foglights not working
Old May 3, 2013 | 02:50 PM
greenspeed's Avatar
I bought a 95 and installed 97 foglights but there not coming on. What can be the problem? I'm puzzled... Plz give me all possible problems
Old May 3, 2013 | 03:05 PM
Amerikaner83's Avatar
the foglights are different from the 4th gen (95-96) and 4.5 gen (97-99)
Are you adding foglights to a car that doesn't have them already? If so then you need more than just the fogs. Search around, you'll find out that you need relays and the fog light stalk as well.
Old May 3, 2013 | 03:40 PM
greenspeed's Avatar
No the car came with fogs I switched the 97 fogs over it has the switch etc... I don't know if it's a fuse or wiring
Old May 3, 2013 | 05:13 PM
greenspeed's Avatar
I swapped the brackets and fogs from a 97. Is there anything else I needed to do
Old May 3, 2013 | 05:27 PM
Quickywd01's Avatar
http://www.google.com/shopping/produ...d=0CMIBEPMCMAc
http://www.google.com/shopping/produ...ed=0CH4Q8wIwAA
Old May 3, 2013 | 10:38 PM
DennisMik's Avatar
The fuse for the fog lights is under the hood by the battery. The cover has the label FR FOG.
Old May 4, 2013 | 06:02 AM
greenspeed's Avatar
Yeah I changed that but still nothing. I switched the relay with another, also figured out the horn doesn't work either
Old May 4, 2013 | 10:03 AM
DennisMik's Avatar
The fuse for the horn is next to the fog light fuse. I wonder if you have a bad connection on the bottom of the fuse panel. Pull out the fuses and see if you have voltage on one of the pins for those fuses.
Old May 4, 2013 | 11:05 AM
greenspeed's Avatar
Thanks Den... The guy I bought the car from was ridiculous! He rigged up everything, the clutch switch doesn't work I can start the car without pressing down the clutch, reverse lights don't work. I have alot to get right. Thanks again bro... Be safe
Old May 4, 2013 | 11:26 AM
sqaeng's Avatar
dishnet
my fuse box cover (with fuse diagram) was rotated 180 degrees and I had a new fuse an a dummy slot. Once I figured it out, my fog lights started working again
mvm062
Nov 30, 2020 09:00 AM
kmitchel
Oct 30, 2015 10:12 AM
Maxima30
Sep 7, 2015 06:13 PM
iflexsteel
Sep 2, 2015 08:04 AM
Hailstatejig
Sep 2, 2015 06:52 AM
