1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
another 11 second maxima...new best 11.73
Old Mar 8, 2008 | 09:02 AM
  #41
96sleeper's Avatar
Originally Posted by Sealti96
How are those ppg gears working out for you? I'm talking to ppg right now also, I want them to make an input shaft for the RS5F50A/V (1st&2nd gear). They have agreed but the price is quit steep, I would have to send them an input shaft so they copy the teeth of the reverse gear of the fwd RS5F50A/V , its the same shaft they make for the Pulsar gti-r but this 1 will have those extra teeth.
The gears work great. I too would have liked to but the input shaft and 1st/2nd gears but the price is way too high for what I need. 3rd and 4th are the real problem areas anyway, not too many people have broken 1st or 2nd or an input shaft. I decided a shot-peen/cryo/REM finishing job on the gears would be fine for what I needed.
I didn't even realize the current PPG input/1st/2nd gearset would not work.
Old Mar 8, 2008 | 09:58 AM
  #42
VQrebuild96's Avatar
Originally Posted by 96sleeper
I don't know, 10's are a really long ways away. I would need to add alot more power or completely gut the car. I am on borrowed time on this stock motor anyway, so adding power is out unless I build the motor, and I am not sure I want to spend that kind of money on this car.
hmmm so this means 10's are possible with this car its just that we need someone to fund the parts. NICE TIMES. I wish my car will see similar times one day.
Old Mar 10, 2008 | 04:54 AM
  #43
Sealti96's Avatar
The gti-r input shaft would work, but only problem is that its missing the set of teeth that drive the reverse gear in front 50a/v , the gtir has a slightly different reverse mechanism. What final drive ratio are you running? I think a higher final drive would help a bit since your 26" tires.
Old Mar 10, 2008 | 05:09 AM
  #44
96sleeper's Avatar
I noticed the reverse teeth when I looked back at a picture of the input shaft. I wonder how much more expensive it would be for them to do reverse, it is already very expensive anyway.
I am using the factory 3.82 final drive ratio. I was using 24.5" slicks to lower the ratio, but they got to where they would not hook in 1st gear. The 26" slicks helped that drastically but still in 1st gear they want to spin sometimes. I would hate to change the final drive ratio only to find out that they would not hook in 1st. I assume it would be better than the small slicks due to the bigger sidewall flex of the 26's, but at this point I don't want to change it.
Old Mar 10, 2008 | 06:51 AM
  #45
Sealti96's Avatar
The guy from ppg gave me the same price as the one they already sell for the gtir, which was 2750 AUD (2500ish USD) this includeds input shaft and the matching main shaft gears. I understand your point about the FD, I mentioned it because I know how the rpm's drop in between gears , a shorter gear or higher FD would keep the rev's a little higher and maintain the engine closer to the sweet spot. I'm running a 4.16 FD in my 50A, but something that I have not mentioned is that I don't have a Maxima , I have an altima which has the same trans as the max. There are not too many people trying to build fast altimas so this forum is a good source for me since its very close to my car.
Old Mar 10, 2008 | 09:31 AM
  #46
Tatanko's Avatar
Bacon Lover
Not to steal away from this thread, but could you PM me some info/pics about your car or maybe post in the Members Rides section? Would just be cool to know more
Old Mar 10, 2008 | 10:03 AM
  #47
Sealti96's Avatar
Pm sent.. enjoy
Old Mar 11, 2008 | 01:47 PM
  #48
adrenaline_rush_fanatic's Avatar
congrats man!!!!
If you plan on going to the track again anytime soon.... hit me up, I haven't been to one and love to roll with you in the 02 6spd
Old Mar 11, 2008 | 06:50 PM
  #49
Aaron92SE's Avatar
NWP Engineering.com
That is AWESOME! Way to go!
I would love for my car to be in the 11s! I hope to hit 11s with a single stage 150 shot this year.
What fuel are you using?
Old Mar 11, 2008 | 07:15 PM
  #50
96sleeper's Avatar
Good ole 93 octane with the water/meth injection.
Old Mar 12, 2008 | 04:43 AM
  #51
Aaron92SE's Avatar
NWP Engineering.com
That is nuts! Congrats man! I would love to roll up to the track running pump gas, put on slicks, and run 11s!
Old Mar 12, 2008 | 08:49 AM
  #52
liqidvenom's Avatar
brotherhood of tq
did you run in street trim or were you gutted when you made your run?
Old Mar 12, 2008 | 09:30 AM
  #53
96sleeper's Avatar
I ran the car the way it stays 100% of the time. The trunk is empty and no junk in the car, but both factory power driver and passenger seats and the rear seat are all in place.
Old Mar 12, 2008 | 10:56 AM
  #54
jouvert00's Avatar
I predict 1.7 60ft in your near future.....killer runs
Old Mar 12, 2008 | 12:15 PM
  #55
96sleeper's Avatar
I have hit plenty of 1.7x 60 ft times, back when I was N/A it was easy, and then I did again a month or so ago at the 1/8th mile track. The track prep when I went to the 1/4 mile was not that great and it was spinning a little bit. Maybe one of these days I can get it together and make a perfect pass...
Old Mar 12, 2008 | 05:46 PM
  #56
kevin007's Avatar
That's even more impressive running 11's with a full trim!
Old Mar 13, 2008 | 10:52 PM
  #57
t6378tp's Avatar
Turbo 3.5
so do you think it's possible to pull a 10.9X pass with good track prep, gutted and race gas tune
Old Mar 14, 2008 | 03:18 AM
  #58
Ceasars Chariot's Avatar
Old Maxima Legend
locate any videos ?
Old Mar 14, 2008 | 04:02 AM
  #59
96sleeper's Avatar
No way. Maybe gutted with a 100-150 shot of nitrous. This stock motor is not gonna take it.
Old Mar 14, 2008 | 04:03 AM
  #60
96sleeper's Avatar
Originally Posted by Ceasars Chariot
locate any videos ?
not yet, one guy is working on it.
Old Mar 14, 2008 | 08:04 AM
  #61
ajcool2's Avatar
Indeed! Now I can go around and brag that we have maximas running 11's full trim.
Does anybody know of any S/C 350's running 11's w/o n20. I think the fastest I've seen is a 12.1. Right now 96sleeper is the fastest s/c 3.5 that I know.
Old Mar 14, 2008 | 08:57 AM
  #62
Tatanko's Avatar
Bacon Lover
I just don't get those 350 guys! They have a superior platform (by that I mean RWD, since we're talking about drag racing) more power to start with, etc., yet they seem like they have no clue what they're doing when it comes to FI. No wonder people think 350Z's are such a waste of time.
96sleeper, can't blame you for not wanting to gut the car or throw a bunch more money at your Maxima.
Old Mar 14, 2008 | 09:14 AM
  #63
ajcool2's Avatar
Its kinda funny looking at post on my350z where people say I finally took my built twin turbo setup to the strip and ran a 12.3. Then say I'm pleased with the results lmao. I'm like if I spent 10-15 grand on a setup like that I'd better be running mid 10's. I'm not bashing 350z's I just dont understand how they arent running faster than they are. I do think the HR Z's will change that though.
Old Mar 14, 2008 | 09:41 AM
  #64
DandyMax's Avatar
3.5 in the works
Yeah, 12.3 lol - I'll likely be disappointed in that with the 3.5 N/A this season!
Well weight has something to do with it but it doesn't explain all of it. There are some of them with FI setups running really low 11's however. But yeah once the HR development builds up it'll get interesting.
Old Mar 14, 2008 | 04:12 PM
  #65
Nealoc187's Avatar
SLOW
I'm pretty sure you could have said that all along because I believe mardi ran 11s in street trim way back in the day with his turbo setup. I'm not 100% positive on that but I believe that's the case. 96sleeper might well have been the first (and only) guy with an SC to do it though, I'm not sure if mardi had full interior when he ran 11.98 way back when with his SC+nitrous. I have made all my runs in my turbo car with full interior also.
edit: just wanted to clarify that I am absolutely not trying to take anything away from 96sleeper's achievement by pointing that out of course.
Old Mar 14, 2008 | 05:23 PM
  #66
ajcool2's Avatar
Yeah I wasnt sure about mardis runs before my time. I just remember the few times I've seen his car at the track he had the the bottom part of his back seat out. Of course it probably didnt make much difference but you know how the maxima haters are "Oh he had his back seat out blah blah blah" lol. **** you could be gutted and sitting a stool with nuthin but metal around and a steering wheel and I'd still be lol.
Old Mar 22, 2008 | 05:34 AM
  #67
babymac's Avatar
BOOST 4 LIFE!
Nice times bro!. I would definitely get a 6 or 4 puck sprung if your daily driving un sprung if not. Along with the extreme it should be a huge improvement over the disc.
btw I wish I could get a 11 with a 110 trap.....
Old Mar 22, 2008 | 08:14 AM
  #68
choray911's Avatar
The Crazy Azz Cracka
Congrads Matt! Looks like I need to get off my ***. I shattered both lower motor mounts a few months ago, and have not had time to make new ones. I'll have to come out and see you run. We have an auto-x at Dade county next weekend. You should come out.
Old Mar 22, 2008 | 08:16 AM
  #69
t6378tp's Avatar
Turbo 3.5
Old Mar 24, 2008 | 08:19 PM
  #70
liqidvenom's Avatar
brotherhood of tq
that is the most impressive thing about your time.... great job man.
96sleeper
29
May 12, 2008 08:21 PM
