1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
couple of Videos of My Max VS 5.7 Tundra,WRX and Civic Coupe L know what all think
Old Oct 11, 2008 | 10:52 AM
nanomax96's Avatar
Hello Everyone, I hope you guys enjoy the following videos. I just Added 00 VI to my mod list so more videos will come in the next couple of weeks.
Civic Coupe
http://www.youtube.com/watch?v=AgNYspMmA-M
Toyota Tundra
http://www.youtube.com/watch?v=EJCaeFZv4no
Subaru WRX w/ bad driver
http://www.youtube.com/watch?v=GNh4-EOP0hY
Old Oct 11, 2008 | 11:03 AM
one_fast_max's Avatar
nice bro. good kills....VQ powa!
could you post a slip up? i'm curious about your 60s with the slicks....
and also...what did that tundra trap in the 1/4???
Old Oct 12, 2008 | 09:48 AM
nanomax96's Avatar
These are my old runs before I added the VI and It was my second/third run with the slicks before 1 went flat, but the Tundra was no joke I barely beat it my 60 w/ slicks were 2.2 and 2.3 I just couldn't get off the line clean w/o bogging.
Old Oct 12, 2008 | 07:03 PM
QNO_A32's Avatar
what rpm were you starting at. sounds like you should launch a little higher. remember...theyre slicks.
Old Oct 13, 2008 | 11:10 AM
nanomax96's Avatar
On my 1st run I launched at 2k and yep bogged nasty. I tried Launching at around 3500 but It stilled bogged, my 60 in that run was 2.3. Next run I launched at 4000 and still bogged a little bit but 60' came down to 2.2 but on this run I got a flat so I didn't have a chance to do any more testing. I'm hoping to bring them down to 2.1 maybe 2.0 with good prep next track day Nov. 1st. I'll keep you guys posted and load some more videos then.
Old Oct 13, 2008 | 11:39 AM
what was the tire pressure??
you should try a quick slip from 5000 or so...that should get you a 1.9xx
Old Oct 13, 2008 | 11:57 AM
kzoosho's Avatar
To let you know, i was pulling consistant 1.7 60ft's on slicks. You dont dump the clutch you slip it man. Thatll cut you better 60's
Old Oct 13, 2008 | 01:00 PM
96blkonblkse's Avatar
What other mods do you have? I saw runs of 14.8-15.2@92, which seems awfully low considering you do have an 00vi. It almost sounds like its not opening?
Oh and fyi, if your persistant on dumping the clutch with slicks, try something higher. Ive done some 4500-5000RPM clutch drops on DR's which has netted me some sub 2.0 60's. IMO a quick slip is much better, takes a lot of the streess off your tranny/axles.
Old Oct 13, 2008 | 01:27 PM
nanomax96's Avatar
I had them at around 15psi but I noticed by mph dropped from 94/94 to like 90/91/92. I'm thinking of rasing it to 20 psi next time I'm out.
Old Oct 13, 2008 | 01:28 PM
nanomax96's Avatar
Thanks for the advice. I'm going to the track on Nov. 1st so I'll give it a try and see how it goes.
Old Oct 13, 2008 | 01:31 PM
nanomax96's Avatar
I didn't have the 00 Vi installed at the time of these runs . I only had the I/Y/E/ Fidanza flywheel, MIdPipe and techno. ECU. and I was running on 17 alti wheels with 225/45/17 all around on all the runs except the 3 or so with the slicks.
Old Oct 13, 2008 | 01:47 PM
Grand_hustle17's Avatar
Old Oct 13, 2008 | 02:19 PM
Ahhh makes sense then! Well get back to the track and SPANK those cars. 00vi/Mevi makes a HUGE difference over the USIM.
My best with i/y/e flywheel, udp, and balding street tires was 14.59@95, i went to the mevi + jwt, and with the same tires i pulled 14.1@99.6mph, with a 2.12 60ft. I know if i had better tires i could have pulled high 13's.
Go represent what the 3.0 can do!!
Old Oct 13, 2008 | 08:48 PM
nanomax96's Avatar
Man that is the only thing I need (extended rev limiter) I've been looking for a used EU but so far no luck. High 13's is my goal. Do you guys think I can attain that with what I have? w/o tune.
Old Oct 14, 2008 | 11:29 AM
Scottwax's Avatar
That's Mr. Detail to you
Nice runs!
Old Oct 14, 2008 | 03:11 PM
Depends. Are you running the DEK injectors? If you are, i believe that causes a bit of richness.
Assuming you have all the supporting bolt ons with the 00vi, 13's isnt out of the question, once you get it tuned, you should be fairly deep into the 13's with slicks/DR's.
This is of course your able to cut a sub 2.0-2.1 60ft. And it is very very possible, with the proper clutch modulation and finesse, i personally have cut a few 2.1's on balding street tires.
Old Oct 14, 2008 | 03:29 PM
nanomax96's Avatar
Yes I'm running 2k lower, and injectors.
Old Oct 14, 2008 | 03:31 PM
nanomax96's Avatar
What size tires were you using and what rims.
minsbang
Sep 5, 2015 05:36 AM
DrVee
Sep 4, 2015 12:18 PM
crazyespn
Sep 3, 2015 01:30 PM
iflexsteel
Sep 2, 2015 08:04 AM
