1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
puzzled...
Old Feb 17, 2008 | 10:45 PM
Maximahappy22's Avatar
puzzled...
Went to the track today and did pretty well, i pulled what i was expecting once but didn't really come close the rest of the day. So i need your guys help with analyzing my numbers from good to bad...
My Best:
rt .171
60' 2.176
330 6.076
1/8 9.352
mph 74.90
1000 12.178
1/4 14.606 @ 89.18 (missed shift to 4th at end of track)
My avarage:
rt .042
60' 2.263
330 6.306
1/8 9.640
mph 73.66
1000 12.501
1/4 14.915 @ 94.09
Any help on why i couldn't replicate my best run would be helpful.
Thanks,
Alex
Old Feb 18, 2008 | 02:18 AM
00SEMAX19's Avatar
Was your best youur first run?
Old Feb 18, 2008 | 09:11 AM
No, my best run was like my 4th or 5th run of the day out of 7 runs.
It basically went high -> low -> spike up to high again
Old Feb 18, 2008 | 01:26 PM
00SEMAX19's Avatar
Lane changes?
Were you spraying?
Old Feb 18, 2008 | 02:03 PM
t6378tp's Avatar
Turbo 3.5
if I remember correctly you were about 4tenths faster last year, if so you have alot of problems to work out. what have you changed recently
Old Feb 18, 2008 | 02:26 PM
Umm i wasn't spraying yesterday so there is nothing time wise to worry about. My best time NA improved like .35 from last year.
And i tried from both sides and still got the same results. i dunno what was wrong...
Old Feb 18, 2008 | 05:03 PM
t6378tp's Avatar
Turbo 3.5
My Best:
rt .171
60' 2.176
330 6.076
My avarage:
rt .042
60' 2.263
330 6.306
looks like you got better traction in the 1st 330ft. did you change anything, burnout, tire psi, shifts etc. it my sound funny but was there a really fast car that went before you on your fastest run, the reason I say this cause the track crew normally will do alot better job prepping for those guys then slower cars and add all the extra sticky rubber they leave from doing John Force burnouts
Old Feb 19, 2008 | 03:58 PM
Nealoc187's Avatar
SLOW
something happened between the 60' and 330' marks. maybe extra wheelspin into 2nd gear, or bogging into 2nd gear, or maybe a bad 1-2 shift.
Old Feb 19, 2008 | 06:49 PM
ahh it makes sense i guess, must've just hooked up real well once. Would doing a longer burnout on the DRs help you think? i've been doing about a 2 or 3 second burnout last time out.
Old Feb 19, 2008 | 07:48 PM
t6378tp's Avatar
Turbo 3.5
depends on the brand of DR
Old Feb 19, 2008 | 10:47 PM
BFG gforce T/A Drag Radial
Also when shifting to second i was chirping my DRs, would that mean they are a little cold?
Old Feb 20, 2008 | 07:06 AM
t6378tp's Avatar
Turbo 3.5
I do not know alot about these tires but a 3-4sec burnout does not sound long enough. try doing a burnout till you start seeing the smoke then slowly let the car pull out of the box with it still spinning. some tires like alittle longer burnout but I would start with this and take notes after every pass so you can comapre what worked and what did not. And make sure you are staging into the groove.
also what tire size and psi are you running
this is a old vid of me doing what I consider a short burnout cause I was on street tire's and needed to get the water off from the box
http://youtube.com/watch?v=ylxyJu1LLJY
and here is a vid of dandymax does the type of burnout I am talking about
http://youtube.com/watch?v=6DQbvV5-HMk
Old Feb 20, 2008 | 10:46 PM
kevin007's Avatar
A 2.1 60'ft. will get you better et's than a 2.2 all day. Check and adjust your tire pressure before each run. When make a pass your tire pressure increases thus causeing differences in your 60'ft. 60 ft. times are key! Write your tire pressure down on your timeslip after each pass until you find your sweet spot. It's not what you do in hole, It's how you get out of the hole!
Old Feb 21, 2008 | 09:05 AM
DandyMax's Avatar
3.5 in the works
http://youtube.com/watch?v=KugEoD7ldic&feature=user
^^^ that's a better burnout vid than the other one I think - closer, better camcorder etc
Old Feb 21, 2008 | 06:36 PM
yeahh... mine aren't nearly that long and i haven't seen smoke from them... they must be way to cold. Next time i go ill try and get smoke from them cuz a 2.2 60' is kinda ****ty for DRs amirite?
i have 225/50/15 on 6.5" stock rims.
My PSI was about 18-20 on most runs.
Thanks for your guys help!
Alex
Old Feb 21, 2008 | 09:03 PM
t6378tp's Avatar
Turbo 3.5
good luck, post the results when you go back and do not forget to take notes after each run
Old Feb 22, 2008 | 12:24 PM
Ceasars Chariot's Avatar
Old Maxima Legend
my guess would be the track. given the two timeslips your car was running the same but like some of the guys mentioned a little wheel spin out there early on appeared to be holding you back.
ive been on some tough tracks and been a whole second off on runs throughout the day. tell those guys to prep the track real good for you where you race lol ! seriously though 14.6 looks better than 14.9 but the difference in time is a few blinks of an eye, keep an eye out for any sort of event that you think they are going to prep the track real good and make some passes.
Old Feb 22, 2008 | 12:28 PM
Old Maxima Legend
here is a vid of the dandymax burnout I am talking about
yeah that dan does some mean burnouts, i wonder if he goes through a pair of slicks each day out ?
Old Feb 22, 2008 | 01:53 PM
DandyMax's Avatar
3.5 in the works
hehe nope... same pair going onto the 3rd season now
Old Feb 22, 2008 | 07:15 PM
00SEMAX19's Avatar
Hey Alex,
I heard they repaved PIR. Is this true? If so it's about time, the track was getting pretty rough. I can't wait to get up there again, it's been a while. Keep me posted when you go again and I'll try to get out there with ya.
BTW, those are good numbers N/A
Old Feb 22, 2008 | 11:09 PM
turbomirage's Avatar
Alex
I've get my best 60's (1.8's) running my BFG's at 13 psi cold, and about a 8-10 sec burn out. Though I have a stutter box in my car and do my burn out in second to build heat faster. Every track is also different and prep and temps play a big roll. But I would definately try a lower psi next time...maybe try 15 psi first and see how that works.
Old Feb 23, 2008 | 09:28 AM
Originally Posted by 00SEMAX19
Hey Alex,
Nah they arent repaving it the are building a completely new drag strip close to the entrance. its not even close to being done though so maybe by the end of the season or next year. The next time i am probably going is March 2nd.
alrighty ill try a lower psi and a longer burnout and see what i can do.
Thanks for the help
greenspeed
May 4, 2013 11:26 AM
FallenOne
Sep 6, 2008 11:00 PM
