1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
New PB 1/4 - 02 N/A Auto 13.83 @ 100.05
Old Mar 25, 2008 | 05:35 PM
  #41
1sexyleo
Originally Posted by Juiced SE-R
Very nice runs!! I wish there were more Maxima owners around here, and having a woman that could bust some *** would just be awesome!! Nice work keep it up.
thx
Old Mar 25, 2008 | 05:39 PM
  #42
1sexyleo
Originally Posted by Jime
Never listen to the naysayers, all that does is make me work harder to prove them wrong.
yeah....i already have some goals set....i love to prove ppl wrong.....someone told that i'll never run a 13.9 again....proved them wrong also
Old Mar 25, 2008 | 07:32 PM
  #43
wyche89's Avatar
good sh*t... with slicks and a tune, you'll definitely run at least 13.6.. i gotta get to the track so i can see what my time is man
Old Mar 25, 2008 | 07:55 PM
  #44
!PrjctMax!'s Avatar
Originally Posted by oTranscendental
Please keep me updated on this! You should dyno before and after to see the exact differences. No one has done this comparison yet!
If I was to be dynoing before/after on each mod then I wouldn't be modding anymore!
Butt dynos are "inconclusive" for most, but I felt it pull a little better up top with no loss on bottom.
I say SSIM, NWP spacers, bumping your timing, tune, light-weight wheels/sticky rubber=mucho profit and on the times you'd get.
Old Mar 26, 2008 | 07:56 AM
  #45
maxima92se's Avatar
thanx...what r u running now?
Last time run which was my pb in that car was a 14.7@94 with a 2.2XX 60ft time. The set up was a set of 16" wheels(pretty light), y-pipe and greddy cat-back and intake.
This time i will be running with cobra rotors upfront and 18" G35coupe wheels but i have the VI, SC but i will only be running the 3.60 pulley. If i can run a high 13@100+ mph with this set up i will be happy.
Old Mar 27, 2008 | 03:53 PM
  #46
Scottwax's Avatar
That's Mr. Detail to you
Pretty consistant 13.9s once you got dialed in. A few 100 mph traps too, nice.
Old Mar 27, 2008 | 04:23 PM
  #47
NmexMAX's Avatar
dot dot dot ...
I know of at least 4 people who have.
I ran my quickest time on stock manifold but 3 mph higher on the modified one. Too much low end loss for auto with the modified one.
Jime, did you ever run with full A33B software & modified FWD IM?
Old Mar 27, 2008 | 06:14 PM
  #48
Jime's Avatar
Yes I have run all 3 setups with the full A33B setup, stock, modified and 350Z IM's. However I can't find my timeslips from last year, but from what I remember the stock setup was quicker than the modified IM and the 350Z was the best. With the A32 setup the stock was quickest followed by the modified then the 350Z.
Old Mar 28, 2008 | 05:26 AM
  #49
1sexyleo
so the 350z IM fits my car and it gives the best 1/4 is what ur saying....right?
nevermind...i know that it could fit with some fabrication.....will it improve my 1/4 and by how much if so?
Old Mar 28, 2008 | 06:16 AM
  #50
Jime's Avatar
It would improve your 1/4, by how much I'm not sure because my timeslips are missing. I don't think it would be worth it unless you got the parts cheap. You need all 3 pieces. I also have a Motordyne 5/16 spacer ($265) and MREV 2 manifold ($400). http://www.motordyneengineering.com/350Z.htm
I got the complete manifold for $100 and the Motordyne stuff for $200 because they were just going into production and wanted some testers. Its definately not worth it if you have to pay retail.
Old Mar 28, 2008 | 07:15 AM
  #51
1sexyleo
ok i know i will need the upper and lower manifold but whats the 3rd part i need? and what years of 350z will it need to come of? im sure i can get them a little cheap.
Old Mar 28, 2008 | 07:33 AM
  #52
ajcool2's Avatar
I dont think it would be worth the work. The mrev2 is basically a ported version of the bottom part of the UIM so you would need the top portion. Also if I remember correctly the mrev2 works better with the revup model Z's. I'm not sure if it has to do with the extended redline.
Old Mar 28, 2008 | 10:39 AM
  #53
Jime's Avatar
The upper manifold is 2 pieces thats why I said 3 all together. Mine came off of an 04Z and I can't remember for sure what years you can use as I did this 2 years ago now.
Not much work involved except in getting the parts, the manifold can be swapped in a 1/2 hr.
"When used with on the non-REVUP engine, the gains are very similar to that of the 5/16" spacer but the MREV 2 Manifold will show a slightly lower peak value, with a slightly higher average value and a slightly higher TQ value. Overall, MREV 2 Manifold provides "area under the curve" and is the highest gain plenum mod available."
Old Apr 3, 2008 | 02:05 PM
  #54
punjabi's Avatar
nice runs and some good 60's. I ran yesterday for the first time, i'll be making a new thread as soon as i have enough posts. I'm not going to post ***** tho.
AaronL
Aug 8, 2020 10:31 AM
BobTX10
Oct 7, 2015 08:43 AM
Maximeltman
Sep 28, 2015 07:19 PM
dshinn
Sep 26, 2015 08:07 PM
