avatar
SLOW
Lots of clutch slip. Like I said before I don't really have a technique I can put into words other than going by feel. I couldn't tell you how much throttle I give it off the line really, I don't really think about it. But I'm slipping the clutch to keep the tires at the limit of their traction- sometimes it works and gives you 2.07 60' times, sometimes I get a bit to aggressive and spin the tires really bad.
Old Oct 14, 2007 | 07:45 PM
95maxrider's Avatar
Lightly modded
would you happen to know what rpm you hold before launch?
Old Oct 14, 2007 | 07:54 PM
Nealoc187's Avatar
SLOW
somewhere in the 2000-2500ish range, but i don't make an effort to set it at any specific point. I just give it a little gas and watch the tree.
Old Oct 14, 2007 | 09:56 PM
Singer's Avatar
Amazing, just amazing. I don't know much about drag racing, what would a set of slicks do to your time. Would it be enough to bring you into the 13's because that would make some 5.5 genners with headers just cry.
Old Oct 14, 2007 | 10:00 PM
streetzlegend's Avatar
I say that beater is a factory freak.
Old Oct 14, 2007 | 10:18 PM
DandyMax's Avatar
3.5 in the works
Slicks might get him high 13's. He's already run as fast as 13.4 on slicks a couple years ago with some bolt ons (different car but still 4th gen, on a 1.8x sixty foot IIRC). Goes to show you what a good driver can do with these cars. And note that's not even the quickest 3.0 either...
Old Oct 14, 2007 | 11:12 PM
95BLKMAX's Avatar
shortened convo of streetz and me when he was tellin me about this...(bold= when I realized streetz wasnt BS'ing, LOL)
StreetZ LeGenD: 14.2 at 94
StreetZ LeGenD: stock 4th gen
ElReyNica2003: gutted?
StreetZ LeGenD: 2999lbs
ElReyNica2003: wtf, bs
StreetZ LeGenD: http://forums.maxima.org/showthread.php?t=541314
ElReyNica2003: no f[EDIT]in way
StreetZ LeGenD: neal as usual lol
ElReyNica2003: NEAL went 14.9 on a bone stock 4th gen
ElReyNica2003: WTF!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11
StreetZ LeGenD: its hima gain
ElReyNica2003: BRB
StreetZ LeGenD: he went back
StreetZ LeGenD: btter weather
Go neal go!!!
Old Oct 15, 2007 | 12:36 AM
Nealoc187's Avatar
SLOW
I don't think this clutch would hold up to how I'd launch it on slicks but if it did, it might just get me there. I would drop .4 seconds right off my 1/4 mile when I put the slicks on my other 4th gen, that was with a .25-.30 second drop in 60' time usually (say 2.20 average on street tires, vs 1.90 average on slicks). this time, I was able to pull a much better 60' time on street tires though, so I might only drop .15 seconds or so off my 60' time, which would probably be about .25-.30 seconds off my entire 1/4 mile ET. So it would get me pretty close. It'd take a just perfect run to eek out a 13.999 (which incidentally, was my ET the first time I ever broke into 13s with my old car back in 02 I think it was.)
but I really don't think the clutch in this car would be able to handle very many runs on slicks. I was smelling it pretty good after pulling those 2.07 60' times.
One thing to remember is that the only real reason I'm running times like this is launching, shifting, and good weather. The car's only trapping 94.x mph. while a strong trap for a stock 4th gen, any bolt on 4th gen or stock 5.5 gen would yank me pretty well, regardless of what times they might have run at the track.
Old Oct 15, 2007 | 07:42 AM
DandyMax's Avatar
3.5 in the works
What clutch is it.. (stock Nissan?) My stock clutch lived just fine doing lots of 6400 rpm dumps on slicks. Well almost full dumps, little bit of slip, more like a very fast roll-on. But it's the slipping that kills it I think, if it doesn't slip for long then it might be ok...
Old Oct 15, 2007 | 08:26 AM
ajcool2's Avatar
Usually I dont believe in factory freaks but in this case I have no doubt. I might take my max out and aim for 13's with just my y-pipe.
Old Oct 15, 2007 | 08:27 AM
ajcool2's Avatar
Neal mod that car already would you lol.
Old Oct 15, 2007 | 09:39 AM
DandyMax's Avatar
3.5 in the works
Except why would he when he already has another 11 second one to play with..
Old Oct 15, 2007 | 10:14 AM
Nealoc187's Avatar
SLOW
I'm sure it's just some pos key value or something. the guy i bought it from had just repaced the clutch before i bought it, i bought the car for $1000 and it was barely driveable because of bad coilpacks, so I'm sure he didn't spend the money on a real oem clutch. my 96 max replacement clutch (probably key value as well, I didn't know anything about clutches back then and just had the shop put in whatever) held up to launches on slicks fine too but this one I can tell sometimes is not as grabby as that one was.
Old Oct 15, 2007 | 10:17 AM
Nealoc187's Avatar
SLOW
I don't believe in factory freaks either. back a couple years ago when I raced briguymax he beat me 4 of 7 runs. this car is no freak, it's just about how it's driven and getting those rare good days at the track, a lucky launch, etc.
I'm not putting any mods on this car, I was about to part this thing out a couple weeks ago because of a starting problem i was having. i don't have enough money to do what i want to do to my good car that i haven't driven in almost a year, i'm certainly not wasting any of it on this car.
Old Oct 15, 2007 | 06:50 PM
AsthmaMax11's Avatar
Amazing job Neal. I still visit the forums to see if guys like you have done stuff like this!
If I won the lottery I would send you a Y-pipe, Mevi and your old JWT ECU. (plus a thousand dollars to better the condition of the car) I am sure you would easily run mid 13's on street tires.
Old Oct 15, 2007 | 10:58 PM
Ceasars Chariot's Avatar
Old Maxima Legend
are you kidding me ? this car is stock ? we need a photo of neal's 4th gen beater as a new header for maxima.org !!
Old Oct 15, 2007 | 11:05 PM
maxmaxima91's Avatar
GRRR... watching this made me so angry!!! your not allowed in my garage anymore.... D@Ml\l VQs
Old Oct 16, 2007 | 12:09 PM
kzoosho's Avatar
Funny. well all need to get together and run like early next year. I have to replace my brand new clutch already so i dont think i am going to do anymore racing but next year im upping the boost to 12psi and i want to run slicks to get better times.
Old Oct 16, 2007 | 12:54 PM
U power shifting? I have 90k on my oem clutch and i have beat on the car every day. Clutch dumps all the time. Never power shifted. Really i don't understand how people toast their clutches so fast... unless power shifting.
Old Oct 16, 2007 | 01:35 PM
kzoosho's Avatar
Im boosted not n/a good sir
Old Oct 16, 2007 | 02:06 PM
i see now... u fried the oem clutch?
Old Oct 16, 2007 | 02:19 PM
kzoosho's Avatar
Naw a xtd or something like that suppose to be able to handle 350hp and tq. my next will be a puck clutch but a sprung puck.
Old Oct 16, 2007 | 02:48 PM
konak85's Avatar
damn good job neal. Driver skill and conditions have all to do with it. I did a 14.803 with catback, ypipe, TS ecu.
Old Oct 16, 2007 | 08:24 PM
MAX2000JP's Avatar
Trust me, Neal's car is not a "factory freak". The car isn't pretty, but runs well.
Heck, Neil and I went out to lunch when we were doing the supercharger install on my Mustang. Neil shifted so fast, he lost a belt!
